Question about Kenmore Kitchen Ranges
How do I properly operate the Turbo Boil on my new Kenmore range?
When I turn on Turbo boil the element glows red, and the water heats to almost boiling, then the element cuts off. How do I keep the water boiling?
  • Kenmore Master
  • 3,287 Answers
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Posted on Apr 07, 2015
Can you put a Greek coffee maker on a glass top new coker
There are essentially two types of Coffee Maker, one where the water is heated by an immersion element (where the water is heated by electricity), and a Boiling Water Coffee maker, where you heat the pot on a stove top element either by gas or electric heat.
(If you hve one of the electric immersion ones, don't do what a famous comedy showed and place the coffee pot on the HOT SURFACE of the cooker.
While the first pot of coffee might get warm, the idea is to heat the water from the inside, then have the coffee brewed by the machine after.
Is there a MODEL or NAME on the BOTTOM of the maker?
Google or search for these things first and get back to this board if that does not help.
If I understand your question (sort of) , are you asking if a Metal pot can be placed on the top of an INDUCTION type cooktop, where the special rings Induce a current of electricity into the bottom of the fry-pan or Stock-type pot to boil water or fry items in oils.
I do not know if there is any special method used in Greece to make coffee. Please provide details, if you were not having a 'glass' cooktop.
After some research, a 'Greek' coffee maker or 'Bricki', is a stainless steel or copper pot used to boil the water and grinds together without any extra filtering.
So, the Original Poster needs to determine what the pot is made from (The type of metal), and the other part is what type of cooker element is underneath the 'glass' part of the stove.
The Test is if you turn on the element, and watch it, does it glow red underneath or not?
If it glows red, then the heating elements are embedded into the glass and the stove functions similar to a regular electric range.
If the 'glass' portion is black and does not glow red without a pot on the top of it, then it is an INDUCTION element, and the Inductor NEEDS a metal pot on top to induce a magnetic field to make the bottom of the pot warm up.
Based on the Size of the Pots shown in pictures, it may be too small to function in your particular cooker. A model of the cooker would help. The label is usually on the door frame to the oven or a logo or name near the contol knobs.
Sep 06, 2017 | Coffee Makers & Espresso Machines
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Why do burners not get hot? After rehooking to electrical power, due to a remodel, the burners don't seem to heat up as hot as they used to. Cant boil water on any of the 4 burners.
Could be not enough voltage on your 220.lines ( one wire lose or a bad breaker. or the wires are hooked up wrung causing it to try to operate on 110 instead of 220
Aug 17, 2014 | Kenmore Electric Smooth Top Stove
Inner 6-inch element on the 12 inch/6 inch Dual Radiant Element cycles off too long
Sounds like the file is corrupted. That doesn't mean the footage is irretrievable. I believe the file type is .mov on that camera? You need to find a .mov repair program, there are lots out there. I don't want to give you a link since I haven't used any of the .mov ones and don't want to accidentally give you malware, so I'll leave that part up to you. But you should be able to get your file repaired, just google ".mov repair."
Nov 15, 2013 | Whirlpool Kitchen Ranges
Kenmore microwave Model 72 8975590 (750 W) is taking longer to heat food. Takes 3.5 min to bring one cup water to boil, previously took 2,5 to 3 min. Does the element lose power over time?
I can adjust the power level so that circuitry seems to be ok. The longer water boil time could be partially due to the colder winter temperature of the inlet water. We'll just cook the food a bit longer as long as the magnetron is still working.
Jan 21, 2010 | Kenmore Microwave Ovens
When turned on, the stove heats up and down periodically.
If you are talking about the burners on a glass top range yes they cycle, even on high. will it boil water?
Aug 06, 2009 | Whirlpool GR563LXS Kitchen Range
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
2 burners work, 2 don't
ok, first check that the ranges are seated properly , clean the connectors , do a test , if it still doing the same problem , then you need to replace the modules of each range thats not working,in this case 2 modules.
Nov 15, 2007 | Kenmore 96213 Electric Kitchen Range
Kenmore smooth top - cooking problems
Smooth tops take a little geting used to than a coil top range....Make sure you have good flat cookware. NO GLASS COOKWARE. (ie vision ware.) Once the burner is set to high, it has to heat the glass, then the pot, so it does take about 2 min loger to boil, If you want to simmer, then i suggest bringing the item to a rapid boil, and then cutting back the heat to below the 1 on the range. and adjusting from there. All smooth top glass ranges do work in this manner. Most people can adjust to the switch, but not everyone can. there really is no problem with your range. BTW i work at sears, and i am surprised that no one helped you.
Dec 20, 2006 | Kenmore 96412 / 96414 / 96419 Electric...
Kitchen Ranges Logo
142 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
