Question about Refrigerators
Refigerator making ticking noise - Refrigerators
  • 2,355 Answers
Could be the fan blade hitting something
Posted on Apr 07, 2015
Hi I turn the heat on in my 06 dodge magnum I hear a ticking noise then goes away now no ticking noise and no heat
Could be your blend door getting stuck thats making that ticking noise. Check your heater hoses to make sure they are getting hot. Check with caution theu may be very hot.
Jan 02, 2016 | Dodge Cars & Trucks
Tapping noise in engine
What's That Ticking Sound Coming From Your Car's Engine?
www.popularmechanics.com/.../whats-that-ticking-sound-coming-from-...
Apr 18, 2014 - My engine has developed a strange ticking sound. Its whisper-quiet before an oil change, and then makes a loud tapping after a new filter and ...
Engine Tapping - Auto Repair Help
www.auto-repair-help.com/auto_diagnostics/engine_tapping.php
ENGINE MAKES TAPPING NOISE WHEN STARTED by Mark Davidson. SYMPTOM SUMMARY The engine emits a tapping noise on start up. The noise may ...
Engine Ticking Clunking Noise - Repair - YouTube
? 9:37
https://www.youtube.com/watch?v=ilDtnJi_BS0
Mar 15, 2013 - Uploaded by knurlgnar24
One of my vehicles started making a rather disturbing sound so I went to investigate and to hopefully fix it.
Dec 02, 2015 | Cars & Trucks
ELECTROLUX American Fridge Freezer making a ticking noise
Hey Jantoye4, thank you for your inquiry!
Based off what you have described your Electrolux freezer is making a ticking noise. This could be from your compressor or condenser. Additionally, you may hear this noise due to your defrost cycle. If you continue to experience the noise more or have another problem I would recommend contacting a professional technician for proper diagnosis and repair. Best of luck! -Matt
Feb 26, 2015 | Electrolux Refrigerators
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
Funny noise coming from the air filter
probably bad ice maker
http://www.shopjimmy.com/
Sep 06, 2012 | KitchenAid Refrigerators
My hyundai elantra keep ticking wat can i do to stop the noise
A "ticking" noise can be caused by several things. First thing to check is the oil level. When an engine is low on oil, there's a lack of lubrication and you will hear the lifters "ticking". Some cars make a "ticking" noise with the AC on. The ticking is the compressor kicking on and off.
Jun 21, 2011 | Hyundai Elantra Cars & Trucks
Leibherr Refigerator is making a constant noise
What sort of noise are you refering to. If it's a whining noise or a screech, check the fan motor. try spraying a little WD40 on the shaft. sounds like a dry front bearing. better still replace the motor.
May 17, 2010 | Liebherr KIKNV3056 Bottom Freezer...
I have a 1998 GMC k1500 and it makes a ticking noise eveytime u step on the gas?
WORN PISTON RINGS MAKE A TICKING NOISE.VALVE LIFTERS MAKE TICKING NOISE.WORN DISTRIBUTOR SHAFT BUSHINGS MAKE A TICKING LIKE NOISE.
Oct 29, 2009 | 1998 Chevrolet K1500
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
