Question about LG 32LG30 32 in. LCD HDTV
How do I fix an LG TV that shows a gray screen for the first 10-20 minuets when it is turned on?
When I first power on the TV, it is fine. Then after 10-20 seconds the picture will freeze up. Then most of the screen turns gray except for a 1-2 inch strip at the top of the screen. After about 10-20 mins. The picture returns to normal.What is up?
    New Friend:
Sounds like a faulty T/con board ,,if replacement doesn't fix it it will be a faulty main av board
Posted on Apr 07, 2015
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 68 Answers
First, try to plug another source on your T.V. set and let see if it's gonna do the same trouble. If not, this is not the T.V. but the source,( cable box or other) that is defect. If not, Looks like a main board problem, or if you're lucky, a cold joint, (Which i doubt). Sometimes it could also be a bad piece in the power supply but i can not say like that. I would have to make test on it with the service manual. If changing source does not work, i suggest you to see a professionnel. Best of luck. Best regards,
Serge.
Lg tv gray screen main menu screen flickers
tats something in the board its self youll have to take that to a tv repair man
Dec 06, 2013 | LG Televison & Video
Gray vertical bars on screen but no picture
It sounds like you might have shorted out the display panel driver board / boards.
These boards are located at the bottom of the screen and are prone to liquid damage.
Just before this happened, did you happen to spill something on the screen or clean the screen using a spray bottle cleaner?
The only fix I know of is to replace the whole panel but it is usually just as cheap to buy a new TV.
Nov 28, 2013 | LG 55LE5400 55-Inch 1080p 120 Hz LED HDTV...
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
LG 55LD520 picture problem
the problem with these sets (all brands) is it could be any board in the set or even the panel used for the display---
Jun 06, 2012 | LG 55LD520 55 in. HD Ready LCD TV
Works fine for 10-15 minutes, then screen goes gray/black and the input flashes in top right corner (alternate gray/black screen and input display). turn tv off, then back on several minutes later - same...
It can be caused by unstable DC in the power supply due to bad DC filter caps, that will be the first place to look. I have a feeling that it may be the main board.
http://www.shopjimmy.com/catalogsearch/result/?q=LG+37LC7D+
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 17, 2011 | LG 37LC7D 37 in. LCD HDTV
Just purchased an LG 42lf7700. All loads up fine
I'm also having this problem. Did you manage to get the problem fixed?
Apr 25, 2010 | LG Televison & Video
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
LG LCD TV remote power button turns off LG DVD Recorder as well
Hi VMUZZI,
IT Seems that teh SIMPLINK Featire of your TV/DVR is ON. Try to OFF the feature.
Mar 09, 2009 | LG DR787T DVD Recorder
LG 32LG30 32 in. LCD HDTV Logo
142 people viewed this question
Computer Repairing
Computer Repairing
