Question about Pool & Spa
Need to trouble shoot hottub 850 controller (6600-092) No power across heater terminals - new heater. temp sensor and high limit at ~ 30Kohms. flow switch good. transformer good.
I'm not just going to spend 500 for new PCB board. I would like to know if anyone has a procedure for testing the relays K1-K3?
  • 1,631 Answers
When everything is connected, and your heater is not heating, is the heat indicator icon active on the topside control panel? Indicating to the user, that the tub should be heating? If it is not, then you have a sensor issue, because the circuit board is not sending power to the heater relays. And hence No Heat!
if the icon is active...
if so, then you are possibly correct in thinking that you could have bad heater relays on your circuitboard. It is A good possibility that they are bad, as it is a common situation that we see in the field. Unfortunately unless you are a circuit board rebuilder, or you know how to de-solder and re-solder, new relays, you have to purchase a new circuitboard. If you are up to some experimentation, and would like to do it yourself, this link may provide you an avenue to obtain such relays?
Spa Relays Ez Hot Tubs
if I was on site, this is what I would do...
  • Turn power off to the hot tub.
  • Disconnect the wires off of the heater element.
    • Or the two wires that go to the heater element, will be disconnected off of their related relay.
    • Reason... I want to isolate both lines.
  • I will not power up the spa, and create a demand for heat, or create a heat call.
  • Once I have confirmed, that the system itself is telling the user that is heating, by illuminating the heater on Icon, I will continue with my test.
  • I will now test each heater line to the "other" hot line connection. So that I will be reading, and looking for 240 V. 1 meter lead will be on a heater relay, and the other will be placed at TB 1, the terminal block where the power is coming into the spa.
  • This test will provide me the information of which really is bad.
  • Not that often that both relays, that provide the power to both heater terminals, will be bad.
If you find that only one really is bad, comment back on this thread, and I will continue to assist you.
Posted on Apr 14, 2015
2 Suggested Answers
SOURCE: PUREX TRITON MINIMAX 400 Pool Heater Control Board
DId yo find the problem? My heater is doing the same thing.
Posted on Jul 28, 2009
Hotspring hottub heater not working
replace heater element inside tube under control panel or check temp sensor if calling for heat bad element
Nov 28, 2015 | Pool & Spa
Need help trouble shooting heater problem
Yes this is your Hi Limit (High Temperature) sensor.
This is a safety device so replace it.
On most DreamMaker spas the Temperature Hi Limit sensors share the same 4-Wire plug, you will have to replace both.
If your sensors have a telephone style plug you can replace the Hi Limit with out replacing the Temp sensor.
Feb 07, 2012 | Dream Maker Spas Pool & Spa
Hi, my Hydroquip powered spa is running continuously but not heating up to the proper temp. All 3 small lights are blinking continuously. I havn't been able to find any trouble shooting info. Thanks for...
Check for power at the wire terminals. If you have power then you probably have a bad element and will need to replace it. If not your temp sensor has probably gone bad.
Nov 27, 2010 | Hydro Quip Inc HEATER ASSEMBLY FOR VERSA...
Pentair MasterTemp 400 Heater Will run fine for about 1-2 hours then the service heater light comes on and the control panel is completely locked up. I can only reset by cutting power to the machine, where...
This reminds me of some of the High temp sensors ive replaced. I would start with checking the pumps flow to the heater. Make sure there are no abstructions and at least 35 GPM (gallons per minute) running to the heater. If your flow is too low, you will trip the high limit sensor after a short while.
This could also mean you need to clean out the heat exchanger. When an exchanger gets dirty, it blocks the flow of water, slowing it down and "super heating" itdue to the water being in contact with the exchanger for too long. This will also trip the high limit and call for service.
If both the above items check out, contact me @ adamh@newconceptchem.com and I will guide you further.
Nov 23, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
I TURNED ON POWER TO MY NEW ELECTRIC WATER 40gal MODEL # GEM402 AFTER FILLING WITH WATER. WATER WOULD NOT HEAT UP. CHECKED THREMOSTATS BOTH WERE PRSET AT 120 CHECKED POWER,BOTH HOT WIRES HAVE 124 VOLTS TO...
