Question about Diamondback Serene Classic Women's Sport Comfort Bike (26Inch Wheels)
How do you level the seat? It is angled down in the front and I'm always slipping forward.
    Problem Solver:
  • 18 Answers
Underneath the seat is an adjustment. It is right underneath the seat and has notches in it..
Posted on Apr 28, 2015
Seat sloped too far forward
You need to be sitting in the chair and the middle lever is the one which releases and secures the angle. I find the adjustment is easier if you release the backrest lever, the third lever to the rear, lean back in the chair which will raise the front seating cushion while moving the backrest back. Using you feet on the floor push back in the chair until the seat feels better. When it is at an angle you like, push the middle lever down to lock the seat in place. Then adjust the backrest with the third lever.
Apr 08, 2014 | Tempur-Pedic Furniture
Tip
Level Seat tip
The most common cause of saddle discomfort is an improperly adjusted seat. Start with the seat level with the ground and only tip it from 2 to 3 degrees up or down if you think it will help ease discomfort. Don't make the mistake of angling it steeply downhill. This makes you slide forward putting too much weight on your knees and hands.
on Dec 21, 2010 | Cycling
How high from the floor should an office chair be?
For mostpeople, the office chair should be somewhere between 16-21 inches (40-52 cm)from the floor.
Jul 30, 2012 | Furniture
I just hired a brand new Primo Viaggio car capsule yesterday and after adjusting it to the most lying-down position for a newborn, it seems that the baby's head will be bent forward when in the seat, I...
With the Primo Viaggio car seat, newborns and young infants should be at a 45 degree angle to prevent head slump and best distribute crash forces in case of accidents. Once infants had gained head and neck support a 45 degree angle is no longer needed.
The other type of car seat you are referring to is a car seat bed. They generally only used by very ill or very premature infants. With certain infant seats now being able to accommodate ever smaller infants they are a shrinking market and are not generally available for public purchase or use.
Feb 26, 2011 | Peg Perego Primo Viaggio Verde Infant Car...
2006 Ford Explorer: Back seat won't fold flat to create flat cargo area. It folds down but not flush.
Okay so im just going to start from the seat being upright in a normal riding position.
1. You need to fold the head rests first. Pull the black tab under both headrests. They should spring into a folded position.
2. pull the side seat lever (on the door side of the seat). This will fold the top/back support down to an angle.
3. There is one more lever on the backside of this seat. Its in plain sight on the angled portion of your seat. Lift the big plastic lever.
4. While keeping the handle lifted, grasp the back of the seat and pull it torwards the front of the car. The seat should come unlocked and roll forward and down more towards the floor. If you have a bunch of junk on the floor, it obviously wont work. clear the path and the seat will fold completely flat.
Also, your drivers seat and front passenger seat cannot be all the way back, they need to come forward some in order for the second row seats' head rests to clear and fold flat.
Oct 02, 2010 | 2006 Ford Explorer
Dont know how to fit the seat to the bike
1. Tighten the bolt on the seat-post of your bike's seat if your seat is a bit shaky. You may need to replace this bolt if it is rusted or withered.
2. Adjust the pitch angle of your seat if it is uncomfortable. You can have it level, leaning forward or leaning backward depending upon what is more comfortable for you. Use an Allen wrench (Allen key) to loosen the bolt on the-seat post to adjust the angle.
4. Tighten the tension on the cover of the seat if the seat has one and it is loose. If it has 2 straps underneath the seat attached with a hook, release it from the hook and tighten, then re-hook the straps.
May 15, 2010 | Dynacraft 16" Boy's Wheels Bike
The angle of the headrest is too far forward on 2010 ford focus
try cleaning battery connections and starter connections if this does not help check timeing may be out. check nfor possible over heating. berrydalewolf
Oct 26, 2009 | 2009 Ford Focus
The lever to move the driver's seat forward and backward doesn't
The reason is that your sliding grips have been slipped and therefore jammed at one position.
Remove the seat open it's sliding grips and replace it.
Jan 28, 2009 | 2002 Nissan Pathfinder
Hoover Elite motor runs when moving backwards but not forward
Are you sure its not just your belt on the beater of head slipping and needs to be replaced?
Oct 18, 2008 | Hoover Elite Rewind Bagless Upright...
Driver Pwr Seat - Half Works & Vanity Mirro
I had the same problem with my 2005 malibu vehicle. To find out the welds they use under the seat to connect the steel brackets are not that strong and snap leaving the seat at an angle position.The best bet is to look under the seat at the side thats angled down and look for a long metal pipe with a U shape it might look a little rusted.If this is so you need to find a welder to reweld the two pieces.
Aug 24, 2008 | 2005 Chevrolet Malibu
Diamondback Serene Classic Women's Sport Comfort Bike (26Inch Wheels) Logo
188 people viewed this question
Top Diamondback Cycling Experts
Tony
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
