What is causing a pinkish vertical line on left side of screen while playing?
techman
  • 3130 Answers
SOURCE: Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Posted on Sep 26, 2006
  • 163 Answers
SOURCE: Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Posted on Jan 17, 2008
  • 280 Answers
SOURCE: fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Posted on Jan 30, 2009
SOURCE: screen display is flipped
I simply turned my television off while emailing fixya and reading the user's manual. The television was turned off for about ten minutes. I think what happened was that the dvd skipped while ejecting and caused the screen to flip....who knows, I'm just happy it works properly again because I love to watch movies.
Thanks anyway,
Brett
Posted on May 18, 2009
SOURCE: Vertical colored lines on left half of screen.
I had this problem on a 37" Viewsonic LCD. Pulled it apart and through a process of elimination, I traced the problem back to a small board with several flat white ribbon cables coming out of it. The board was near the top center of the screen and under a ton of other equipment requiring almost a total disassembly.
This small board was clean but I noticed one of the rubber standoffs had slipped down and was making contact with one of the outputs running to the LCD. It also happened to be the output running to the section of the screen with the problem.
I postulated that the sticky glue on the rubber standoff may have just enough conductivity to cause a problem. Moved it so that it was no longer touching anything electrical and then reassembled the TV.
Afterwards, I turned it on and was pleased to see the problem has gone away! If you're having the vertical line problem, then maybe this could be your problem too, especially if you have a Viewsonic since it could be a manufacturing defect.
Posted on Mar 22, 2010
Vizio VW46LFHDTV10A vertical lines on either side of the screen. I tapped screen and left side lines disappeared.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Vizio VW46LFHDTV10A 46 in. LCD TV
Screen has vertical line on left side top to bottom,tv turns on when plugged in back lights come on but no menu or display of any kind,no 12 or 24 volts
Oct 14, 2016 | Vizio E422VL 42 in. LCD HDTV
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
TV suddenly has pinkish red vertical dotted lines running down it that comes and goes randomly.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 16, 2015 | Televison & Video
TV has blue vertical lines and no picture
I have a 42" Electrograph plasma and it has a 2" black vertical line on the left side of the screen.
Aug 02, 2010 | Electrograph Systems DTS4230 42 in. Plasma...
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
Screen display is flipped
Thanks anyway,
Brett
May 17, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Have a sony kf-50xbr800 rear projection tv. Has red line definition on many object but particulary on long or far shots. Tried the service menu recommendations d-gm tg v pos and it didn't correct the...
Hi...
I would try the Convergence setup in the service menu ( IF they allow you to do that)
If the internal convergence isnt enough you might have to have the convergence amps replaced
Jan 02, 2009 | Televison & Video
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
