Question about Cross Executive EPS-1501X Shredder
Does not auto shut-off anymore?
Is there any way to fix it so it will automatically shut-off like it is supposed to?
  • 2,963 Answers
Automatic feed switch jamed with paper. reverse and forward several times may help. Otherwise turn it over and pull paper out of the bottoms to clear the switch jam.
Posted on Apr 06, 2015
  • C E Samanich
    C E Samanich Apr 08, 2015
    I have already done those things multiple times...it does not help.
Is the fan suppose to run continuously?
Only If Fan is on and while on auto the fan then should automatically shut of according to temp setting..
Jun 07, 2016 | Fedders A6Q10F2B Q Chassis Room Air...
Asus eee pc auto-restart not possible
it could be an OS problem try to re-install (your OS)
Jun 14, 2012 | ASUS Eee 4G Notebook
Dryer starts fine after a couple of minutes shutts of, I have to restart it several times untill clothes are dry.
most dryers have a sensor that is supposed to shut off auto matic when clothes are dry look at your choises on the dry temperture. one of them usually have automatic whites auto colors etc. the sensor sounds like it went bad. most of them are near the exhaust pipe.it measures the moisture level to test it remove the wire or wires. then try running the dryer for a little while.
Dec 29, 2011 | Roper Dryers
What is the ploblem if the car shut down when its hot
It is supposed to shut down when it overheats, that is a safety precaution to save further damage. You fix the overheating problem and it won't shut down anymore.
Dec 12, 2010 | Daihatsu Charade Cars & Trucks
Dryer does not shut off automatically anymore, it just keeps drying until i open the door. How do i fix?
may be the timer motor, here is a website that will show you how to test it:
http://www.partselect.com/dryer+test-timer+repair.htm
Oct 24, 2010 | Maytag PYE2300AY Electric Dryer
Automatic Dry Function Has Stopped Working
There is a humidity sensor which acts as an auto cutoff switch in most driers, as your load auto dries , it senses the change in humidty and kicks the power off. It is often shaped like a flying saucer with wire terminals on the wings. That is likely your culprit, generally located close to the element. Based on your description, I would start there. Also test a load on timed dry, but it sounds like that's your problem. Remember to unplug before looking under the hood. Post back if you need further info
Sep 20, 2009 | Dryers
Automatic wipers
There is a parking mechanism attached to your wiper motor the tab on these either bend or break off it should be replaced and retimed to fix your problem.
Aug 30, 2009 | 1997 Buick Park Avenue
SHUTS OFF AFTER 1 HOUR
Here ya go!
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
Dec 30, 2008 | Krups FME2 Coffee Maker
Cross Executive EPS-1501X Shredder Logo
451 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
k24674
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
