Question about Tablets & eReaders
How can I hard reset msi tab n913 - Tablets & eReaders
My samsung t210 is not resetting i have tried button and inside setting options both look like its working but when reboots no change the accounts come back aswell
Before performing the Hard Reset:
- In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
- But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
- Turn your Galaxy Tab 3 off.
- Take out any existed SIM or memory card.
- Wait for 10 seconds.
- Press and hold the Volume Up key + Home key, Then press the Power key.
- Keep pressing the keys until Samsung logo appears,Release all keys.
- Wait until you get Factory reset / System Recovery menu on screen.
- Use the Volume Down key to select Wipe Data / Factory Reset option.
- Use the Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use the Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
New Hard Reset / Factory Reset Method Using Odin3 Flasher:
In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
- Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
- Download Odin3 flasher.
- Put your phone into Download Mode.
- Run Odin3.exe
- Click on CSC button and Select the Hard Reset file.
- Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
- Click on Start button and wait until the operation done.
- Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
- Done.
Jun 02, 2016 | Samsung Tab Tablets & eReaders
I bought a used Samsung Galaxy Tab 4 (8.0) running on AAA Automobile Club towing system on it, I want its original android system back into it, where can I find that specific download? A link please!
Try a Hard Reset which clears everything off it and installs Android new. There are no Android download links.
  • Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8 ... www.verizonwireless.com > Samsung Galaxy Tab 4 (8.0) Before performing a hard reset, ... Home > Support > Samsung > Samsung Galaxy Tab 4 (8.0) > Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8.0) Ask Verizon:
  • How to Factory Reset the Galaxy Tab 4 - YouTube www.youtube.com/watch?v=nZBZYa4nZ18
    • BY ASKTHEANDROIDGUY
    • 3 MIN
    • 110K VIEWS
    2014-05-19 · Video embedded · How to Factory Reset the Galaxy Tab 4 Check Out Our New Website: http://www.RickytheAndroidGuy.com Like us on Facebook: ...
  • SAMSUNG T330 Galaxy Tab 4 8.0" - How to Hard Reset my ... www.hardreset.info/devices/samsung/samsung-t330-galaxy-tab-4-80 Hard Reset SAMSUNG T330 Galaxy Tab 4 8.0" First method: In order to switch off the tablet hold down the Power key for a short while. After that, press and hold ...
  • Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset ... solverbase.com/w/Samsung_Galaxy_Tab_4_8.0:_Hard_Reset_Factory_Reset Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset. From ... How to make a Hard Reset (Factory Reset & Data Wipe) on Samsung Galaxy Tab 4 8.0"? Samsung ...
  • Samsung Galaxy Tab 4: Steps For Hard Reset - Technipages www.technipages.com/galaxy-tab-4-hard-reset How to perform a factory hard reset on the Samsung Galaxy Tab 4 tablet. Technipages Smart phone, gadget and computer tips. ... Samsung Galaxy Tab 4: Steps For Hard Reset.
  • https://www.android.com/tablets
    May 23, 2016 | Samsung Tablets & eReaders
    After pressing the reset button on my acer a200 iconia tablet it freezes on start up with only "iconic tab" showing on a black screen, what do I need to do to to restore my tablet to working order
    Since you tried to reset the tablet, you can try doing the hard reset. Just to let you know, performing hard reset deletes the data from your tablet.
    Iconia Tab A200 How to Perfom Hard Reset
    Please let me know if it helps.
    Feb 05, 2016 | Acer Tablets & eReaders
    How can I reset my Galaxy tab 2 7 to its original settings?
    Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ...
    https://www.androidpit.com/.../samsung-galaxy-tab-2-7-0-how-to-perfor...
    Jun 18, 2014 - Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ... From the Backup & restore section, ensure the appropriate account is ... In Menu mode, select Settings ? Privacy ? Factory data reset ? Reset Tablet? ... Samsung Galaxy Tab 2 10.1 - How to perform a hard ...
    Jun 18, 2014
    How to Hard Reset the Galaxy Tab 3 - Android Forum ...
    May 7, 2014
    More results from www.androidpit.com
    Galaxy Note 5: How to Perform Soft & Hard Reset
    www.technipages.com/galaxy-note-5-how-to-reset
    Aug 23, 2015 - If you want to sell or give away your Samsung Galaxy Note 5, or if you're ... The hard reset will wipe all files off of the internal memory, as well as ... your phone and just perform a factory reset as a way to make it their own. ... November 7, 2015 at 3:44 pm ... I have problem with my Samsung Galaxy tab 2 ...
    How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0
    ? 6:01
    https://www.youtube.com/watch?v=7sbgN0PxMzc
    May 2, 2013 - Uploaded by HARD RESET KING
    How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0Android 4.0 ... hi I got the same one as you and ...
    Dec 21, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
    I cant get pass my password
    You may need to do hard reset.
    You didn't say make / model.
    Here's an example:
    Samsung Galaxy Tab GT P1000 hard reset
    Feb 13, 2015 | Tablets & eReaders
    I have forgot my password for my samsung galaxy tab 3
    1 problem is I cannot verify that you really are the owner of this tab. But you should be able to do a hard reset by a turning off the tab, holding the power, volume up and home button all at the same time until it resets.
    Jan 07, 2015 | Samsung Galaxy Tab Tablet PC
    To many pattern attempt
    1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
    Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
    It should hard reset any of these tablets:
    Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
    Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
    Reset GT-P6810 Galaxy Tab 7.7 WIFI
    Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
    Reset GT-P7310 Galaxy Tab 8.9 WIFI
    Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
    Reset GT-P7510 Galaxy Tab 10.1 WIFI
    Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
    Apr 15, 2014 | Samsung Galaxy Tab Tablet PC
    To many patten attempts
    Feb 10, 2014 | Samsung Galaxy Tab 2 7" 8GB Android Tablet...
    Hi guys, during upgrade I did something wrong. So, now I have on screen of my tab logos of pc and mobile with triangle in between. No charging, non responding, no hard reset available. Please, help...
    Have you tried the hard reset? Try these instructions for a hard reset:
    1. With the device off, press and hold Volume Up and Power.
    2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
    3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
    4. Press Volume Up continue.
    The Galaxy Tab should then go through the hard reset process.
    Mar 02, 2011 | Samsung Galaxy Tab Tablet PC
    Tablets & eReaders Logo
    35 people viewed this question
    Top Tablets & eReaders Experts
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
