Question about Dryers
Not all the light bulbs are lit. How could I fix this?
    Genius:
  • 1,617 Answers
Make sure the tab inside the socket is touching the bulb. Also use the correct wattage.
Posted on Apr 07, 2015
98 lesabre left flasher indicator stays lit with the lights on replaced the flasher unit did not fix the problem all for of the lights flash when you turn the hazards on
this means you have a bulb burnt out somewhere on the left side. as long as you mean it stays lit when the lights are on only
Oct 29, 2014 | Cars & Trucks
Brake/Signal Lights Problem.
Sounds like a ground problem to me. Bulbs are not getting there ground to complete the circuit so they backfed through the other bulbs.
Oct 23, 2012 | 1998 Acura RL 3.5
My right rear turn signal and brake lights dont work but the lights are lit what do i need to do to fix this
IT SOUNDS LIKE THE BULB IS BAD! THE PARK LITE SIDE IS WORKING, BUT THE HIGH SIDE (BRAKE AND TURN) IS BURNED OUT! REPLACE THE BULB!!!
Feb 26, 2011 | 2005 Chevrolet Malibu
I have green light so I know the bulbe is good,
just because the green light is on doesn't mean the bulb is lit. look into the lens from the side--not directly into it to see if it is in fact lit. if it is lit but you have no display, the main board is likely bad, but you can try resetting the lamp hours and reflashing the unit with the most current firmware.
Jun 17, 2010 | InFocus X2 Projector
Control locked light is lit not allowing any operation of the dry
Did you try unlocking it by pressing on the "End of cycle" button for 3 seconds.
If that doesn't solve the issue, it might be the control board (user interface) might have gone bad.
I had the same issue with my GEW9250 and I had followed these steps to repair the board. I am not sure if it works for you, but you can try it out.
Open the User interface control board
Then remove the PCBS (the green control boards)
Check the led bulbs, for me one of them is fried. You can use volt meter to test it.
Remove the bulb(s) that are fried (not working)
That should fix it...
Apr 05, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Left brake light stays on
Usually when your signal blinks rapidly it indicates a blown bulb.   Switch on your four-way flashers and check your bulbs at each corner.  On the brake light staying lit, check to see if the left-rear bulb is installed correctly and is the correct bulb for the application.  I've seen people force bulbs in sockets causing the braking element of the bulb to light instead of the parking element.  The braking element is much brighter than the parking element.
Mar 17, 2009 | 2000 Jeep Wrangler
Left Signal light isnt blinking on my 2000 300M Chrysler
you need to replace the rear driver side light bulb. it will fix the problem.
Feb 27, 2009 | 2000 Dodge Ram 1500 Truck
Dashboard Lights - "brake lamp" light stays lit/ dashboard bulb for gas gauge burned out
you can remove the cluster and buy the bulb separate as far as the brake light it is either the float is bad in the master cyl. or you have low frt brake pads
Oct 12, 2008 | 2003 Honda Odyssey
Dryers Logo
37 people viewed this question
Top Dryers Experts
