Question about GE Ovens
Where is the serial number on the GE True Temp Oven?
    Top Expert:
  • GE Master
  • 45,431 Answers
Open the oven door and look for a label or a tag with numbers on it .
Posted on Apr 06, 2015
How do I fix my GE True temp oven which shows F7 on the display?
https://www.youtube.com/watch?v=Rg7Dp4LBxtA
it seems its the connections ribbons on the control panel is wrong
will give you a clue look down the replys to the video to get more info
some very carefull cleaning is needed inside the front panel rework some connections
i use deoxit 5 and a rag
spray the deoxit to a rag then wipe the connection ribbons
then dowse the plugs with the deoxite
wait a while and re plug then carefully
should cure it
i would add a blob of grease to the sockets once its all running
to avoid further corrossion
hope this helps
Dec 11, 2014 | GE Ovens
Ge true temp oven
Sometimes you will have to pull the oven out to get access to the connector for the sensor. It could be jammed in the back or the hole is just too small to pull the connector through the wall.
Feb 15, 2014 | Ovens
GE True Temp oven won't turn off.
The sensor is a part number WB23T10002 and goes for about $60. The paper inside the control area of the oven will state the normal resistance values of it. (probably about 1080 ohms at room temp, about 2650 at clean temp.) If you cut a lead to it, you would just get a F3 code, and if you cut the other and wire them together, just get a F4 code, so that wouldn't help diagnose the problem, but if you could use an ohm meter on the probe it would. BUT the oven should not come on without it being set to bake, SO I conclude that the ERC is indeed the problem (with the welded electrical contacts), which is a part number WB50T10043 which might go for about $125 or so. If you are careful when you replace it, you can probably peal the faceplate (part # WB27T10125) off and reuse it, so you should just need the ERC.
May 05, 2009 | GE Ovens
GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
Oven low heat
Did you try going to the GE website to pull up the Use and Care Manual? It does have a section re: how to adjust the temperature by as much as 35 degrees either way. Although it is not the 100 degrees you mentioned, you could try it and see if it helps...
The main GE website is: http://www.geappliances.com/
At the top of the web page is a SEARCH section. You can click on the blue down arrow in the first box and select Use & Care Manuals, then put your model number in the empty box to the right of that selection box, ie. JT952 is my oven.
If you are having a problem locating your model number/serial number, you can go to the FAQ (frequently asked questions) section to see how to find it.
Jul 05, 2008 | GE Profile JT952 Electric Double Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
GE True Temp Oven Timer Instructions
go to this web site put in your model number and you can download the whole use and care manual http://www.geappliances.com/ just look for the search box half way down on left select use and care then put in the model number
Dec 02, 2007 | GE JGRP17 Gas Single Oven
Ovens Logo
168 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
