Question about Breville Kitchen Appliances - Others
It makes a popping noise when it boils< sometimes the switch shuts off.
    Guru:
  • 575 Answers
Corroded element. Renew.
Popping/bursting/spitting caused by steam expanding inside normally dry element tube.
Posted on Oct 09, 2017
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Loud popping noise?
its just the unit in defrost mode,the popping sound is water hitting the defrost heater and boiling away,no need to worry
May 24, 2010 | Magic Chef CTF2125 Top Freezer...
Shuts off
Does the unit shut off only before the water boils, or does it shut off and on periodically? I just fixed my friend's WK200 Braun kettle. His would shut off and on, eventually coming to a boil. During normal operation, when you press the switch, it is connected to a rod which at its other end (ie the bottom of the kettle) is able to close the circuit allowing the current to pass through the heating element. In my friend's case, the contact had become weak - I just had to slightly bend the metal pole a little bit to provide a better contact when the switch was depressed. To repair the unit, I only needed a couple of torx screwdrivers and a voltmeter to measure continuity. (note, if you bend the metal pole too much, then the circuit will always be closed even when the switch is OFF - make sure you test for an open circuit when the switch is OFF)
Jan 29, 2010 | Braun WK200 Cordless Electric Kettle
It starts to boil but shuts off before it boils and then may start uo again but then shuts off prior to getting hot.
this is a comon problem with them its the switch playing you up,it has a "bymettel spring in it" they just kind of were out and then they do what yours is doing popping off to early t-fal may be able to fix it for you (but at what price??????) could it be cheeper to get a new one
Oct 26, 2009 | Tefal T-FAL Avante Stainless Steel...
WHEN I SHUT OFF MY BURNERS AFTER THEY HAVE BEEN ON FOR A WHILE, THEY POP.I WOULD LIKE TO STOP THAT IF POSSIBLE. WE USE PROPANE.
EXTINCTION POP
(1) Recognition of Extinction Pop. Sometimes a small explosion of gas in the burner head occurs when the burner is shut off. Under these conditions flashback on extinction has taken place. This problem is commonly called "extinction pop." Extinction pop, as the name implies, creates a noise or a "bang." Ordinarily, it is not followed by burning in the burner head or mixing tube, since the gas supply is turned off. The pop occurs at the time the gas supply to the burner is shut off. Sometimes it may be delayed for a few seconds.
(2) Results of Extinction Pop. Ordinarily, extinction pop is not unsafe or hazardous, and will not damage the appliance. It may result in a customer complaint because of the noise created. However, the resultant concussion may blow out the pilot flame. If an automatic pilot safety device is used, it will act to shut off the gas supply to the appliance.
(3) Correction of Extinction Pop. It may be possible to eliminate extinction pop by reducing primary air supplied to the burner. Make sure this air adjustment does not cause yellow-tipping during normal burner operation. Check proper gas pressure and proper gas orifice size. If these actions fail to correct the problem, burner change may be required.
Sep 08, 2009 | Tappan Kitchen Ranges
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
I was boiling water on the electric range beneath my FRIGIDAIRE FMV157GC 1.5 Cu. Ft. Microwave Oven when there was a loud snapping/popping noise occured. I immediately shut off the microwave and thought...
I would say the transformer for the power supply has probably shorted, or another major component in the power supply has shorted - This may be repairable if easily spotted, but most likely will not be cost efective.
Sep 04, 2008 | Frigidaire Microwave Ovens
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Noise
Freon "boils" when compressed and pushed through the evap. causing cold. Sometimes after time you can hear it making the boil sound. There is really no way to fix it. Well... There is a way to fix but the price you would pay to fix it; you could turn around and buy a brand new freezer! GOODLUCK:)
Dec 17, 2007 | Haier HRT02WNC Compact Refrigerator
Kettle shuts off before boiling?
I had a similar failure. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettlefuls; so far so good!
What ticks me off about this is that I don't mind getting 'Made In China' ****; everything comes from China anyway. But don't charge me a ridiculous amount of money and try to pretend that I am getting a superiour product. If I had paid twenty dollars or less for it I would just chuck it and get the same one again because it looks nice, pours well, doesn't burn the hands, worked OK for couple of years, etc. Instead I walk away from this feeling really ripped off. I have a house full of Braun products(shaver, kettle multiple tooth brushes) but now I won't buy any more.
Oh and if you take your kettle apart and your house burns down it is not my fault. There, now I feel better.
Aug 29, 2007 | Braun WK600 Cordless Electric Kettle
Kitchen Appliances - Others Logo
300 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
