Question about Cameras
How to install a new drive belt on the projector. It looks very imposing & cannot find instructions.
  • 2,963 Answers
Try repair manual at manualslib.com
Posted on Apr 06, 2015
Turns on again after standbymode
Try holding the power button for a few seconds.
Jun 29, 2012 | Optoma DLP Projector HD23
I have a Sankyo Sound 600 projector that I found in my basement. For sone reason neither film wheel is moving. Since it's been sitting for years in my basement is there something that can be used to...
I have the same projector. Many years ago the main drive belt rotted off and needed to be replaced. This drive belt drives everything in the projector. If yours has failed, you will need to remove the back cover (4 phillips screws) and replace it. Just find the drive motor (about center top) inside the projector. With the shaft pointing front to back, the main drive pully is on the back end with a fan mounted on the front end. E-bay sells replacement belts for about $10.00 to $13.00 dollars. I just used a belt that I picked up at the local electronics store that looked like it would fit. You should replace both belts, if one has failed, this is an old projector. If only the take reel has a problem, ie slipping, adjust the clutch on the rear drive pully.
Jul 31, 2011 | Cameras
Projector been in storage for 20 years - fitted new bulb and rubber drive belt C. All working but light not shining through lens. Any ideas please?
Old film projectors had a spinning disk with cut-outs in the light path (looks like a fan, but flat). This blocked the light when the film was moving between frames, then let it shine through when the film was stationary. It sounds like this disk has become stuck or is not being driven (another belt?).
Jan 15, 2011 | Cameras
How do I install a new belt?
Hi.
Follow below for the V6 Engine...
  1. Raise and support the vehicle.
  1. Remove and discard the drivebelt tensioner clip (if fitted).
  2. Remove the accessory drive belt.
  1. Rotate the belt tensioner counter-clockwise.
    • Use a 3/8 inch square drive bar to rotate the belt tensioner.
  1. Remove the belt.
Installation
  1. To install, reverse the removal procedure.
If you need instruction for the V8 Engine, let me know and I will get that for you.
I hope this helps you.
Thanks...
Dec 01, 2010 | 2001 Jaguar S-Type
Sanyo Projector PLC XU83 lamp is replaced 1 everything is fine 2 projector turned on and reset the counter 3 projector switch off and normal 4 Next time imposible to power on the projector After ...
Check the cooling fans. If they are not rotating the Projector will not start.
Did the lamp explode? If it did a bit of glass has lodged in the cooling fan and stopped it from working.
Hope this helps.
Nov 15, 2010 | Televison & Video
Belts need replacing how do i do it?
Pull washer out a couple of feet and tilt it back, lifting the front. Rest against the wall. The belts are on the bottom. Remove the drain pump belt, and you'll get to the drive belt. The motor is installed on a plate and held by a spring. To install the belts easier, push motor towards the transmission pulley when installing new belts. Part numbers: 211124 for the pump belt, and 211125 for the drive belt. Set of both belts: 12112425.
The set of both belts includes an instruction sheet also.
Coupon "New10" takes 10% off.
Good luck
Oct 31, 2009 | Maytag Dependable Care LAT9416
My belt tensioner pulley broke at the bolt that bolts to the bracket. I bought a new one and I was wondering if there was an easier way to replace the tensioner pulley other than removing both the upper...
You should only remove the drive belt shield if you raise the car. Below are step-by-step instructions per the repair manual. Drive Belt Tensioner
Removal & Installation To Remove:
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Remove the drive belt shield at the right wheel well.
  4. Remove the drive belt.
  5. Remove the drive belt tensioner mounting bolt.
  6. Remove the drive belt tensioner.
To Install:
  1. Install the belt tensioner. Torque the mounting bolt to 21 ft. lbs. (28 Nm).
  2. Install the drive belt.
  3. Install the drive belt shield.
  4. Lower the vehicle.
  5. Connect the negative battery cable.
Oct 30, 2009 | 1999 Plymouth Grand Voyager
Diagram with replacement belt doesn't seem to match old manual
I haven't worked on a belt drive but here is the Sears parts site for your washer with diagrams of the console, drive system etc. You may get a better idea of how to replace the belt from these.
Here also is the Whirlpool / Amana installation and maintenance document for Amana belt drive washers. It may look similar to yours.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56310258b0952a4e8525729c0056d75b/$FILE/Amana_Searcy_TL_Washer.pdf
The other thing I'd check is Whirlpools list of documentation for their laundry products. Check some of the washers that they make for one that looks like yours and you should get a better idea.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1&Count=30&Expand=6#6
Oct 08, 2009 | Kenmore Washing Machines
How to change water pump in 1996 geo metro?
I've found the Haynes Repair Manual that you can get at Auto Zone to be the best one there is. They have step by step instructions with pictures on repairing or replacing just about anything on your auto. You can get them for around $20 - 25. Is yours a 3 or 4 cylinder? Auto Zone has a new service where you can actually look up repair instructions for your vehicle with pictures. Here's the instructions for a 3 cylinder for your year, make and model:
  2. Drain the cooling system.
CAUTIONWhen draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Remove the air cleaner assembly.
  2. Loosen but do not remove the four coolant pump pulley bolts.
  3. Raise and support the vehicle safely.
  4. Remove the lower splash shield.
  5. Remove the air conditioner compressor drive belt.
  6. Remove the lower alternator cover plate bolts, loosen the alternator adjusting bolt and remove the drive belt.
  7. Remove the crankshaft pulley.
  8. Remove the coolant pump pulley.
  9. Remove the timing belt.
  10. Remove the oil level dipstick and guide tube.
  11. Remove the alternator adjusting bracket from the water pump.
  12. Remove the water pump rubber seals.
  13. Remove the water pump mounting bolts and nuts. Remove the water pump from the vehicle.
To install:
  1. Clean the gasket mating surfaces thoroughly.
  2. Check the water pump by hand for smooth operation. If the pump does not operate smoothly or is noisy, replace it.
  3. Install the pump using a new gasket. Tighten bolts to 115 inch lbs.. (13 Nm).
  4. Install new rubber seals.
  5. Install the upper alternator adjusting bracket and tighten bolt to 17 ft. lbs.. (23 Nm).
  6. Install the oil level dipstick and guide tube.
  7. Install the timing belt.
  8. Install the water pump pulley and leave the bolts hand tight.
  9. Install the crankshaft pulley.
  10. Install the water pump/alternator drive belt.
  11. Install the lower alternator cover plate and tighten bolts to 89 inch lbs.. (10 Nm).
  12. Install the air conditioner compressor drive belt by releasing the tensioner pulley and installing belt.
  13. Install the lower splash shield and lower vehicle.
  14. Tighten water pump pulley mounting bolts to 18 ft. lbs.. (24 Nm).
  15. Adjust the water pump drive belt tension and tighten alternator adjustment bolt to 17 ft. lbs.. (23 Nm).
  16. Install the air cleaner assembly.
  17. Refill the cooling system.
  18. Connect the negative battery cable.
  19. Start the engine and allow it to reach operating temperature. Check for leaks and refill cooling system as necessary.
Jul 17, 2008 | 1996 Geo Metro
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
