Question about Dometic Rooftop RV Air Conditioner
How to fix rooftop air conditioners to drain properly i.e. down drains at front of the coach?
We have had this problem continuously and in for repairs many times. Dealer says there is no fix which we find hard to believe.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 42 Answers
On most coaches the air conditioner simply drains onto the roof. There are multiple openings on most base pans for the water to drain out, so a single hose will not normally solve the problem. What I have done in the past is use rubber roof caulking to make directional dams, routing the water where the customer wanted it to run off. Gutter extensions can help also, making the water drip away from the camper instead of running down the sides. A clothes pin, clipped onto the end of the gutter, can help a lot too.
Posted on Apr 07, 2015
  • Dometic Master
  • 2,992 Answers
I would try to find the "drain", connect a hose of some kind to it and direct the hose to the back. Air over the top and back should continue to push it in the rearward direction. If no drain I guess I would "shim" the front so the front of the pan was higher than the rear, which I would guess would do the same thing. If stopped, I would be sure the front of the vehicle was considerably higher than the rear.
Posted on Apr 06, 2015
Where are the condensing water drains?on a Coleman RV rooftop air conditioner
The condenser drains for a roof unit drain on top of the rv. There are on hoses which divert the condensation to a location other than the roof. Are you trying to keep it from dripping down at the door?
Jun 28, 2014 | Dometic Rooftop RV Air Conditioner
When my a/c is on it leaks water,right down through the vent.is there some drain holes up on top that may be pluged up.
Yes! There should be a drain tube that dumps the water on to the roof, if the tube is plugged then water builds up in the catch pan and eventually overflows running into the coach. You will need to take the shroud off to see where the water needs to drain, should be on the left side if your facin the front of the trailer while standing on the roof. Might be a leak in the roof but I think the drain is plugged on this one.
If this was helpful a vote with the thumbs up would be appreciated.
Jul 29, 2011 | Dometic Rooftop RV Air Conditioner
Air Cools well but after about an hour, water starts coming into the coach through the discharge air side. Unit does not freeze up but if I shut the unit off, the tray that holds the water drains quickly,...
Your evaporator is probably dirty and is blocking some of the air flow so the air has to move around the coil and starts coming in through the condensate drain holes. That stops the condensation (water) from draining out the holes because the air is pushing it back in.Try having the unit cleaned and that should stop that leaking.
Jun 27, 2011 | Dometic Rooftop RV Air Conditioner
Roof leak from seal between AC unit and coach roof
Not very often that occurs but possible. If it has been running well for quite a while and not leaking, just double check that all 4 bolts are snug, but don't tighten too much and compress the gasket too much. I suspect that drip tray may be cracked, or drain holes plugged, and that is what is dripping inside. If it doesn't leak when unit is shut off, and it's raining, then I would pull the cover off, and check for blockage in all the drain holes. In order to properly clean 2 drains at evaporator coils (rear of AC), you will likely have to remove screws holding cover over it, and carefully lift it up and out of the way. Hard to see, but there is usually 2 drain holes in there, one on each side, and the tubes get plugged as well. Make sure power/hydro is off to unit for safety. If it does leak when raining, and unit off, then I'd say gasket needs replacing.
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
Both units are liaking water inside coach. Have claned out overflo
Did you check & make sure drain holes were cleaned out in base of unit on roof? When you say overflow, do you mean drip pans under cover on roof unit, and if so, did you inspect them for cracks ? There were some years that experience cracks in drip pans.
Jul 11, 2009 | Dometic Rooftop RV Air Conditioner
Dometic AC Unit is leaking
Your drain pan is plugged up and allowing the water to rise above the edge of the pan and into the coach. The best way to repair this is to get on the roof and lay down next to the air conditioner. Look underneath the unit and you should see two white nipples sticking out the bottom about 1/3 of the way back from the front. These are the drain ports for the pan. Take a wire hanger or a long pick and work it into the hole of the nipple. The hole is kind of small and it would not hurt to open it up a bit. If you are unable to access the nipples in this manner, then the AC has to be removed and stood up so that the pan can be cleaned.
Hope this helps,
Jeff
P.S. The reason that it is only leaking during the day is because the evaporator creates more condensation in the hotter parts of the day than at night.
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
LEAKING AC UNIT
Hope this helps,
Jeff
Condensation
First clean this up ., and add a drain tube to the bottom of the coach!
Sep 08, 2008 | Dometic Rooftop RV Air Conditioner
Low pro 15
Over sight from the teck. Most units are designed to drain off the side of the coach. If you do not want to take it back. Installation as your speaking of is the only solution. Other wise the unit is going to drain down the side of the coach.
Sep 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air conditioner
why is our dometic roof top a/c on our boat draining water back into boat. is there a way to clean the drain?
May 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
163 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
