Question about Yamaha EMX512SC Powered Mixer 500 Watts Stereo 12 Channels 3 Band Equalizer Lightweight Design
I HAVE NOT RECEAVE IT YET I'M ASKING WHY HAVE I NOT GOT IT YET BEEN MORE THEN 2 MOUTH
    Top Expert:
  • Yamaha Master
  • 3,107 Answers
Fixya does not sell anything. You need to contact whoever sold you the item directly to ask them about when/if it was shipped.
Posted on Apr 07, 2015
What besides tiredness are the effects from taking Tegretol Tables. Do they cause Diaoherre
Listed side effects are nausea, vomiting, dizziness, drowsiness, and dry mouth.
Diarrhea is not listed. Bear in mind these side effects do not appear in every person, or to the same degree, as it varies widely.
See your doctor about this as it may be a sign of something else.
Dec 19, 2014 | Music
Akai ewi 4000s neck strap mount
1 Un screw all the screw on black panel, but must remember where each on goes, but Be careful not the two screws in side mouth pice which holding the pitch bend unit. 2. open the battery cover remove all the battery 3. Remove the 1/4 earphone nut, and all screws on the silver metal case. (Under the black plastic ), you don't need to remove any screws from the "key" side 4. Use something to pull the battery Cartridge sideway out from Main attachments, but not all the way out from the ewi case, because you can't, the plastic case structure will be in the way, 5. Use some flat pice metal like dinning knife insert in to between black and sliver metal to separate the two parts, start from the mouth pice end, once you open wide enough the battery cartridge can be remove from the case out. Now you can open the Ewi 4000s and see the two HX nuts that holds the strap mount, put some Nail polish on it before you tie them up.....Warning.. You must pull the battery cartage sideway out from its electric plugging mount before you are trying to separate the plastic and silver housing otherwise you will damage the circuit board. That was What I did to mine. Good luck and may God provide you wisdom for this.
Apr 22, 2013 | Akai Ewi4000s Electronic Wind Instrument
My power light is on but ther is no sound alteration from the talkbox i am using an alternet power supply could this have anything to do with this problum.
The pedal does NOT alter the sound... you probably don't understand how it works. Visit this YouTube site and observe:
http://www.youtube.com/watch?v=gkryZXYl0LU
Note that you have to have a microphone to pick up the sound. What the device does is to put your guitar sound into your mouth where you modify the resonance like when singing and then the modified sound is picked up by the microphone the hose is strapped to. I would suggest using a Shure SM57 micrcophone. Notes that your guitar sounds via the cable are NOT modified in any way, only amplified to put into the tiney speaker that drives the hose up to your mouth.
Feb 03, 2011 | Rocktron Banshee 2 Guitar Talk Box Talkbox...
The active light does not light up when I plug my guitar in and no sound comes out from the talkbox ... But the guitar sound can run through it to an amp where the guitar sound comes out
It sounds like you have NOT connected the power adapter to the box to power it. The guitar sound won't be too loud as you run the hose to your mouth and pick up the sound with a microphone such as a Shure SM57 which then goes to your amplifier. Without the power adapter the internal amplifier will not produce any output.
Jan 08, 2011 | Rocktron Banshee 2 Guitar Talk Box Talkbox...
The button on my hohmer chromatic will not return when the mouth piece is screwed on tight. Any help? The sping works fine when apart.
Lube the sliding part with CRC226 spray can available at Home Depot in the electrical dept. Clean any buildup of contamination.
Dec 21, 2010 | Hohner Super Chromonica Chromatic...
This is Close and play, this is what you need to know, think of it as a speaker inside the box, now something has to power it this is when the power amp is needed. So take the out of the power amp into the...
Remember that the tube in your mouth and your mouth have to be close enough to an active microphone to pick up the sound from the talk box. Now what was the question?
Dec 16, 2010 | Dunlop Ht1 Heil Talk Box
How do u put on the mouth piece and make a sound?
If you are talking about a single reed instrument such as a saxophone this is how you proceed. First you have to moisten the reed using water or your own saliva. You can do this by placing it in your mouth and rubbing both sides of it with your tongue. Take particular care not to damage the tip of the reed. Take the mouthpiece in one hand and lay the reed on the flat part of the mouthpiece with the thinnest part of the reed towards the tip of the mouthpiece flatside down. The tip of the mouthpiece is the opposite end of the mouthpiece from the one that you put on the instrument. You can't mistake the two. The end that goes on the instrument is like the opening of a tube. With the reed laying flat on the mouthpiece gently slide the ligature ( clamp with one or two screws ) over the end of the mouthpiece and the reed. Take care once more not to damage the end of the reed. Line the very tip of the reed up with the very tip of the mouthpiece leaving a sliver of the mouthpiece showing. Holding the reed in position move the ligature along the reed and mouthpiece so that it is covering the bark part of the cane reed about 1/8 to 1/4 inches from where the bare part of the reed starts. Some mouthpieces have a guide line marked on them. Once the ligature is positioned you can tighten the screws. Do not overtighten them. They just need to be snug enough to secure the reed in position. The reed should be in the position I described in order to speak or vibrate easily. Now you can slightly fold your bottom lip over your bottom teeth and insert the mouthpiece and reed into your mouth. Your top lip should not be folded over your top teeth. Your top teeth should rest on the top of the mouthpiece and your bottom lip should provide a cushion between your bottom teeth and the reed. You should have as much pressure applied between your top and bottom teeth so that someone cannot easily pull the mouthpiece out of your mouth. You will learn how much pressure to apply to affect intonation and produce a good sound with practice. Now with the mouthpiece in your mouth you can blow through it to produce a sound. Your mouth should provide an airtight seal around the mouthpiece if you followed my directions. You can steady the mouthpiece with your hand while try to get a sound. If all you produce is a sqwawk that shouldn't discourage you. What you are trying to do is make a piece of wood vibrate in a controlled manner using breath pressure and your jaw muscles to control the vibration. Do not use too much pressure or the reed will be clamped shut at the tip and not be able to vibrate. You should have at least an inch between your bottom lip and the ligature as to how much mouthpiece should be in your mouth. Once you can consistently make a sound then you can proceed to putting the mouthpiece on the gooseneck with the gooseneck properly installed in the saxophone. You should rub a little cork grease on the cork of the gooseneck before putting the mouthpiece on it. The distance that the mouthpiece goes on determines the tuning. Your lip pressure also affects the tuning but a lot less in comparison. You can vary your lip pressure rhythmically to produce vibrato. Most sax players now hardly use vibrato or use a slow shallow controlled vibrato on notes at the end of phrases. Another thing to note is that to start with you should use about a number 2 reed unless your mouth is particularly sensitive and then I wouldn't go anything less than a 1 1/2 for a little while until you get used to the vibrating sensation and the feeling of your bottom lip between the reed and your bottom teeth. Hope this helps. By the way I have been playing since 1963 and I hope you enjoy it as much as I have.
Aug 24, 2009 | Rico Tenor Sax Reeds Box of 10
Yamaha EMX512SC Powered Mixer 500 Watts Stereo 12 Channels 3 Band Equalizer Lightweight Design Logo
44 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
