Question about Dynomax 2000 - 2001 Oldsmobile Bravada Exhaust System Kit 19331 Olds
How. Do you bleed the brakes to get the dash brake to go out
Fixed my ABS brakes by replacing two brake lines. Now I get ABS light on dash.Need to erase light. Fixd diagnostics said all is good. Just need to get light off for ABS.
Did you bleed the brakes after you replaced the 2 brake lines. Did you breed the brakes with or with out the power on.The right way to bleed brakes with abs is with thew power off. you will need a abs scan tool and re bleed the brakes
Aug 21, 2017 | Cars & Trucks
Why is the brake light on after putting front brakes on
Do you mean the brake lights on the rear of the vehicle or the brake light on the dash?
Jan 21, 2015 | 2002 Kia Amanti
Brakes will not bleed, air in lines, not getting fluid to brakes
check the brake booster a lot of times they will leak on the inside of the firewall and run down under the carpet inseide look under the dash where the brake pedal rod goes thru the fire wall and see if there is and brake fluid coming thru
to bleed brakes by myself i use a bottle of brake fluid and get a hose the size of the bleeder on the brakes and put the hose over it and put the other end in the brake fluid open the bleader a little and pump the brakes air goes out and it will pull the fluid back in
Dec 21, 2014 | 2004 Honda Odyssey
Do you have Brake Light Reset Instructions?
Try your foot under the emergency brake pedal pulling upward may be a weak return spring on the pedal. Unless you've been low on Brake fluid which would mean it's time to bleed the brakes...
Jul 01, 2014 | 1986 Chevrolet Crew Cab Pickup Truck Dash...
How to add brake fluid international 574
It has hydraulic brakes, you will have to bleed the brakes. There is a bleeder screw on top of each rear axle, and it looks like a grease zerk.
This procedure will require a clean bucket and 1/4, 3/8 or 5/16 inch clear tubing that will fit over bleeder screw nipple.
To bleed the brakes run the tractor until the Hytran hydraulic fluid reaches operating temperature.
Run engine at fast idle 1400-1600 RPM, block rear wheels.
With tubing connected to nipple on bleed screw and other end in clean bucket, loosen bleed screw and let hydraulic fluid drain until you are air bubble free, then close bleed screw. Repeat on other brake. Do not pump brakes while bleeding.
Check and if needed, Top off the hydraulic fluid with clean fluid, make sure transmission fluid level is full or over full. Also check for leaks at the bottom of dash and along the top of transmission cover. The brake lines run from under battery box along the top of transmission and then go to the rear axles.
You might have to repeat the bleeding process to get all the air out of the lines, if the bleeding works but only lasts a few days then it probably has leaking seals in brake pistons.
Jun 27, 2014 | Garden
1989 GMC SIERRA BRAKE LIGHT IN DASH STAYS ON [CHECKED FOR AIR IN BRAKE LINES-NO AIR] [BRAKE FLUID LEVEL GOOD] [BRAKE PEDAL PULLED UP] IN DASH BRAKE LIGHT STAYS ON
Check your emergency brake. Make sure it isn't partially pressed in. Try unplugging the switch to the emergency brake and see if the light goes out; if it does the switch is bad.
Jun 24, 2011 | 1989 GMC Sierra
Driver side brake not bleeding properly after bleeding left side and changing rotors, calipers, and pads?
first of all make sure master cylinder is full of brake fluid.then you crank car leave foot off brake pedal. watch abs light on dash it should turn off in 10 seconds if not have car towed to garage or dealer. they have to use a scanner to scan the abs brakes if abs light turn off in 3 seconds. then starting bleeding from master bleed the lower brake line fitting at the proportional valve followed by the upper brake line fitting. keep eye on brake fluid in mastercylinder dont let run dry.next prime the abs hydralic modulator.connect the bleeder hose to the rear bleeder valve on the modulator.place the other end into a container partially filled with cleab brake fluid.make sure the end of the hose is submerged.open the bleeder valve slowly about 1/2 to 3/4 turn have an assistant depress the brake pedal and hold it in the depressed position. when the flow of fluid ceases close the bleeder valve.repeat process until no air bubbles are present in the fluid.then tighten the bleed valve securely. start bleeding brakes. your bleeding sequence is right rear - left front - left rear - right front.WARNING IF ALL FAILS YOUR BRAKES DONT FEEL SOLID AND FEEL VERY SPONGY.DONT DRIVE CAR. HAVE IT TOWED TO DEALERSHIP.THEY WILL HAVE TO PRESSURE BLEED YOUR BRAKE SYSTEM.
Nov 17, 2009 | 1999 Oldsmobile Alero
BRAKE PEDAL GOES ALMOST TO THE FLOOR, DASH LIGHT ON FOR BRAKES, PEDAL APPEARS SPONGEY.
SOUND LIKE AIR IN BRAKE LINES.CHECK BRAKE FLUID LEVEL MAKE SURE ITS NOT LOW. CHECK ALL BRAKE HOSES AND BRAKE LINES. FOR LEAKS. YOU HAVE TO BLEED BRAKES.IF ALL IS GOOD.YOU HAVE MASTER CYLINDER AND ABS BRAKE FAILURE.HAVE DEALERSHIP FIX IT.THEY HAVE THE EQUIPMENT TO TROUBLE SHOOT AND BLEED THE BRAKE SYSTEM.
Sep 12, 2009 | 1995 Dodge Grand Caravan
92 dodge van rear ABS-brake and ABS lights on/can't reset?
Its probably how your bleeding your brakes, but first make sure the bleeding nipples are facing upward. You should bleed diagonaly, front pass wheel then rear driver wheel. Then front driver wheel and rear pass wheel. The abs light has its own computer your have to get it scanned to clear the codes and turn off the light
Mar 18, 2009 | 1992 Oldsmobile Ninety Eight Regency
Brake light in dash gos on
You have aleak some place, that needs to be addressed first. Was the reservoir completely out of brake fluid? If so air has enetered system and will have to be bled. Always start at the wheel farthest from the master cylinder. Generally it is the passenger side rear. As said fix the leak before you bleed. If you need help once fixed let me know and we can go from there.
Nov 16, 2008 | 1992 Chrysler Lebaron
Dynomax 2000 - 2001 Oldsmobile Bravada Exhaust System Kit 19331 Olds Logo
582 people viewed this question
Top Dynomax Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Dynomax Measuring Tool and Sensor Expert? Answer questions, earn points and help others
