Question about KitchenAid KUDS30IXBL Builtin Dishwasher
Our cancel/drain light is on and will not go off (Even tried turning off and on the circuit breaker) We cannot get any other buttons to work with the light constantly on.
    Champion:
  • KitchenAid Expert
  • 220 Answers
Called a stuck key on the keypad under the door the is panel behind this panel should be service sheet if this is a newer model should show procedure to test for a stuck key
Posted on Apr 07, 2015
How can I restart my dishwasher
Press and hold the start button for a few seconds. The dishwasher will drain and reset
Aug 30, 2016 | Bosch Dishwashers
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Kitchenaid dishwasher kuds30ixssa has pump running but have no lights on control panel with door closed.
Did you have a power outage recently? They are notorious for damaging circuit boards--usually about 3-4 weeks after the power interruption strange things will either start happening or *not* happening with appliances due to damaged computer chips on the boards starting to fail. Your symptoms indicate either a blown user interface(push button panel) or a defective main control board(board with the brains on it) or both!
Aug 11, 2015 | KitchenAid Dishwashers
Clean light is flashing 7 times, stops and flashes again. Can't make it started anymore.
my whirlpool is doing the same thing. I'm trying to find a wiring diagram with not much luck. A work around I use is to turn the breaker on the fuse box off for 5 seconds then back on. The dishwasher then works for one cycle.
Aug 09, 2015 | Whirlpool Dishwashers
My whirlpool was stuck on the Lock switch. we used he cancel button but now it wont run. the fill light come on but nothing happens. I have tried unplugging it to reset the panel, but nothing helps
Double check there is power at the outlet. If no power, check circuit breaker box. If the circuit breaker "pops" after resetting, you have a serious electrical problem in the washer or wireing to the washer. Consider the age of your washer, cost to find a lightly used working replacement, vs the cost for repair tech. Ask for an approximate repair visit cost.
Jan 20, 2015 | Whirlpool Washing Machines
Dishwasher will not drain
If you can close the door, turn the control to drain and, can hear the motor running; you have a clog under the pump screen in the back of the Dish Washer preventing the pump impeller from turning
if you hear nothing: reset the house circuit breaker.
to fix: while the DW is on turn off the DW house circuit breaker then remove the pump screen and, remove the broken glass etc. from the pump then: repower and, test.
May 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Drain pump won't turn off, all lights are blinking
Try pushing the cancel button. Try holding the cancel button down. If it'll let you select a cycle, try running a cycle. Try putting a large volume of water in there. It might either clear the pump or it will "see" the water going out be satisfied. If it remembers the cycle you last ran, or which cycle you usually run, run a cycle that it's not used to. That helps clear the computer some dishwashers. Failing that, try turning the circuit breaker off for a minute. Press every button on the dishwasher. There's a chance that that will help drain any power stored, making the computer forget what condition it was in. Failing that, try turning the circuit breaker off or for a day or two. Failing that, if you know what you're doing and you're not worried about voiding the warranty, open up the control panel where the main circuit board is. We can assume that if it remembered this cycle with the power turned off for a while that there's a battery in there to keep from clearing the memory. Find the little button cell battery and take it out for a few minutes. Then put it back in and turn the power on. There may a reset button hidden inside there or somewhere else on the machine. Find the manual at home or on the internet and look in the troubleshooting section. There might be a specific button combination to clear that condition.
To keep this from happening in the future, pick up and install a dishwasher air gap for around $15. It's really easy and keeps water from backing up into the dishwasher. They're actually required in a lot of cities.
Sep 15, 2009 | Asko D1706 Built-in Dishwasher
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Feb 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid KUDS30IXBL Builtin Dishwasher Logo
168 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
