My phillips tv model 60pp9100d/37 has no sound or picture except for the words "Weak signal" running across the screen....can anyone advise me what might be wrong. ..
    Genius:
  • 1,181 Answers
Antenna loose or cable disconnected or if running from cable box on wrong channel
Posted on Apr 06, 2015
Arpi
  • 326 Answers
SOURCE: Phillips model 42PF9631D/37 Plasma TV PIP Setup
Hello, please try this link: http://www.p4c.philips.com/na4/4/42pf9631d_37b/42pf9631d_37b_dfu_aen.pdf Best regards, Arpi
Posted on Jun 17, 2007
  • 138 Answers
SOURCE: Phillips TV- Plasma Model #42PF7220A/37
A tech will need to come out. When the tech do come out have him unplug the Y main and see if the led goes solid greem if it does have them replace the Ymain and the Y upper/lower boards. Most likely that will be the problem.
Posted on Aug 20, 2008
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
SOURCE: Hi, I have a Philips model 37PF7321d/37, 37 inch
The power board numbers you need to search for on eBay is 310432847531 or 310432838621 - they are compatible according to Philips.
Posted on Nov 05, 2009
SOURCE: screen is black but we have sound
The problem is a faulty inverter kit (2 boards).
I live in the Netherlands and had it twice, tv is 2 and a half years old! In the Netherlands Philips replaces the inverterkit without any
costs for the consumer (even after warranty time) cause they have
admitted that it is a production fault.Philips made a new inverterkit
which should solve the problem indefenit.Be sure the kit is Version
1.3! I had 1.2 after the first problem, and that went wrong after 7 months again. Today got revision1.3 installed which is Philips final solution.
Posted on Jul 21, 2010
Testimonial: "Thanks very much for your help. I will contact Phillips Ireland and see what they can do.Thanks again"
Phillips 37PFL5332D/37 I have a blue power light but no picture, sound or anything. Please advise?
When tv power on.U have a solid LED green or red power light incadication?Yes,than 100% ur tv Tuner signal board is the problems and the causes.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 13, 2011 | Philips 37PFL5332D 37 in. LCD Television
Grey lines
this a vertical circuit, and HV Circuit Defective, send to repair
Jan 15, 2010 | Philips Magnavox 27MS343S 27" TV
Philips 60pp9100d/37 convergence issues
Did you replace the 6.8 ohm 1watt resistors? As that model will usually blow a couple when the ICs fail.
Apr 21, 2009 | Televison & Video
Phillips Model 60PP9100D/37
Its a common problem on this model. Most likely the HVG. Goto www.TvRepairKits.com for a kit with instructions.
Apr 19, 2009 | Philips 60PP9200D Television
Phillips 50PF9431D/37: Perfect Picture, inuadible audio
The audio or sound IC (integrated Circuit) on the TV panel maybe bad and need to be replaced.
Also, the speakers of the TV may have a weak connection from inside the panel.
But my best bet is the first solution i gave. If u are not a qualified electronics technician then take it to a service centre.
Joseph Asoh,
Abuja, Nigeria
Mar 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
Durabrand TV/DVD dct1481
The blue screen is fairly common and is displayed when inadequate signal is present.
In other words, 'no reception.'
The weak BBC1 signal is kind of a confirmation of your poor signal strength.
Aug 20, 2008 | Durabrand DWT1905 TV
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
PHILIPS TV MODEL # 60PP9100D/37
check your speakers, your cables going to speakers and try to use a headset, if you hear sounds in your headset the problem is your speaker .
Mar 08, 2008 | Philips 60PP9352 60" Rear Projection...
NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
check the wires inside at the left lower region as you are looking at the rear. There are several circuit boards there that tend to loosen when moved. The cables are really ribbons like those used in computers.  I'd lioke to be more specific however I'm not entirely familiar with this model, just rear projection tvs in general.
Sep 05, 2007 | Philips 60PP9200D Television
Open Questions:
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
