Question about Schwinn Cycling
How to use the 21 gears
New to me
  • 2,992 Answers
Talk to your friends. Owner's manual.
Posted on Apr 06, 2015
Pendulum wall clock from the 50's stops at 6:21
Needs lubrication in the gearing at that point most likely.
Nov 28, 2015 | Watches
Brother 1510 replace toner problem
Assuming you have tried to replace an empty toner with a new or refilled toner cartridge. Some of these machine simply fail to recognise the reset activation lever on the side of the cartridge. You could try removing the end cap at the geared end. You will find a half moon shaped gear which needs to be lifted out slightly and rotated a quarter turn clockwise. replace any other gears and refit the cover. This resets the toner cartridge to "new" state. If you printer doesn't recognise this, you will need to get a manual reset keycode from brother. Please note - some folk reset used cartridges this way and re-use them. Used toner will contaminate the drum and give poor print. Any residual contaminated toner on the drum can contaminate a new cartridge and so-on. Refilled cartridges are fine if the cartridge is completely cleaned out first.
May 06, 2015 | Brother DCP-1510 Laser Multifunction...
I have a Schwinn women's 21 speed Frontier. Frame in purple serial #0378. I wanted to know the year and specs. On it? Thank you!
First thing, is headbadge black and red? Does it say it was made in China, either on the headbadge or somewhere else on the frame. If so, the bike has no value as an antique bicycle. If its in running condition, tires hold air, brakes work and gears shift its about a $60 to $ 75 bike
Sep 22, 2014 | Schwinn Frontier 21 Speed Mountain Bike...
How to assemble the rear gear and chain on a 21 speed mtn. bike
Hi victor ernest yessler
Go to the following website and view how to adjust the rear gear and chain
Please rate me
Bud
http://www.youtube.com/watch?v=2j1gSwhsVN8
Sep 27, 2012 | Cycling
I've got a 21 speed bike and I get a skipping ,
It is the derailer (the part on the back that the chain runs through). Take it to a bike shop or bike enthusiast. The repair should only take about 5 min. Some bike shops won't even charge you.
Jul 22, 2011 | Cycling
My bike has 21 gears the new wheel only has 18 gears w ill the bike work
yes it will. You will have to adjust the gear shift cable so that it doesn't go past the 6th gear on the wheel (as you would've had a 7th gear) otherwise your chain will constantly slip off the wheel and jam up
Sep 30, 2009 | Cycling
How do you use the 21 speeds on the Schwinn ladies coaster bike?
there are 7 cogs on the rear wheel hub; three on the crank hub:
7x3=21 gear change possibilities
large gears move the wheel faster and farther around but, with more effort
small gears move the wheel less distance but, with less effort
i.e. 10 teeth divided by 30 teeth= 3:1 per 360 degree rotation of the bicycle wheel
Sep 07, 2009 | Schwinn Cycling
How do i set up my shimano 21 gears . just had new cables and ive lost some gears. theres also small screws on the drailiures, and ive messed with them and maybe thats my problem?can u help me on how to...
okay start with the deraileur in the smallest gear if it wont loosen cable and screw with the letter h by it if you cant see letter just loosen the one that lets it move out only go until its in high gear then making sure its shifted to high gear tighten cable slowly shift to low gear when it reaches low tighten small screw you havent adjusted yet to keep deraileur from going into spokes
Apr 07, 2009 | Cycling
Cycling Logo
75 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
