Question about Chevrolet 2011 Chevrolet Express 3500 Cutaway 1WT
Brake caliper causing abs to activate a wobble
Intermittent front wobble when braking
  • 36 Answers
SOURCE: My Silverado front end wobbles at any speed, not affected braking
Couple of checks , mud in front rims will give you a wobble. Front tire cord seperation or loose wheel nuts. , Wore out tie rod end, front wheel bearing play, or a weight has fallen off the rim and it needs balancing. If it is vibrating your steering wheel, have the front end looked at right away.
Posted on Mar 12, 2009
  • 19 Answers
SOURCE: Spongy brake pedal even after ABS bleed and base brake bleed.
Did you adjust the rear shoes out? If the rear drum brakes are out of adjustment they will give you a lot of pedal travel. If the pads are worn have no fear of that U-CLIP brake spring, just change one shoe at a time. Take the spring off one side, change the shoe, put the spring back on the post and do the same to the other shoe, no problem.
Posted on Dec 19, 2009
xdmann
  • 43 Answers
SOURCE: 1999 Chevy Tahoe- Soft Brake Pedal
Try having the dealer flush and bleed your system. It is very hard to bleed ABS systems yourself and have safe brakes that still work afterward. Bleeding non-ABS brakes yourself is easy not the same for ABS brakes. Valving, sensors and what-not require a tech and the correct equipment in my opinion. You do it wrong and you could ruin your ABS system. Do that and see if they firm up. I replaced my brake shoes/pads at the same time all new everything in back, drums/springs everything and new rotors up front. then I had the chevy dealer flush, refill and bleed system. Stiffer pedal and brakes work better. Keep in mind the brakes on 99 Tahoes are inaedequate, require new rotors often, heat up and fade/glaze pads regularly. I replace my pads long before they wear down because they glaze up and start fading early. I'll rough em up once maybe, next time, new ones. Every two brake jobs, new rotors for me. Just how it is. They will stiffen a bit and work better but they will never be awesome brakes. Just how it is on 99 and earlier Tahoes. Hope it helps. Very important to bleed correctly though. I'll bleed my 83 Toyota 4x4 myself but not the Tahoe.
Posted on Jan 30, 2010
SOURCE: Brakes are still spongy after changing the pads, one caliper, and master cylinder. bled front brakes.
I just went to Brake Masters this morning and had them replace the Master Cylinder since I was experiencing the pedal very spongy and going to the floor. When they replaced the Master Cylinder and they gave me back the car, the brakes were still spongy and going to the floor. I addressed this to them and they took another look at it, but when I took it for a second time, the brakes were extremely spongy. It was almost like they gave me back my car in worst condition to when I brought it in. Can you help?
Posted on Jul 31, 2010
Mr BrokRench
  • 1623 Answers
SOURCE: the left brake caliper sticks after my 97 lumina
Hi there...when you say it "sticks" are you think the pistons are not retracting in the calipers? Did you replace calipers with NEW ones or remanufactured/rebuilt ones? How about the caliper slides, did you replace those? About half the time this is the problem on a sticky caliper that is causing excessive brake wear. If they are off just a little bit & no longer "true" the caliper will bind and the brake pad will steadily rub on the rotor. They need to lubed with disc brake grease and the protective boot needs to be in good shape to keep the brake dust and debris out too. This is an inexpensive part, easy to replace and often overlooked by shop techs. Good luck, i hope this helps. Thanks for using FixYa!
Posted on Jul 12, 2011
Problems with bmw r1200gs
If your speedo still works, it means the rear sensor is fine. Have you had the front wheel off lately?
If so, check the wiring to the front sensor just above the left brake caliper. Sometimes the cable is removed from the the clip and is then worn away buy the edge of the brake disk. This will cause an intermittent problem affecting both ABS and TC.
Apr 03, 2014 | 2011 BMW R 1200 GS Adventure
Tip
How To Help Keep Your ABS Brake light Off On Your Dashboard
Have you ever driven in someones car and seen the ABS light lit up like a Christmas Tree on the dash board?
Here are a couple of helpful tips on how to keep this braking system in good shape.
#1. When replacing your Disc brake pads be certain NOT to hit the wheel sensors on every wheel as damaging them can kick the ABS light on an when this light comes on the ABS system shuts down until it is repaired.
