Question about Tablets & eReaders
I see on the screen is a android on it's back with door open red warning sign and underneath that it states... no command... how do I get out of this mode?
  • 74 Answers
Just try to do a hard reset. i think it can get back normal
follow this procedure.
1. switch the tab off. after,
2. long press power button + volume down key simultaneously.
3. after it shows the logo then release the power button but continue pressing the volume key until the wipe or reset menu appears.
Posted on Apr 06, 2015
How do i unlock my nexus 7 when its on the screen with android robot laying on its back?
Android robot laying down with a red triangle having an ...
https://androidforums.com > Forums > Featured Forums > Android Lounge
Mar 24, 2013 - 14 posts - ‎7 authors
Whenever i try to turn my android tablet on it displays android robot laying ... an exclaimation mark in a red triangle and dont let me proceed to its desktop . ... and holding it until it turns off and then turn it back on can revive it, ... no command error ' Android Forums
19 Jun 2014
HELP-Tried Recovery Reboot, Red Triangle w ...
15 Jan 2012
More results from androidforums.com
SOLVED: android guy on his back - Nabi Jr - iFixit
https://www.ifixit.com/Answers/View/349279/android+guy+on+his+back Oct 31, 2016 - my android guy on the screen is laying on his back with the stomache door ... Android recovery mode" and a few seconds later an Android robot ...
How to Fix The Dead Android and Red Triangle Error Symbol - YouTube
? 1:44
https://www.youtube.com/watch?v=58EPvbwPbe0
Oct 5, 2016 - Uploaded by Gauging Gadgets
Meaning of Green Android laying down and a red triangle with an exclamation point inside it: •If there is ... All ...
How to Fix The Dead Android and Red Triangle Error Symbol Android Recovery...
Jul 07, 2017 | Tablets & eReaders
RCA android from staying between the initial screen and then to the green android imoge screen that states no command and has a triangle with exclamation point. How do I fix this?
Most likely this is because you accidentally set your phone into a broken recovery mode state of some sort. Although I am not clear on the exact issue, you should be able to simply fix your device by taking the battery out and putting it back in. If that doesn't work, try holding the volume up button for 15 seconds and then pressing the power button. Otherwise, the only solution would be to reflash your device. Is the screen you have like the picture below?
Jan 11, 2016 | RCA 8" Android Tablet w/Dual Tuner
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
I tried reseting it cos it was telling me my firmware was corruped. after reset, i powered on and i came on! but the only screen that apper is the welcon screen and nothing more. so i treid hardreseting by...
So sorry to hear/read about this challenge you are having.
You've provided a few details to help you out; so also is it that you've probably left a few otter details out too.
First, the android logo which appears... is it lying on its back with its tummy open and a 'no command' writing also displayed?
Or is it simply the android logo ONLY.
In any case, once you do the hard reset and the android logo re-appears, try and pushing either the volume up or volume down button.
Next, check and see if it now displays the various command options on the screen.
Otherwise, when the android logo reappears, you can try press one of the following 'home button' or 'back button' or 'opened tabs button' and see if the reset menu/command options become displayed.
Oct 03, 2017 | PANDIGITAL Novel white
Sanei a76 tablet more pattern lock attempt. how to remove unlock my tab please help.
Here is the trick to unlock your Sanei 76 tablet pattern and Gmail :
1) Download Android SDK and install Drivers
2) Open ADB in Command Promt (cmd)
eg : my adb file is stored in this directory
c:\android sdk\sdk\platform-tools\
so to open adb inside this director i use the command
cd c:\android sdk\sdk\platform-tools\
7ac56502-9b5e-40ad-a42e-02deb0a64701.png 071aa9ed-d87b-43b7-aaf9-a53a9c9c27c3.png
3)type the command adb devices to check wether your device/tablet is connected to your PC
(if your device is connected you will get some thing like this : 727ab014-596a-4066-9df4-dbb8eb522e6a.png
4) Then type the command adb shell.
you will get some like shown below
5)if you got symbol rounded in the above screen shot download this file and run it.(if your device is not rooted)
http://downloads.ziddu.com/download/23715300/root.rar.html
6)The type su in adb shell
you will get super user privilages
7)Then type the command below
wipe data
8)the type command reboot
9)Now you are done you are successfully removed your Gmail and Pattern lock.
Oct 06, 2013 | Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
