Question about JVC Televison & Video
MY TV won't turn on. I tried to hold the menu and volume(-) button down and release while pressing the on button and now the red light clicks on off continuously and no picture or sound.
Old JVC standard television, 15 years old. I never had any problems before this. It was working fine until this happened.
    Top Expert:
  • JVC Master
  • 74,136 Answers
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 07, 2015
Unable to set up remote URC 22935
MENU • Set Up • Searching For Yor Code • Blinking Back the Code:
Redefining a Key • Punch Through • Volume Default • Clearing Out
Key mover • Favorite Channel Scan • Macro-Sequence
How to Program your One For All remote
(Models URC-2005, URC-2099, URC-4005, URC-4050, URC-6050)
Set Up
After getting the proper codes from your manual or Customer Service, use the following instructions to enter them into your remote.
PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
PRESS and HOLD the MAGIC button until the red LED flashes twice, then RELEASE.
ENTER the 3 digit code for your brand.
You should receive 2 quick flashes after entering your code.
PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
menu
If you have tried all of the set-up codes for your brand of eqipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following proceedure to search for your code.
ENTER 9-9-1 (two blinks on the remote)
ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
When your device turns OFF, PRESS the MAGIC button and RELEASE it to lock in the code for your device.
menu
PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
PRESS 9 - 9 - 0.
PRESS 1, carefully COUNT the number of blinks. (1st digit)
PRESS 2, carefully COUNT the number of blinks. (2nd digit)
PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
menu
Redefining a Key
PRESS 9 - 9 - 2.
PRESS the DEVICE,(TV,VCR,CABLE,etc.),key you want moved
PRESS the DEVICE key you want to replace.
Example: If you want the Aux key to be a TV key:
"MAGIC" (2 blinks) 9 - 9 - 2, TV (you want to move TV)
Then AUX (you want to replace AUX).
menu
Punch Through
This sets Volume to work for one device in all modes.
For example, the TV volume will work in the cable and VCR modes.
PRESS 9 - 9 - 3.
PRESS the device key you would like the volume to come from.
You will get two blinks on the remote.
NOTE: This only sets volume in the TV,VCR,CABLE, or SAT mode.
If you want to set the volume for a device to work just one or two other devices- refer to the instructions under "KEYMOVER-From one button to another"
menu
Volume Default
Use this to get the original volume to work on each device.
PRESS 9 - 9 - 3
PRESS the VOLUME+ key, you will get two blinks.
Now The volume is set for all original devices.
menu
Clearing Out
A Device Key
PRESS 9 - 9 - 2
PRESS the device button twice. - Two blinks.
Any Button On The Remote
PRESS the button you want to clear - RELEASE
PRESS 9 - 9 - 4
PRESS the button you want to clear twice. - Two blinks.
All Key movers,Macro's, and Defaults
PRESS 9 - 8 - 0 -- Two blinks.
Scrambled Keypad
Sometimes it seems that the keypad is "scrambled". Functions like channels, volume, or numbers are not where they should be.
If your remote seems to be acting this way, try the following proceedure:
ENTER 9-7-3 (two blinks) (for URC-2005, try 9-7-4)
Try the functions on the remote
If the keypad continues to act "scrambled", you may:
Be on the wrong code for your device.
A wrong code may only operate a few functions of your equipment or they may be operating inaccurately.
Have something more serious wrong with the remote.
In either case you will have to contact us for more information.
menu
Key mover
An Advanced Function To A Button
PRESS 9 - 9 - 4.
PRESS the "MAGIC" button and then the three digit extended function.
PRESS the button you wish to use for that function - Two Blinks.
From One Button to Another
PRESS 9 - 9 - 4.
PRESS the DEVICE and the FROM button
PRESS the DEVICE and the TO button
Two Blinks
EXAMPLE: To take the volume from a TV and put it in the VCR mode,
it would be: MAGIC - 9 - 9 - 4 -TV - VOL UP - VCR- VOL UP - two blinks.
