Question about GPX 32" Thin LED Full 1080p HDTV with Built-In DVD Player
I'm trying to program my comcast remote so the tv turns on when my DVR turns on
TDE3274 v 1128-01
Need a code for my Sony RM-Y16 Remote to split screen with my Comcast DVR
It is possible that this remote will not program to your Comcast dvr. Your DVR is probably newer than the remote and has new codes that the remote doesn't support. The only thing you can do now, is either purchase a new universal remote that supports both units. or use your Comcast remote to program it to your TV. the Comcast remotes are programmable.
Oct 07, 2012 | Sony RM-Y916 Remote Control
I have a JVC tv with a Comcast DVR. Remote provided will not work on DVR.
did you take a look at the manual you should have recvd for your comcast remote control, You need to program your DVR, look in the manual for the 4 digit code and follow the instructions- usually- hold the dvr button on the remote down until it stops blinking- enter the code- (depending on who the manufact is) wait for the button to start then stop blinking, see if that helps
Feb 07, 2012 | JVC Televison & Video
LG LHB953 Theatre system volume control with comcast dvr 3
Try the help menu in the comcast remote. I believe you have to program it again for the LG to work the sound.
Jan 01, 2010 | Televison & Video
Remote doesn't control. batteries are good, but there is no apparent connection between the remote and the TV. It is in use with a Comcast turner-DVR, which works fine, but I have to turn on and adjust...
Are you using Comcast remote to control the TV? When you program the Comcast remote to control your TV, it will do two functions: on/off, and Volume control. The Comcast can also be programmed not to control the volume of the TV (TV volume will have to be set at about mid level manually, then the Comcast box will send out variable sound level to the TV), just on/off ONLY.
Oct 27, 2009 | Olevia 227-S11 27 in. LCD TV
Comcast DVR 3 Remote doesn't work with TV
You may have to use a separate remote control for your TV.
Jun 05, 2017 | Emerson Televison & Video
Need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
Jan 03, 2009 | Philips 47PFL7403D 47 in. LCD TV
Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Dec 13, 2008 | Samsung LN32A330 32 in. LCD TV
Progamming Comcast remote
Go here, it has a viewable manual for the comcast remote and a list of codes. There is also a way to search codes listed. Haven't tried yet, but it can't hurt trying!
http://www.scribd.com/doc/202024/comcast-dvr-remote-manual
Sep 08, 2008 | Sanyo DS20930 20" TV
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
GPX 32" Thin LED Full 1080p HDTV with Built-In DVD Player Logo
115 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
