Question about Emerson LTDN42V68US 42" Class LCD HDTV
Will not work on cable input
Which part do I need to replace?
    Top Expert:
  • Emerson Master
  • 46,240 Answers
Does it work with antenna input . my set uses the same input on the back of set
Posted on Apr 06, 2015
Hdmi input not working
If it works on your cable or tv input then the problem lies with your input circuitry. Since those inputs are on your main board, then it is that board that has the issue and needs to be replaced.
Nov 18, 2015 | Televison & Video
Our tv, model 42hp25bat, has been running on our cable input for the past year. All of a sudden the tv input setting says "no signal". The tv works for our DVD player on HDMI setting. We...
the signal input on the cable connection to to your tv (inside your tv) is broken, and possibly needs to be replaced. Possibly few capasitors or other parts might need to be replaced. or the whole signal board.
Apr 17, 2008 | Televison & Video
Input not working after lightning. Is there a way to use HDMI DVD input somehow?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 07, 2015 | Panasonic Viera Tc-P42C2 42 in. Plasma TV
Green and pink dots on screen
Check other inputs and see if the DOTS are on all inputs. If so, TV needs replaced. If not check to make sure the cable on the problem input is tight and possible replace cable. If issue persists, try another device on the same input, like a DVD or cable box. If resolved issue is with source. If not the input is bad on the TV, just don't use this input.
Apr 06, 2014 | Sharp Aquos Televison & Video
Connect to tv problem
The cable you describe should be the only cable that you need. You want to make sure that you switch to whichever input you connect to on your TV. If you are getting sound but no picture there may be a problem with either the input or your cable. Connect the cable to a different input to see if it works. If it does then the problem is with the input on your TV. If it doesn't work then there is something wrong with the cable. You may have to get it replaced at the place you purchased the camera from/
May 29, 2010 | Samsung VP-D361 Mini DV Digital Camcorder
When i turn on the system the unit comes on but nothing comes on the tv screen. All the input cables are hooked up correctly
make sure the input cables are in on both sides. If that does not work you might need a replacement because the input cables are damaged in the inside. Also if thats not working go to where you bought it.
Jan 24, 2010 | Sony Playstation 3 (PS3) Console
My dish 322 receiver wont work 2 tv,to get service
  • There are two satellite inputs on the back of a 322. There may be a single cable going to a splitter connected to these two ports or two individual cables.
  • If there are two cables swap them, if you still get signal on the same input only then the receivers input is dead.Otherwise follow the bad cable and ensure it is not damaged or disconnected. Swap the location on the other end and see if the issue stays on the same cable. If so replace the cable, if not replace the LNB or Switch.
  • If there is a splitter bypass it and connect the single cable directly to the input that does not work. If there is no signal the port is bad, replace the receiver. If there is signal then reconnect the splitter, press menu 6-1-1, check switch, and then test. Allow the test to finish. If the two inputs do not match replace the splitter... Its called a DP Seperator
Jan 24, 2010 | DISH Network 322 DTV Receiver
Bad cable input connector?
try use vedio input for work....or use vcr ant in vcr vedio output to tv...
no need replaced tv
Aug 13, 2009 | Televison & Video
My sony wega 36' circa 2001 will not receive cable signal.
If none of the r.f. inputs are working and you do not get local channels off of a pair of rabbit ears. You may have a bad tuner. Which you can get replaced for 125.00-150.00 or you could run the cable into a vcr input and use audio/video cables to connect to a video input on the tv and switch tv to that input and run the channels using your vcr. In other words, use your tv as a monitor and use the vcr tuner to pickup basic cable. Hope that takes care of it, Russmann.
Jun 05, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony with diagonal lines
Is it a composite(yellow plug)video input? an HDMI input? What if you switch the output of the cable box to another input, Make sure its not the cable box first. If it happens on another input then the cable box or the connection wire to the tv from the cable box is bad.Good Luck Ps Please rate this thread
Oct 18, 2006 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Emerson LTDN42V68US 42" Class LCD HDTV Logo
43 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
