Question about Toshiba Satellite M40-S417TD Notebook
Won't startup i shut down the computer at work.Now i want to turn it on.i see the LED is on but i can't see or hear any activity on screen for booting.
  • 71 Answers
Re: won't startup
Try removing the battery and the AC adapter from the laptop and press the power button a few times. This should drain any remaining power from the laptop. Now plug in the AC adapter and try turning it on.
Let me know what happens,
Posted on Nov 14, 2007
0 characters
3 Points
Latitude D830 starts then shuts down quickly.
1. Make sure you are plugged into A/C.. Your battery could be running low.
2. Make sure there is nothing blocking the heat vents. This symptom is typical for overheating processors.
Mar 17, 2013 | Dell Latitude D830 Laptop Computer PC...
15.4-inch macbook pro A1286 turn on but wont start
  1. Verify startup process passes initial memory checks and POST (Power On Self-Test) with no beeping sounds or flashing sleep LED. Check video activity.
  2. Disconnect any peripherals and Ethernet cable.
  3. Reset SMC using the procedure for your computer.
  4. Reset PRAM by holding down Command-Option-P-R keys while restarting, until you hear the startup sound for the second time.
  5. Start up from known-good original system media or an up-to-date, bootable Mac OS X volume.
  6. Run Disk Utility or check Mac Resource Inspector (MRI) results to verify SMART status of the your hard drive.
Jul 31, 2012 | Apple PC Laptops
Error why coming
Can you hear any fan or drive sounds? If you don't hear anything at all when you try to turn the laptop on, no little LED's light up, the problem almost certainly isn't related to the hard drive. So if you don't have a live screen, start with the LCD troubleshooting flowchart, and if you don't have any activity at all, start with the power troubleshooting flowchart. Even if the hard drive has failed at the electro/mechanical level and won't spin up, this wont prevent the LED's on the laptop from lighting up, or the LCD from displaying the BIOS information and complaining about the lack of a boot device.
Ford F150 Body Kits
Jun 07, 2012 | PC Laptops
Tecra A10 won't boot up. Laptop was dropped when running and froze. Shut it down to reboot but doesn't work at all. When the power button is pressed, the HDD LED illuminates for just over a second and then...
I suggest try going to Local Computer Centers, Have them check what hardware's are having problem, most likely there are problem with LCD, Motherboard, HDD.
Apr 21, 2011 | Toshiba Tecra A10 Notebook
Fan shuts off on computer startup, led lights are
The fans are USUALLY controlled by the processor chip reading its internal temp and running fans as needed. Under the varying load during boot, it is not uncommon to have fans starting and stopping..
Nov 30, 2009 | HP Pavilion dv6000z Notebook
Activate windows screen and then says my windows is activated
the obvious question:
is your windows legit?
if it's not you may have a corrupted windows copy, download another copy or buy one in ebay (they're getting cheap).
if it's legit. you have may have a hardware problem so more details may be required.
1. are you doing a clean install, any errors while files are getting copied?
2. do you have hardware that did not come with your computer installed or connected, make sure you disconnect everything and as your computer starts working, reinstall and test 1 piece of hardware at a time.
good luck
Nov 22, 2009 | HP Compaq Evo n800c Notebook
The Startup repair program is running and wont stop
A complete scan can take several hours to complete. If you want to shut it all down unplug it and remove the battery. Leave the battery out for at least 10 minutes, and until it cools down.
Nov 04, 2009 | PC Laptops
Computer windows will not come up
Try This:
To repair your computer using Startup Repair follow these steps:
  1. Boot into Vista installation DVD
  2. Choose your language settings and click Next
  3. Click Repair your computer
  4. Choose your operating system and click Next. This should bring up System Recovery Options.
  5. Click on Startup Repair
Startup Repair should now start diagnosing your system to identify the root cause of the failure. Once it has identified the root cause, it would automatically start repairing your computer. If you are curious to know what Startup Repair did, you can click on the details link and see which tests Startup Repair ran to diagnose the problem.
After Startup Repair has finished the repairs, click Finish to reboot your computer.
Your computer should now be able to boot normally into Vista!
Feb 20, 2009 | Acer Aspire 5500 5570-2609 Laptop
Compaq notebook won't boot up
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
May 19, 2008 | HP Compaq Presario V2000 Notebook
Toshiba Satellite M40-S417TD Notebook Logo
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
