Question about Samsung Hmx-f80 Flash Memory Camcorder Silver
Won't come on.
Used 2 or 3 times for a few minuets is all. Charged the battery , installed , and nothing. Battery is good , tried on another camcorder and it worked.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
May be this video can help...
Posted on May 05, 2015
  • Anonymous May 05, 2015
    and where is the video
Boat motor won't start. battery fully charged
I would have the battery tested anyway to make sure you don't have a dead cell. Usually even with a weak battery the starter will try to engage the flywheel on top of the motor.Besides the battery check the fuse located on the motor. If all is good then you can remove the starter for testing and possible rebuilding.
Jul 07, 2012 | Nitro Boating
I have received as a gift a Canon FS300 Digital Video Camcorder . The first time I used it, I followed instruction on how to charge the battery with CA-570 Compact Power Adapter which was included. It wok...
Hi!
Almost sure there is nothing wrong with your battery, charger and camcorder.
The battery loose power even when doing nothing, especially when it is a NiMH type.
Please charge the battery for a couple of hours and try again to start the camcorder.
Aug 09, 2011 | Canon VIXIA FS300 Flash Media Camcorder
Will not turn on with good battery.
Can you not detach the lead to the charger unit, and plug that directly to the camcorder, to see if its the actual camcorder at fault ?
Near the camcorders power socket, you should see a small picture telling you what power the cam uses - usually around 7 volts, centre positive connection jack plug, at around 900mAh. As long as you get the voltage close, and have enough amps behind it, it will still work safely.
Camcorders are rarely fussy about the exact voltage, but you should never go above 9 volts unless its needs more. Most take the internal power down to 5 volts inside anyway.
The batteries do have a tiny non-replaceable internal fuse, triggered by voltage spikes or overheating, and if that goes, it usually means buying a new battery :(
Batteries can go at any time from the very first second they are used. I've bought many, and had a few that didn't last 2 months from brand new. One high-end type lasted over 9 hours on its very first charge :) and then never worked again after that :(
Apr 03, 2010 | Canon ES8400V Camcorder
Camcorder will not turn on without being plugged
If the camera is turning on and is able to be used normally while plugged in to an AC wall pack, but not using the battery, there is probably a problem with either the battery or the internal power switch to go from AC to battery.
Check the battery with a voltmeter to insure you have a fully charged battery. It would also be a good idea to use the voltmeter on the camcorders power tabs to make sure the camcorder is passing the correct voltage to the battery. The amount of volts should match the volts on the battery.
If it's a battery issue, batteries plus has a replacement for this camcorder. If not, it's a switch within the camera (software most likely) and there's not much you can do other that try to reload the camcorders firmware if it is available fromt eh Insignia-Products web site.
Hope this helps!
Feb 08, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Fully charged battery in and it only lasts few minutes
you have to buy lithium battery's or lithium rechargable's. that camera should of came with lithium battery's did you get it used? and it should take usb.
Jan 02, 2010 | Sharp Viewcam VL-AH151U Camcorder
Electrical - vehicle will not start
It sounds like you have a bad battery. Some times when the battery is bad and you try to jump the car you need to let it charge for 10 or 15 minuets before you try to start it. Or better yet take the battery out and have it charged and tested. I'm betting the battery is toast.
May 03, 2009 | Chevrolet Sportvan Cars & Trucks
Camera eats batteries in 2 minutes!
Sorry to hear that you have problem with the camcorder. It does have few situations with not charging battery based on our repair experience. I would suggest to make sure the battery is fully charged and see how it goes. If there's any battery problem, you should send it to Sanyo for manufacture before the warranty expires. Makes sure send every thing back to Sanyo. Battery problem cannot be solved simply other than bad battery contact situation. -James
Apr 12, 2009 | Sanyo Cameras
No power to camcorder even when battery is fully charged
1. replace a good battery to check the battery is full really.
2. check the battery is installed flawlessly.
Mar 11, 2009 | Hitachi DZ-HS300A DVD Camcorder
Canon dc100 wont swich on
The camera seems to have these problems, and I think its because the power switch is on when the camers is being charged.
Sep 11, 2007 | Canon DC100 DVD Camcorder
Samsung Hmx-f80 Flash Memory Camcorder Silver Logo
278 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
