Question about Apple Ipad I-pad
Had to re set and lost everything again this is the third time this has happen
  • 3 Answers
Yes a reset will loose you everything, if you need a hard reset try holding the front button down with the main on off switch at the same time for around ten seconds this normal fixes things without removing your apps
Posted on Apr 07, 2015
Www urcsupport com
Does your TV have a "half-mute" setting:
* press MUTE once to reduce the volume to 50%
* press MUTE a second time to reduce the volume to zero
* press MUTE a third time to restore the volume to 100%
Jul 01, 2013 | Televison & Video
Sony DSC-W320 says "no space on memory card" even though it's completely empty
The problem most likely is caused because you are deleting EVERYTHING. Next time, instead of deleting everything, format the card in the camera instead.
May 13, 2012 | Sony Cyber-shot DSC-W50 Digital Camera
I lost all of my radiator fluid today. This is the third time it has happened. It did not happen until we got to our destination and parked and shut off the car. The last two times I refilled the tank...
You need to check the engine oil level for coolant
Also make sure you have no external coolant leaks anywhere
I suspect that the head gasket may be letting coolant into the exhaust
I wouldn't be too concerned about the thermostat if it isn't over heating
You got a bigger issue with the lost of coolant
Jul 02, 2011 | 1997 Mercury Sable
I nedd to set the time and dont have my book
Pull the crown in 1st position. turn it cw and ccw. see what happens. now press the buttons one at a time. see what happens again. now pull the crown in 2nd position and again turn it. observe. push the buttons again. see what happens with your watch. you should figure out what everything does on yourself without needing a book. good luck!
Mar 01, 2011 | Casio OC-500 Oceanus Watch
Lost my manual for the NP 105CR Model Next Play IPOD Dock cube. Can't figure out how to turn off a radio alarm which comes on at odd times.
The Alarm is controlled by the Set button. Press Set once, then press Function to cycle through Alarm 1 functions until the display reads OFF. If needed, press Set again, and press Function until Alarm 2 also reads OFF. Press Set a third time, and you can set the main time with the Vol +/- (minutes) and the Skip (hours) buttons. Press Set a fourth time to return to normal display.
Dec 21, 2009 | Starlite Next Play Clock Radio with iPod...
My Palm Treo 600 is stuck on and frozen in the camera position. Usually I would get a paper clip and stick it in the reset hole on the back and it would reset allowing me access to all functions of the...
Hi elg
There are many ways to reset your Treo, here are some from Treo KB themselves...
# How do I perform a hard reset on the Palm Treo 600?
Warning: A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything.
HotSync note: Some third-party applications change the way your handheld backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
1. Hold down the power (on/off) button on your device.
2. While holding down the power button, turn over your device so that you can see the back of it.
Using an unfolded paper clip or a similar small object, gently press the RESET hole on the back
3. When the device's screen displays the Palm Computing Platform logo, release the power button.
4. A message will appear warning that you are about to erase all the data stored on your handheld.
In response, do one of the following:
* Press the UP button to complete the hard reset, erasing everything on your device
or
* Press any other button to begin a soft reset, leaving your data intact.
5. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Note: A hard reset does not reset the current date and time. It does restore other settings to the factory default.
Back to top
# How do I recover after a hard reset?
If you backed up your data by synchronizing it to your desktop computer, you can restore it now by performing a HotSync operation.
1. Since all data was erased by the hard reset, first synchronize your device with your desktop computer.
1. Make sure your conduits are turned to "Synchronize the files" or "Desktop overwrites handheld". Do not turn conduits to "handheld overwrites desktop". This will erase data on your desktop computer, and you won't be able to transfer it to your handheld.
Note: Data restoration may take some time. The HotSync operation will be faster with a USB connection, slower with a serial or IR connection. You won't be able to perform a network HotSync connection until you have performed at least one successful 'local' HotSync via USB, Serial or IR.
Re-install third-party software, if any.
2. Third-party software (applications, hacks, themes, games, databases, eBooks, etc.) might not have transferred back to your handheld during a HotSync operation. Locate any missing original .prc or .pdb files on your desktop computer, and double-click the files to re-install them. For more information on how to install third-party software, visit the Palm Support Knowledge Library.
Caution: Sometimes, the reason you needed to perform a hard reset was because of third-party software. While we encourage users to take advantage of the thousands of third-party titles available, we cannot guarantee that the third-party software will be compatible. If you recently installed software and then experienced a problem, maybe you should not re-install that software. For more information on how to diagnose third-party issues, visit the Palm Support Knowledge Library.
Re-set your preferences.
3. The System conduit restores your preferences for display, menus, auto-off, and other functions. However, if there are other preferences (such as those set within third-party themes) that haven't been restored, now is the time to do so manually. Refer to the third-party software documentation for instructions.
Back to top
# How do I perform a Battery Disconnect Reset?
A battery disconnect reset is a last resort step you can take to cut battery power, wipe out all data, and bring a Palm Treo 600 back to its factory-fresh state.
A battery disconnect reset will erase everything on your device, and also reset the wireless radio and disconnect the internal battery. All your data will be removed, and your formats, preferences and other settings are restored to their factory default settings. Don't perform a battery disconnect reset unless you've backed up your data, or you're willing to lose everything.
Additionally, you won't be able to turn your Palm Treo 600 back on until you connect it to a power adapter, so do not perform this type of reset if you're not near a power source and your Palm Treo 600 charger.
HotSync note: Some third-party applications change the way your handheld backs up data, while other third-party applications do not back up data at all. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
1. Disconnect your Palm Treo 600 from the AC charger.
2. Hold down the K and Backspace keys simultaneously.
3. While continuing to hold down the K and Backspace keys, press the RESET button inside the hole on the back panel of your device.
* Note: Palm made this type of reset very awkward to perform, so that it would not happen by accident when your Palm Treo 600 is jostling around in a pocket or bag. Sorry for the inconvenience. You might want to enlist the help of a dexterous friend if you find it too difficult.
4. Continue holding down K and Backspace. The screen will flash white briefly, and then go black. Release K and Backspace after this happens.
5. To revive your Palm Treo 600, connect it to the AC charger and plug the charger into a socket. The screen will stay blank for several seconds (as long as half a minute), then it will turn on. The LED will glow solid red, indicating charging.
6. Finally, follow the steps for recovering after a hard reset (a battery disconnect reset is a type of hard reset).
here are the links:
http://support.vzw.com/devices/palm_treo_600_smartphone/faq.html#item15
http://kb.palm.com/wps/portal/kb/common/article/887_en.html
http://mytreo.net/how-to-guides/hard-reset-the-treo-600/
regards,
voodoo
Jun 11, 2009 | Cell Phones
Treo frozen with Treo logo on screen
  1. Hard reset:
  2. Press and hold the Power (on/off) button on the front panel of your device.
  3. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  4. If you see a progress bar (see below), keep holding the Power button.
  5. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  6. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
HotSync note:Some third-party applications change the way your device backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 22, 2009 | Palm Treo 700p Smartphone
2yr old DLP TV flashes for few mins then has red tinge
Push the menu button when the problem shows up again. Please tell me if the flashes show up in the displays as well on the menus. I can take it from there.
Apr 15, 2008 | Mitsubishi WD-62927 62" HDTV
Apple Ipad I-pad Logo
83 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