You would have to do the same process for VOL DN and MUTE.
"Shifted" Key Mover
In order to stack a second function on a key; when pressing the button you want the function on in the sequence, instead hit MAGIC and then the button you want.
To use the function: TAP the MAGIC button and release, then TAP the key you chose.
FOR EXAMPLE:VCR-MAGIC(hold 2 blinks) 9-9-4 MAGIC 2-3-4 MAGIC PLAY
If you hit the PLAY button - the VCR will PLAY, if you hit MAGIC -PLAY it will bring up a display.
menu
PRESS 9 - 9 - 6
PRESS the channel to be stored, up to 3 digits
PRESS the ENTER button
REPEAT steps 4 & 5 up to ten channels
If you do not store ten channels, you have to hold "Magic" for four seconds to close Favorite Cannel programming.
NOTE: To stop scanning, press any other button on the remote control.
menu
Macro-Sequence
This will allow you do do several functions with just the touch of ONE key.
PRESS 9 - 9 - 5
PRESS the key you want the Macro to be on
PRESS the sequence of keys you want the remote to do
PRESS "MAGIC" and wait for two blinks - RELEASE.
When you hit the key you put the macro on it will automatically start the sequence.
IMPORTANT: The Macro key will be the macro in ALL MODES so it is best to pick a key you will not need for anything else in any other mode.
menu
All Material Copyright Universal Electronics Inc.
"One For All" copyright Universal Electronics Inc.
Any questions about the products should be directed to help(at)ueic.com
Apr 03, 2013 | Televison & Video
I have one of the old big screen tvs the hitachi rear view screen projector tvs I am trying to find a universal remote that would work perfect on it as we bought it from someone and didn't have a...
Generally universal remote controls won't work for all functions to any TV like its original remote do. Some functions may not differ, that is, if you try to up the volume, the tV's volume will go down, and so on. The most we can do is to try with other setup codes for the tV brand with the remote control, and synchronize it, check the functions, and accept a code which will give you most of TV's functions alright. I hereby attaches setup codes for Hitachi brand TV' both 3 digit and 4 digits. Try them, and see which code suits to your TV the most.
Three digit codes for Hitachi are: 001/ 004/ 009/ 013/ 059/ 061/ 079/ 088/ 091/ 137/ 139/ 140/ 141/ 142/ 143/ 144/ 145/ 146/ 179/ 210
Four digit codes are: 0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 22, 2012 | Televison & Video
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
How to program remote to dish? 4.4 IR/UHF PRO
Your question is not clear as to whether you want to program the remote to your TV or the DISH receiver. Here are steps for both if this has not been resolved already!
DISH RECEIVER::
1. Go to the room where the receiver is located. With the remote for THAT room press menu twice. (This will be the remote with the Green 1 on the bottom.)
2. Press and release the SAT button on the top left of the remote
3. Press and release the black and red record button 3 times
4. Look that the number next to remote address (secondary Remote address) has changed.
5. If not, start again.
TV::
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Aug 13, 2011 | Universal Remote Control DISH Network...
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Front panel locked by accident- no original remote, only universal, code unknown. tv has since been turned off by unplugging, now it won't turn on. remote has also been unprogrammed because batteries were...
Hello
Three digit universal remote code for RCA are:-
000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Four digit universal remote code for RCA are:-
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
Other ways to unlock RCA tvs
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
Nov 22, 2010 | RCA 27R410T 27" TV
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
MagicSing EG-18000 TV picture
i believed the problem is the TV mode. (NTSC or PAL mode)
try this
turn mic OFF
press and hold 8 then press power buton (PAL to NTSC)
or
turn mic OFF
press ang hold 9 then press power button (PAL to NTSC)
customerservice@magicmic.com
Sep 05, 2008 | Magic Sing Along Consumer Microphone
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Televison & Video Logo
83 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
