If the 3 point lowering levers are next to the seat the lever closest to the seat should set the draft after lowering the hitch...Outside lever is up and down...Inside lever should be draft after lowering hitch.....Levers should be side by side after lowering
www.tractorsupply.com/tsc/.../3-point-equipme... Tractor Supply CompanyTSC has 3 point tractor disc, trechers, forks, attachments and implements for sale every day. ... modern farming as much as the adoption of the three-point hitch.3 Point Landscaping & Utility ... - 3 Point Cutters & Hay ...
You need to put your hydraulic pump in gear and the lever that runs the hydraulic outlets will run your rockshaft it might not go down if there is no load on the 3-point.
I think a 140 is a IH Cub . I don't believe they had available a 3 point hitch. Please register at www.farmallcub.com and there are people there that have had a 140 apart and back together many times. IF there was a 3 point hitch available they will know about it. GOOD LUCK Mike
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
