Question about Fujitsu fi6670
Scanner is not ready. (Power may have been cycled.)
Unable to scanner due to Scanner is not ready. (Power may have been cycled.)
    Top Expert:
  • Fujitsu Master
  • 51,132 Answers
Unplug it for 10 minutes and try again.
Posted on Apr 06, 2015
Testimonial: "I found out, it was USB port was bad. I use other USB port, Scanner worked.. Thanks."
  • Keith Ho
    Keith Ho Feb 27, 2018
    Tried another USB port and it worked.
"cycle error" - scanner powers up ok but will not scan due to this error ID=055
Error 55: "Lamp I2C error reading from DAC". Operator log message: "Cycle power, if problem persists, call service.". This error is involves communication errors between the LED AY and the DAC. A couple things can be done to alleviate this issue but unfortunately, as a user, you can only perform the first step. The other steps require a Kodak Field Engineer to complete. First step, upgrade your Firmware. Firmware updates can be found at the following web page: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Production/i5200_Scanner/Support/Drivers_And_Downloads/i5000_Series_Scanner_Firmware/index.htm. If you still experience issues following the firmware upgrade, call Kodak Service & Support to schedule a field engineer to be dispatched to your site.
Mar 03, 2014 | Kodak i5200 Document Scanner
Thanks, my HP LaserJet 9000MFP is requesting for cable check it say check cables. check scanner lock. cycle power
This error is an indication that the system is unable to move the scanner. This usually happens on new units when someone forgets to unlock the scanner before switching machine. If the printer has worked up till not and just started doing it then there is a good chance that the scanner has failed and will require service. If you just moved the machine then check the scanner locks and make sure the cabling is all connected.
Aug 09, 2011 | HP LaserJet 9000mfp Printer
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
Scanner error - I've plugged in, reset partial, reset semi, disassembled and cleaned bulbs (both working) and optics, moved to different outlet, checked power supply, put unit in warm room, but still get...
On the top of the scanner mechanism, there is a black tab that gets caught on the underside of the scanner surface, just beyond the glass, towards you. You will hear a gear grinding sound, that"s the tab getting caught. either bend the tab down, or remove it. Its on the black cover that"s on top of the scanner mechanism. Also remove any tape that is on the bottom of the trailing cable under the scanner that prevents it from moving all the way to the left.
Feb 05, 2010 | HP OfficeJet D135 All-In-One InkJet...
LED never gets to on solid. Always flashes slowly as if in operation.
Thanks, but the problem fixed itself. After leaving the scanner on for a very long time, the LED finally started to glow steadily. Now after power cycle it only takes a few seconds to become ready.
May 02, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
UMAX 2100XL IS CONNECTED, 2 G LIGHTS FLASHING WITH NO PRINTS
OUR SCANNER IS CONNECTED BUT DOES NOT WORKING. DOES NOT POWER ON THE "SCANNING LAMB" NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
Dec 09, 2008 | Umax PowerLook 2100XL Flatbed Scanner
Check Cables. Check Scanner Lock. Cycle Power.
the problem is the cable in the scanner's mainboard
Sep 15, 2008 | Office Equipment & Supplies
Unusual noise
scanner unit initialises on power on condition. scanner unit moves to right extreem end and makes banging noise. This problem is due to scanner unable to find the home position. open the flat bed glass unit . one end of there will be black colure with white stip. apply black marker ink on black colour and fix the blass back to griginal position. scanner will work.
May 06, 2007 | HP PSC 1610 All-In-One InkJet Printer
Fujitsu fi6670 Logo
2,787 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
