Question about Pioneer Elite PRO-1140HD 50 in. Plasma HDTV
The screen is black. when I cycle through the different inputs, the input display appears for 3 seconds and then disappears. I get a display of "Plasma Display--No Input Signal".
    Top Expert:
  • Pioneer Master
  • 75,599 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Jan 05, 2017
3 Suggested Answers
  • 8 Answers
SOURCE: i connected my hp laptop to my pioneer plasma via
Hello. You have to go into your Display Settings, in your HP Laptop, and chose the Dual Screen/Monitor Setting & make sure you check the "Extend my Windows Desktop onto this Monitor" Box. If you are trying to view your Internet Browser on your TV - you will need to Click on and Drag your Browser to the Right... of off your Laptop Screen and onto your TV Screen. This will take care of your problem!
Posted on Jan 11, 2010
sodeep
  • 3267 Answers
SOURCE: Video input to HDMI 1 stopped displaying. Both
replace the HDMI cable
Posted on Dec 16, 2010
Theatre projector is unable to switch inputs in menu
This is worth a try: Turn everything OFF. Unplug all the inputs from the projector and turn them off too. Next, turn the projector ON and all the input devices ON. Then, one by one plug each input device (already turned ON) into the projector. See if this helps. I have a SONY monitor that supports multiple inputs and a few times this has worked.
Good luck.
Jan 28, 2015 | Sanyo PLV-WF20 LCD Projector
How can I restore the tv picture to my tv combi
Make sure you haven't selected the wrong input using the input or source button on your remote control. You may have to cycle through several choice until you get to TV or Tuner or something similar. Cycle slowly, some TV's take a few seconds to render the picture one you choose a different input source.
Jan 07, 2015 | Televison & Video
I bought an LCD Samsung 3 years ago and about a year ago a thick black line appeared in the middle of the screen. Can this be fixed at home?
check if the lines appear on different inputs or source like hdmi,av,pc, if it happens on a different source then theres a problem with the lcd screen it needs to be fix.
Dec 26, 2014 | Samsung Televison & Video
I have a no signal prompt on my jvc flat screen, the Verizon fils box is working, how do I fix it?
Make sure you have selected the correct INPUT. Many TVs have several from which to choose. Locate the INPUT or A/V button on the TV or remote. Press it once and wait up to 3 seconds to see if the picture appears. Repeat to cycle slowly through all inputs until picture appears. Some TV / remotes have buttons labeled AV1, AV2, AV3, etc. or similar do go directly to the specific input as opposed to cycling as above. Press each - one at a time - and wait up to 3 seconds for picture to appear.
If unable to display a picture, check A/V cables at cable box and TV. Note which input is being used on the TV for the cable box. Then select the same AV input on the remote that is being used on the cable box.
If still no picture, contact cable company / Verizon for service.
Jun 26, 2013 | Televison & Video
I have a apex 32-inch tv model (AT3208S), This tv was connect to a converter box, the other day electric power went out in our area for about 8 mins or less, once the power was back on the tv screen was...
OK, I have one of these TVs, and here's a thought: There's nothing wrong with the TV nor with the cable converter box. Please bear with me. Since I don't know how much you may know about TVs in general and this one in particular, I'm going to assume you know nothing and go from there.
This TV has several different "inputs", which are ways a signal can be transferred from its source to the TV, where it "outputs" the video image. I believe this particular TV has 5 different inputs: In descending order of the quality of the video signal, there're one S-video input (a 4-pin video connector plus red & white audio), three composite video inputs (3 connectors each: yellow video and red/white audio--audio connectors are the same for both s-video and composite), and one coax connector (a single large screw-on connector with a little wire sticking up through the center of it) for a total of five different inputs.
The problem with these Apex TVs is that they always default to the Antenna/coax input first when they are restarted. Most people use the TV to display an input signal (like the cable box or a DVD player) connected either to the S-video or to one of the 3 composite video inputs, not to the coax input, which just displays the channel numbers from 1-125 when it's set to do that (hit the "display" button on your remote to toggle showing the channel numbers for the coax input). If there's no signal coming into the coax input, the screen with appear blue. (If it's blue, it simply means it's not getting a signal via the input to which the TV is currently set. You can turn off the blue screen in the menu settings, but then you'll just get a blank screen. It's probably better just to leave the screen blue; at least you can tell the TV's actually trying to display something that way.)
You have to manually select the proper input by pressing the "video" button either on the remote (lower right corner) or the "video" button directly on the TV (hidden control panel under the middle of the margin around the bottom of the TV screen. You'll have to press on the door, and the whole control panel rolls open to reveal another set of composite inputs and some buttons. The video button is the one farthest to the left.)
Anyhow, by pressing the video buttons, you'll cycle through the various inputs. Assuming your cable converter box is functioning properly, powered on, receiving a signal from the cable company, and connected to the TV via a(n) appropriate wire(s) connected correctly, you should see the output from the cable box on the screen when you cycle through to display the proper video input.
Another possibility: the power outage fried the input to which your cable box was connected on the back of the TV. If that's the case, your cable box would probably also have sustained damage. You can check to see if the various video inputs on the TV are working by connecting different source inputs (like a BluRay/DVD/VCR player, video game console, video camera, etc.) to one of the other inputs and see if you get a picture when the TV is set to the appropriate inputs. (Remember, the "video" button is what selects/changes/cycles through the various video inputs.) One of the sets of inputs went bad on my TV. I just use the other ones.
May 18, 2011 | Televison & Video
KDL-32S3000 Problem. We broke remote, so got a new one coming. However, The screen will be normal for 15 seconds or so and then a black bar will appear at top. On the left top of the black bar it will...
its asking you to adjust power on the main power box it sould be under power saver adjust level it to low it should be in your menue and then your main power setings.
Feb 06, 2011 | Sony Televison & Video
I am using this monitor with our CCTV system, it is not currently displaying the video. As I cycle through the inputs the video image will display for about 3 seconds before disappearing.
Hello there,
ok so if i understand this problem correctly you have a Monitor connected to a DVR for a CCTV System, when cycling through the inputs on the Monitor you find the correct input for the CCTV system but the monitor only stays on this input for a few seconds .
sounds like the input is going out or the Monitor is programed to stay on a single Input, I would try both move the CCTV System to another Input on the Monitor and if that fails see if the Monitor has any Pr-Set settings then you can Default .
if you need any Help with the Default let me know and i hope this information was helpful don't forget to Rate.
Jan 27, 2011 | Bosch MON152CL (Black) 15 inch LCD Monitor
Mitsubishi WD-62525 Input 480i
it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
JVC Screen problem
using your remote ,off the close caption. the black rectangular box that you see for the message but since you have message in the box. that why you see a rectangular black screen.
Jan 09, 2008 | JVC AV-32D305 32" TV
Pioneer Elite PRO-1140HD 50 in. Plasma HDTV Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
