Question about Drills
How to do maintenance on an electric drill? - Drills
    Genius:
  • 1,179 Answers
What maintenance ? There is not much to do other than repairs an a drop of oil in the chuck on occasion.
Posted on Apr 06, 2015
Why does it blow controller fuse when key is turned on?
Electrical: Circuits, Relays - SwedishBricks
www.swedishbricks.net/700900FAQ/Electrical-CircuitsRelays1.html
fuse keeps blowing Drills & Drill/Drivers Questions ... - Fixyawww.fixya.com > Forum > Tags > fuse keeps blowingDrills & Drill/Drivers fuse keeps blowing questions and answers. Ask your fusekeeps blowing drill and drill/driver questions. Get free help, advice & support for ...Ryobi Multi-Volt Battery Charger Fuse - Questions - Fixyawww.fixya.com > ... > Ryobi > Ryobi Multi-Volt Battery Charger1423701) and have blown the internal fuse. The label on the charger indicates the input is 120V AC. Question about Drills & Drill/Drivers. 1 Answer ...Remember that fuses can fail without showing signs of an obvious ... remember that suspect turn signal flashers, fuses, bulbs and relays can be ... will be predictable, such as a bad current or ground connection, blown fuse and the like. .... The relay then sends power to all the lock motors (all doors except driver's door).Missing: drills
[PDF]Electrical Safety - Occupational Safety and Health ...
https://www.osha.gov/.../4...
Occupational Safety and Health AdministrationShe has an older drill with a steel housing and a 3-prong plug. ... current. This willgenerally allow enough current to flow so that a fuse will blow or a circuit breaker is tripped, thus turning off the electricity in that circuit. ..... There are three major ways tocontrol power line hazards: 1. ... Install warning signs at driver's eye level.Missing: drills ‎key
Jan 07, 2016 | Drills
B&D Electric drill model DR501 Type1: Power cord
Maybe the motor was damaged by the short.
Oct 31, 2013 | Drills
I would like to know what inspections/maintenence should be performed on drill presses, say monthly and than yearly. I want my machine to stay in tip top shape.
Depending on how much the Drill Press is used will determine the maintenance required.
For light to moderate usage a monthly clean and lubrication of turning / sliding parts with a general inspection of drive belts and pulleys will be sufficient. Heavier usage will require more frequent cleaning, lubrication and inspection.
Yearly maintenance will be the same as the monthly check with possible replacement of the drive belt if showing signs of wear or deterioration such as cracking and checking bearings of drive motor for signs of wear or noisy operation. If possible, an electrical safety check should also be carried out at this time by a suitably qualified person.
Feb 16, 2011 | Craftsman 12" Drill Press (21914)
Whats it mean whene the top light comes on and it wont drill wit the makita hr3000c
green light up : all electrical contacts are ok
red light on : time to replace carbon brushes ant if possible bring back for maintenance kit
Nov 17, 2009 | Makita HR3000C Electric Rotary Hammer
The motor is smelling hot and I see sparks when I release the trigger. Any maintenance needed?
It gets hot because this is very hard work for a 14.4 volt drill. For that matter, it is hard work for any portable or small electric drill. The sparks you see during the stop procedure are likely an electric brake. If yours doesn't have a electric brake - it may be too late for maintenance :-(
Your drill would appreciate it if you would give it a rest when it gets hot ... this is not good for your drill.
I am sure others will have more to say about this, here is my 2 cents worth.
Thanks for your interest in FixYa.com
please vote
a
Nov 14, 2009 | Porter Cable 14.4V Hamm Drill Kit
Why does my drill turn on and off when I tilt it?
If it's a corded drill, the cord is probably broken where it goes into the drill. If it's a cordelss drill, the battery contacts (on the battery or in the battery receptacle on the drill) are loose or dirty.
In other words, when you tilt it the power is shut off to the drill.
If you want more info, let me know.
Charlie
Sep 30, 2009 | Electric Drills
How to apply an electric drill? how to used the electric drill?
Please follow the below steps to use a electric drill -
1. Determine which electric drill is best for you, the cord or cordless. The electric drill that has a cord attached needs to have an outlet which might limit you according to what job you are doing. The cordless drill is limitless and can be used anywhere without needing an outlet. Corded drills can be more powerful, where cordless drills are limited to power and can sometimes be a bit bulky.
2. Consider most of the jobs you may use an electric drill for. If you have a lot of heavy-duty projects ahead, you might want to purchase a more powerful drill. They run slower but have the power behind them to get the job done efficiently. The more powerful drills usually have a cord attached to them. If you have a lot of lightweight jobs to use a drill for, then a cordless one may be your best selection.
3. Arrange the work to be drilled either straight ahead of you or down below you. These are the two safest ways to use a drill. The drill is also more secure and won't waver while using it. If the material you are drilling is a hard or thick material, use a hole punch to start the hole before you drill.
4. Push the drill slightly as you are drilling to give a bit of added force. Start out slowly, and as the hole progresses, increase the speed slightly.
Tip -
Secure your work before drilling by using clamps. The more powerful the drill, the slower it drills. The less powerful the drill, the faster it drills.
Warning -
If you are using a cordless drill, charge the power pack before starting a job. Keep the air vents on the drill clean, and clear of any debris so the drill does not overheat.
Good Luck!!
Thanks
Sep 29, 2009 | Black & Decker Grinders
General maintenance
These tools need very little maintenance. Make sure your chuck is tightened down, inluding the screw in the middle of it, as this can work loose over time and jam the jaws. Other than that it is just a matter of using an airline through the vents to blow any dust/debris/carbon out. The gearboxes are enclosed so need little lubrication and the motor has plain brass bearings. If the motor squeals a little when starting/stopping jsut apply some oil behind the pinion gear and on the shaft at the rear of the motor.
Oct 19, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
79 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