#2. Try to use the newer ceramic disc brake pads as they are less likel;y to throw dust all over the wheels and the sensors impediing the workings of the wheel sensors, thus requiring more frequent cleaning of the brake dust residue that forms on the sensors and ultimately causing the BCM to read a system failure and shut down the system till it is fixed.
#3. Be sure to have your wheel and axle bearings inspected for excess play as if they go bad the wheels can ultimately vibrate and wobble sending this information through the particular wheel sensor and back to the Body Control Module thus setting off the ABS light, and perhaps if the axle bearing etc. is bad enough, the excessive wobble could be translated as a wheel slippage thus causing the ABS to lock up the brake caliper on this particular wheel and create all sorts of havoc.
As always.....Happy Motoring!!!
on Aug 03, 2010 | Chevrolet Caprice Classic Cars & Trucks
ABS & brake Wobble in Cherokee front end
I am not familiar with your ABS as to how it is fed to the brakes but I am pretty sure I know what you are talking about. It sounds like your ABS is activating which is in my case the wheel hub. You will notice a wire harness coming down to your wheels and where that attaches is usually where the problem is. (problem being if I am correct when you brake you are getting a rapid pulsing rather than a smooth brake)
Mar 26, 2014 | Jeep Grand Cherokee Cars & Trucks
Brake Caliper will not release
The only things I can think of is ether a kink in the right side brake line or the proportioning valve is clogged or stuck or the ABS valving is clogged or stuck. Its possible the system has become contaminated with moisture???
Mar 05, 2013 | 2004 Ford Mustang
Car shakes when i press on the breaks
The most likely cause is a warped or unevenly worn disc (front brakes) or drum (rear brakes on some models). Problems with the calipers can also cause intermittent grabbing, which would make that wheel vibrate.
A bad wheel bearing is another possibility; the bearing may intermittently lock up under the decelerating force from braking. In this case, you probably also have a rumbling noise at certain speeds from the offending bearing.
If the low traction or ABS light comes on when you get the brake and shake, the ABS may need repairs. This is a low-probability situation.
I recommend an inspection of each brake and wheel bearing. (Wheel lug problems may be involved, but you'll see those when you pull the wheel to look at the brake.) If there is visible wear on the drum or rotor, check to see if it still in allowable limits (any car parts store that does brake turning will be happy to measure it for you).
Feb 28, 2012 | 1999 Oldsmobile Intrigue
The left rear wheel is locked up
This can be caused by a defective anti lock brake system ABS for short, this year has active ABS, this means the system can apply hydraulic pressure to the brakes with the driver never touching the brake pedal, if the valve that controls this pressure to the wheel leaks or sticks the brakes will lock up. To confirm this release pressure at the wheel by opening the brake caliper bleeder valve at the top of the brake caliper with the engine off. If the wheel spins free after the pressure is released you will need the ABS checked and quite possibly a new ABS hydraulic control unit. This type of failure is very rare but it does happen
Jan 16, 2012 | 2003 Dodge Caravan
After driving for about 50 feet, and apply my brakes I get a loud rattle from the front passenger wheel. It is really loud in the 10-0 mph area. It keeps buzzing and rattling while holding the breaks in at...
All possible solutions will not fit here ...
I think it is time for a brake job. I think the scrapper on the disk is telling you it NOW time to get the front brakes serviced. Delaying the service will probably result in more damage to your disks.
Thanks for your interest in FixYa.com
Nov 29, 2010 | 1997 Buick Park Avenue
Caliper is sticking
the ABS valve in the ABS hydraulic control unit is leaking pressure and causing brake to apply is the most likely thing wrong..
May 16, 2009 | 1997 Pontiac Grand Am
Brakes pulsate real hard
That is just the ABS system at work. It is supposed to prevent your wheels from locking which often makes the brake pulsate, especially in wet weather or or snow or ice. The only way to really stop this is to disable to ABS by unplugging it and removing the fuse. This will make the ABS light appear in your dash, but your brakes will stop pulsating.
Jul 14, 2008 | 1997 Pontiac Sunfire
Chevrolet 2011 Chevrolet Express 3500 Cutaway 1WT Logo
225 people viewed this question
Top Chevrolet Computers & Internet Experts
Richard Warren
Richard Warren
Devon trahan
Level 1 Expert
Jeff Armer
Are you a Chevrolet Computer and Internet Expert? Answer questions, earn points and help others