The controls of electric water heaters are designed so that at no time are both the top and bottom heating elements energized. Nearly all electric water heaters of this capacity in the US & Canada (other places, too) operate on 240 Volts.
When the water in the tank is below the set point of the thermostat (in your case - 120 degrees), the top heating element is expected to be on - (unless there is an issue with the top thermostat or limit switch). The top most control is the "high temperature limit". It is identified by the reset button on it. Make sure this isn't tripped by depressing the button. If it clicks - it was tripped and should start to make hot water at this point. If not tripped, you should check for the presence of 240 Volts between the heating element terminal screws. Do not measure from ground to a terminal screw and believe 120 Volts is "good". To make heat, you need 240 Volts - not 120 Volts measured across the terminals - not to ground. The amount of heat created running at 120 Volts is only 1/4 of what it will do at the correct voltage.
If you don't measure 240 Volts on the top element, check the bottom element in the same manner described for the top element.
If unable to measure 240 volts on any element, either there is a problem with the power source (blown fuse or circuit breaker), high temp limit switch, or thermostat(s).
If 240 Volts is present on either heating element, and water is not warm / hot in 30 minutes or so, a defective heating element is suspect. You can change controls without draining a tank, but replacing elements will require draining the tank first. Do not power the water heater without first filling it.
You can read a very detailed "how to" article about checking water heaters here.
I hope this helps - and good luck!
Nov 04, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Reads OH but still cold
you either have a bad temperature sensor (check the wires for damage) or a bad circuit board. I would recommend replacing the temp sensor first. If that doesn't work, pull the board and take it and have it tested.
Mar 18, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
What does oh mean on hot tub a cal spa
'OH' means 'over-heat'.
Basically the high-limit temperature sensor has detected a temperature far in excess of what it should be.
Check the filter(s), water flow, pump etc....
Regards,
Ian.
http://hottub.synthasite.com
Jan 26, 2010 | Coleman (5040B750) Patio Heater
My new heater does not work on my hot tub. I have a Jacuzzi Z135 Model s2600000 with a Controller version r574 and a Balboa 58028 that has been replaced by the 53349 heater (4 KW, 1 PSI set Pressure...
Test across both terminals at the same time. If you are getting 230V, disconnect power and check the resistance across the terminals. For 4kW, you should get roughly 13 ohms. If not, the element is bad.
If you get 0 Volts across the terminals, the tub is not heating. ManyBalboa packs switch both leads to the same leg of power, so you can get 120V to ground from each terminal, but you get 0V from terminal to terminal.
The clincher here is that the "heater on" light is off. I would double-check the pressure switch. You should test it with the tub running in heat mode. Disconnect one of the flag terminal leads from the switch, THEN test for continuity across the terminals. If you get none, you have either low flow or a bad pressure switch. You can verify by jumping the two wires together and see if the "heat" light comes on. Again, check for flow. I would run any of these tests with the filter removed. The symptoms you describe are very commonly caused by a dirty filter causing low flow. Again, pressure switch test. A bad sensor would cause the "current temp" to read too high, and a hi-limit problem would cause the little "heater-on" light to flash. Unless that little light is just dead (I've never seen it go bad), everything you say points to the pressure switch (or a dirty filter).
Nov 30, 2009 | Jacuzzi S750000 Black RapidHeat In Line...
No heat sensor
you need a new high limit sensor for your control box. What is the model number of the control box?
Jan 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Heater not working
ALL ELECTRIC HEATERS HAVE LIMIT SWITCHES THAT KILL POWER WHEN A HIGH TEMP IS REACHED YOU COULD HAVE ONE OF THOSE LIMITS GOING BAD OR IT COULD BE THAT YOUR FAN IS NOT PRODUCING ENOUGH AIR FLOW ACROSS THE HEATER TO KEEP IT FROM OVER HEATING THE LIMIT. PLEASE DESCRIBE THE NOISE YOU HERE
Dec 19, 2007 | Heating & Cooling
Pool & Spa Logo
134 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
