Question about Fossil Watches
How do i set time on fossil abacus analog watch
    Top Expert:
  • Fossil Master
  • 40,244 Answers
Google (fossil)(model)(manual) without parens for instructions.
Posted on Jan 27, 2017
SOURCE: Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Posted on Aug 24, 2007
  • 17 Answers
SOURCE: Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Posted on Jul 30, 2008
  • 4 Answers
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Posted on Dec 02, 2008
  • 2334 Answers
SOURCE: how to set analog time on casio fishing gear watch
Follow this link and get manual:
Rate me, please.
Posted on Mar 15, 2009
SOURCE: Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
Posted on Feb 09, 2010
How to set a abacus au8002 watch
Google (fossil)(au8002)(manual) without parens for instructions.
Dec 25, 2014 | Fossil Abacus Watches
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Nov 09, 2012 | Fossil Abacus AU4002 wristwatch
I lost the Wrist Net power supply but I do have the charger base. What voltage is the power supply?
Wow, I haven't used my SPOT watch in years--but I found it!
The charging base for my Abacus AU4000 uses an adapter rated at 12 volts, .11 amps, center positive. I believe that all the charging cradles for the Abacus Wrist Net series watches were the same--the different model numbers referred to different case and band options.
Good luck, and don't hesitate to follow up if you have any additional questions.
May 26, 2011 | Fossil Abacus AU4002 wristwatch
I have an Abacus wrist net and the battery is dead. Where do I send it to get the battery replaced?
Most watch shops will replace batteries but you might need a Fossil dealer to replace yours, as it might need a special tool.
Try your local dealer first.
If you do need a Fossil dealer, go to ""; at the bottom of the screen is a menu which includes "store locator". This will tell you where your nearest store is.
Jan 16, 2010 | Fossil Abacus AU4002 wristwatch
I have an Abacus AU4000 Fossil watch but I cannot set the time manually...does anyone out there know how this is done? I do not have access to the MSN network at my location to allow the watch to set...
you can find an exper in the local shop where you buy the product and they will give you specific service for your questions about your product.
In addition, and i like to play world of warcraft. there is a reliable website for
all players to get world of warcraft gold with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service for your login.
Jan 06, 2010 | Fossil Abacus AU4002 wristwatch
I purchased a abacus wrist net on line with msn direct , and my battery isn't charging with my charger.
Your issue may not be that the watch is not recharging, it may just need to be reset. This will work on most, but not all of the abacus watches. You need to press all but the top left button at the same time. Do this 20x if successful, your watch will magically power up. I have this issue from time to time, usually right after a static shock. Hope this helps!
Dec 15, 2009 | Fossil Abacus AU4002 wristwatch
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Dec 12, 2009 | Fossil Watches
I cant find a battery for my Fossill Abacus Wristnet AU 4005
It has a Powerful rechargeable Li-ion battery so there is no need to purchase extra battery kits!
Aug 25, 2009 | Fossil AU4003 Wristwatch
Go to and go to customer care. Once there go to watch manuals and look for your watch.
Apr 06, 2009 | Fossil AU4003 Wristwatch
Watches Logo
57 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
