Question about Electrical Supplies
Will not charge. Stater is putting out power . Cant read model number on engine.
  • Eugene Rounds Apr 06, 2015
    Hi donwertz, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?What of generator is it? Some generator do not charge batteries unless it is thru an AC charger.
  • 2,992 Answers
Owner's manual? no manual, try both owner's and Repair manual
manualslib.com or MFG website possibly customer service email.
Posted on Apr 06, 2015
Kohler diagram
only thing it can be now is charging stater is bad but dosnt make since its getting power somewhere has to be stater is charging check voltage at stater see if power there if is check relay behind dash see if power there then go to switch see power there this done while engine is running and battery unhooked if no power at switch replace it if motor wont start jump start at starter to get it going if wont start let me know well go from there
Sep 02, 2014 | Garden
Briggs & Stratton engine model # 4455770435E1, need to find out what part number to order to fix alternator? Told our "stater" was bad?
The alternator (P/N 592831) should put out around13-14 volts DC with no load (other than charging the battery. If the voltage drops only when the deck is engaged but not when the lights are on it could be a connection to the mower clutch causing excessive current draw. I suggest covering the fundamentals such as ensure the battery is healthy, ensure all connections are clean and tight before condemning the stator. then and only then would I remove the flywheel to inspect the stator.
Aug 16, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Slow dying battery
you need to have the stater checked and see how much volts it is putting out under normal engine rpm as well as accelerated rpm, it may be time to replace your stater/alternator!
Jul 03, 2013 | 2006 kawasaki ZX-6R
Charging system
Start your engine and take digatal multimeter and ground the black probe and put the red one on the back on the alternators large red wire and read the voltage it should between 13-15 volts anything more or less then you will need to replace the alternator.
Feb 03, 2012 | Cars & Trucks
Power getting to stater but wont crank over
No mention of model...so these are general comments.
First, when you say there is power to the starter, do you mean the actual starter or the starter relay (or starter solenoid). On most Yamahas there is power to the starter solenoid from the battery at all times.....power leaves the relay to the actual starter motor only when the key is on, the interlocks are satisfied and the starter button is pushed.
So if you actually are getting power at the starter motor and no rotation, and the battery is fully charged you have either a starter motor issue or an internal engine/clutch problem. Is the bike physically in neutral ...rear wheel spins? Remove spark plugs and attempt to rotate engine with kick starter if equipped, or access rotor bolt and rotate with socket...if it rotates fine...remove starter motor and inspect,
If the starter relay is not sending power to starter motor....check Kill switch is in ENGINE RUN position, bike is in neutral, and indicated on dash, and retry. If you have no neutral light showing, but it is in neutral, you need to flip the sidestand up...pull in the clutch and retryt....as there is a sidestand switch and a clutch switch that are part of in gear starting interlocks.
No neutral light indication requires testing of the neutral switch aand wiring but tryt to get the bike running first.
Apr 15, 2011 | Yamaha FZ 750 FT (U.S Motorcycles
I put a new stater in and now the car says the volts are too high and to service charging system.. it has a brand new battery too. what do i need?
check the voltage at battery, when car is off it should read at least 13 volts. when running should be 14 to 14.5 if its higher its over charging !
Nov 22, 2010 | 1996 Cadillac DeVille
Cant get it started put stater on
behind your starter you have a crank sensor replace it and it will start i found out the hard way
Nov 09, 2009 | 1996 Pontiac Grand Am
Stater problems
do u need this for a charging issue or a firing issue?
Jun 17, 2009 | Boating
Have No ignition light when in Nuetral.plus wont start
russel just because you have new batt does not it is not faulty or not fully charged have it tested should read 12.7 volts if fully charged. it should not be a fuse or green light would not be on when the bic is running . check batt cables at battery and also at stater solenoid. hope this will help
Mar 24, 2009 | 2003 Yamaha YZ 250
Electrical Supplies Logo
41 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
