Question about Epson WorkForce Office Equipment & Supplies
MY Epson WF-3520 will not print from the rear paper feed.
I have checked rear paper feed in print properties, but it still pulls paper from the cassette tray. I am printing from Word using card stock. If I put one pc of card stock in the rear paper tray first the printer will eject it then pull from the cassette tray. If I just try to print without putting the paper in the rear it pulls from the cassette (It used to read not to load paper in rear, then when the printer started up it would change to load paper in rear. I would then load 1 pc in rear feed and it worked, but not anymore. Using MS XP now. When printer was feeding from rear I was using Win 7, but after updating from the update utility my Win 7 laptop crashed. Before it crashed I kept getting notification of update available for printer. At that time printer was working good, but started not letting me get into printer properties. When I would click on properties it wouldn't do anything... so I thought I needed to go ahead and do the update. Win 7 crashed after the update so now using my old dell XP desktop. Any suggestions as to what I should check?
  • Epson Master
  • 6,161 Answers
Try reloading the drivers for you printer for XP, un-install the windows 7 driver and install xp. check the Epson web site for xp drivers if available.
Posted on Nov 18, 2015
eagle338
  • 4889 Answers
SOURCE: feeds paper crooked
Lexmark printers are hyper sensitive to dust..It might be causing this problem...Take a cotton swab dip it in alcohol and press it against the roller whilw pressing the paper feed button....
If this doesn't work you should try a longer procedure...Remember you have to look real hard..
It's possible that the paper may be running into a foreign object and not feeding in at all. A foreign object could also cause the paper to stall, or even feed-in crooked. Remove all the paper and use a flashlight to look carefully into the paper feed-in area. Look for a pen, pencil, push pin, paper clip, candy, etc. If you can't see anything, then actually pick your printer up and turn it so the paper opening is facing down and shake it a little, side to side. Your trying to dislodge anything that might be stuck in the paper entrance area. If nothing falls out, then turn it back over and use the flashlight to once again look inside that area. Sometimes you'll see an object that may have moved over into view while you were shaking the printer. Any foreign object might block the paper from actually being able to move forward, so then the printer thinks there is no paper installed. You may have to even remove the Top Cover to be able to get a better view of that paper feed area. Unfortunatly, just removing that cover is not always that easy, especially on the newer printers. You may need a Service Manual for reference, disassembly and troubleshooting. I have not checked, but you can normally find Service Manuals for most printers, at www.2manuals.com (most Service Manuals can usually be downloaded for around $10 +/- ). Even if there is not a foreign object stuck in that area, with the top cover off, you might just possibly see what the problem is and even be able to correct it..
Posted on Oct 17, 2007
SOURCE: HP 7350 printing goes through the motions but nothing
I had the same problem and couldn't figure it out until I found this on the web - I changed the DEP setting and now I can print just fine. Hope this helps you too!!
Julia
Source:
http://www.tech−archive.net/Archive/WinXP/microsoft.public.windowsxp.print_fax/2006−06/msg00081.html
· From: Shawn D <ShawnD@xxxxxxxxxxxxxxxxxxxxxxxxx>
· Date: Sat, 10 Jun 2006 07:40:01 −0700
I just figured out my issue. It had to do with DEP − Data Execution
Prevention. I had remembered that I was fooling around with this a couple
weeks ago and had changed it to "Turn on DEP for all programs and services
except those I select" in which I had Windows Explorer checked. I just got
done selecting the original which states "Turn on DEP for essential Windows
programs and services only", rebooted, and now I can print again to my hp
7350 printer.
The DEP can be found under control panel−>system−>Advanced Tab−>Performance
Settings−>Data Execution Prevention Tab
Hope this helps.
Posted on Mar 06, 2009
SOURCE: I have 2 Dell model 1700n laser printers and they
Take off the two rubber rollers, turn them inside out and replace them, Voila!
Posted on Aug 23, 2009
  • 5 Answers
SOURCE: paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Posted on Oct 16, 2009
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
Epson WF-2530 Says paper out, feeds one sheet 2/3 then wont print
you might have to check for a maintenance kit and change the rolls.
Oct 21, 2016 | Epson WorkForce WF-2530
Epson WF-3529 printer seems to feed two sheets at a time when printing
In some countries, due to moisture in the air, during some weather conditions, this is common.
Fan paper well before loading in the tray.
Also depends on the type of paper.
Use manufacturer recommended grade. gsm80 in most cases.
Sep 06, 2016 | Epson WorkForce WF-3520 All-in-One Inkjet...
Why won't my Epson WF-7620 print on thick paper when fed from the rear slot
Are you setting the printer to A3 when you hit print? When you select print you will get a on screen box where you can change options and then confirm by clicking print. Most printers are set to default legal size.
Aug 07, 2016 | Epson WorkForce WF-7620 Wireless Color...
It says paper size does not match the paper source setting, Print on Letter No Yes Remind later
Check paper tray it might have a movable plastic thing that sets the paper size . Check printer properties on settings - printers - Epson Workforce printer properties. Check software you are printing from that it has page setup and printer setup paper size set correctly
Mar 02, 2015 | Epson WorkForce WF-3640 Wireless Color...
Paper Jam Error but there is no paper jammed. False error message
I know it sounds silly but when my Brother All in one does this the trick is to pull the main supply cord, count 10 and reconnect(Or turn off at the wall) The brain then reboots and all is well.
Feb 23, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
Printing vertical green lines on photos
The troubleshooting section for banding below was taken from the user manual found at this web link:
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
White or Dark Lines in Printout
If you notice white or dark lines in your prints (also called banding), try these solutions before you reprint:
• Run a nozzle check to see if any of the print head nozzles are clogged. Then clean the print head, if necessary.
• Make sure the paper type setting matches the type of paper you loaded.
• Make sure you loaded the printable side of the paper correctly for your product.
• Turn off any high speed settings in your product software.
• Align the print head.
• You may need to replace the ink cartridges.
Hope this helps...
Dec 21, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
What is error OxF1
0xF1 means there is a paper jam. Are any of the lights on the machine flashing? Are any of them solid ? Epson WorkForce WF 3520 All in One Printer
Sep 15, 2014 | Epson WorkForce 600 All-In-One InkJet...
Epson wf-2530 printer error see your documentation
Turn the printer unit ON
2. Pull the power plug from the back side of it
3. wait 1 min
4. Plug unit back in
5. wait 3 full minutes
6. try to print does the error still exist? If yes continue below
Locate one piece of CARD STOCK paper and manually feed it up against the feed assembly and into the feed.Must be CARD STOCK PAPER, regular paper will not work. the idea is too dislodge any pieces of paper that may be broken off inside the rollers, and not visible to the eye. Repeat this process until the error goes away.
If you continue to experience problems, PLEASE RESPOND TO ME
Dec 16, 2013 | Epson WorkForce Office Equipment &...
799 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
