Location of serial number for m42 - Office Equipment & Supplies
  • ray gallant Apr 06, 2015
    Hi danny saunders, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? contact the maker of the unit and ask tech support
    New Friend:
  • 79 Answers
Hi!
If you tell me the printer Model / Brand i can specify to you where you can find the S/N (Serial Number)
ADCSFXworks Printing Center
Posted on Apr 06, 2015
Whereis the location of army m42 duster serial number
Your looking for a serial number for an M42 40 mm Self-Propelled Anti-Aircraft Gun?
Apr 06, 2015 | Cars & Trucks
How to check service tag on supermicro servers
AFAIK Supermicro is not using Service tags like Dell or Lenovo. Instead they go by serial numbers. The location of the serial number depends on the type of the server:
Blade serial number (SBI... or SBA...) is located on the side
Blade Enclosure serial number (SBE...) is located on the rear side
CMM (chassis management module) serial number (SBM...) is located next to the latch
Rack-mountable chassis serial number is located on side of chassis by the sliding rail
4U Tower Chassis serial number sticker is located on the bottom side
Rack-mountable Systems' Serial Number is located at the rear side by I/O panel
Embedded Systems' Serial Number is located on the I/O panel
Check this website for more:
http://www.supermicro.com/support/SNGuide.cfm?sn=ss
Feb 23, 2015 | SuperMicro Computers & Internet
Bmw m42 engine to fit a camshaft sprocket to a camshaft
The M42 and M46 engines have the twin vanos pulleys and require locking tools to lock the crank and cam shafts inot the correct position. There are no timing marks on these as they are floating pulleys- ie they have no key locating the pulley in a specific position on the cam. Unless you make accurate marks during stripping there is very little chance you will be able to get the cam timing right on this engine without the cam locking tool kit.
Apr 25, 2014 | 1994 BMW 3 Series
Where is the model serial number on the Canon MX882
Issue: Where is the serial number located?
Solution: Locate the serial number MX882
Locate the Serial Number The serial number of the MX882 is located inside the printer, as shown below.
  1. With the printer powered on, open the Paper Output Tray (A).
    The above illustration shows a PIXMA MX870.
  2. Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
  3. Wait until the print head carriage moves to the ink tank replacement position.
  4. To the right of the print head carriage, inside the printer, is a white sticker that is attached to a metal plate. The serial number is located on the white sticker. Please see the illustration below.
    The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
May 09, 2011 | Canon Office Equipment & Supplies
Having trouble getting a Celestron Nexstar 114 to locate even guide stars? When I get an "alignment success" then pick an object,say m42 it takes off like it's looking for m42 but just keeps going and at...
Have you followed the instructions in the manual? The first thing to do is setup with the time, date and location, then select a 3 or 2 star alignment method to calibrate. Use ONLY the hand controller to move the scope to the stars.
May 30, 2010 | Meade Infinity 114EQ-DH Telescope
M42 adaptor
Quite right too. When the M42 adaptor is fitted there is absolutely no exchange of information between the lens and the body: M42 lenses pre-date all of those later developments. Your camera will also be unable to stop down the lens automatically when taking the picture, most M42 lenses don't even stop down automatically when connected to an M42 body.
You need to do things the old-fashioned way. Your camera needs to be set to meter manually, shutter priority mode may also be used. In manual mode you focus the lens as normal with the aperture ring set to the lowest aperture number (i.e.aperture is wide open).
You then make sure that the lens in in manual mode as well and stop down to whatever you want, if the image remains bright enough then you can adjust the precise focus using the hyperfocal principle if you like which takes advantage of the increased depth of field of a stopped down lens.
In manual mode, you then tell the camera what aperture you have set (read it from the lens barrel) and set the shutter speed using the camera's light meter to guide you. If using shutter priority mode then the camera will choose the shutter speed for you.
Check everything is set as you intend and press the shutter.
It all sounds long winded but is exactly how many of the world's greatest photos were taken and soon becomes second nature. You also learn far more about the relationship between aperture, shutter speed and ISO settings and will be able to talk about reciprocity like you know about it!
Jun 26, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
About serial key
Details Issue: Where is the serial number located?
Solution: Locate the serial number MP150
topFrame=findTop(this); Locate the Serial Number The serial number of the PIXMA MP150 is located inside the printer, as shown below.
  1. With the printer powered on, lift the scanning unit and pull the scanning unit support down into place.
  2. The serial number is attached to the back wall inside the printer.
    It starts with four letters (JCBA, JCBB, JCBC or JCBD) and ends with five numbers. Example: JCBA01234, etc.
.footergray { font-family: Arial,Helvetica,sans-serif; font-size: 9px; color: black; text-decoration: none; font-weight: bolder; } .footerblack { font-family: Arial,Helvetica,sans-serif; font-size: 9px; color: black; text-decoration: underline; font-weight: bolder; } © 2008 Canon U.S.A., Inc. All rights reserved. Duplication in whole or in part without permission is prohibited.
Jan 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Vivtar 20mm wide angle lens #22100295
This lens was manufactured by Kino (aka Kiron) made in 2001. I will try to find out it's compatibility list and post it here when I have it.
Jul 08, 2008 | Vivitar Super Wide Angle 19mm f/3.8 Manual...
Gateway DC-M42 camera
I have vista but can't get the DC-M42 to load. I have the original disc. Only manual, vista etc downloads...
Jun 18, 2008 | Gateway DC-M42 Digital Camera
k24674
jasbo
jasbo
