Question about Polaroid TLAC-02255 22AA€A LCD TV 1920x1080, 60 Hz, HDTV, LED Backlight
How do i use as a pc monitor?
What settings?
  • 1,087 Answers
Well if you have an HDMI output on your pc you can use that or if the TV has a VGA input you can use a VGA cord and select your TV input to PC
Posted on Apr 07, 2015
Can't set it up
If your monitor is only monitor just connect it with vga cable connector at the back of the monitor then goes through at the back of
pc unit.
however, if the monitor;TV/Monitor you need to use the supplied remote of the monitor set it on pc display same procedure in connecting monitor to pc unit.
Nov 09, 2013 | Liquid Video A170E101 Monitor
No input signal recommended settings hp vs15 monitor 1024x768 60h
old monitor 1280 x 1024
power light on?
OSD work?
if it said on the screen no input sig, then that is 100% true
the PC is not sending output.
check the video cable connections both ends
then if bad, boot PC to safe mode. does that work.
then maybe you set the PC graphic resolution too high for the monitor. use safe mode to set new , legal resolution
1280 x 1024 is max, do not exceed, the horz, vert, reso to the left here. if you do the monitor , will display, out of range. errors.
im confused, you show HP monitor then Sam.
why ?
my guess is HP question posted in SAM section.
so here is my HP answer
1280 x 768 @ 75Hz
if your PC or other device exceeds any of those. this old monitor
will go blank.
HOR, vert and refresh rates max.
to solve this riddle, set the PC to
1280 x 768
then connect monitor and bingo.
but there is a chicken and egg deal here.
if the display car is over this, as most new systems are.
then use safe mode to set the resolution to 1280 x 768
and reboot to normal mode.
boot and it F8 , safemode.
Sep 25, 2013 | Samsung SyncMaster 960BF (White) 19" LCD...
Monitor says no signal but it works on my pc
Check the settings on monitor for "input" most of these have multiple input settings and make sure your pc output is set to "mirror"
Jan 05, 2011 | AOC 19LVWK LCD Monitor
My HP Pavilion 1903 monitor keeps going to sleep every time I turn it on
check in your monitor menu to ensure there is no energy save mode set. press the menu button on your monitor and check the settings. ensure that your pc also does not have an energy save setting set. e.g if the mouse or keyboard are not touched for a specific time e.g. 1 minute then switch off monitor to save power. make sure that such settings are not switched to on in your pc settings. if this is a new monitor and this was not a problem with your old monitor then suspect the monitor settings if the monitor and pc are both new. then suspect both settings. if possible test the monitor on a second pc or laptop to see if problem persists.
Dec 11, 2010 | Computers & Internet
My monitor's color is messed up, when i start the computer all the icons and background are colored normally, after a few seconds it all goes to just about black and white. im sure it has to be settings of...
your monitor's backlite circuit board is gone, it's not able to sustain the signal from the PC
change the monitor and checkm else connect the faulty monitor to another PC and check.
because if it's settings, then the setting reside inside the HD of the PC, so if you change PC then the monitor should pick up the setting from the new PC and vice versa.
Dec 06, 2009 | Sony SDM M81 18.1" LCD Monitor
Monitor Resolutions Menu Pop ups
Please disable this notification from settings menu of monitor. you should find it under settings or notification menu which can be accessed via switches on monitor.
Jun 14, 2009 | E-Machines eMachines Desktop PC
Cannot stop monitor adjustment box from comming up every minute or two ,very annoying,please help.
A few suggestions.
1. check all cords- plugged in to computer, plugged into monitor- no bent pins etc..
2. Virus scan
3. Restore computer to a time before this problem ocurred.
4. A warning - Selecting incorrect monitor settings may damage some monitors. For information on the settings your monitor supports, see your monitor documentation.
I suggest that you adjust your monitor settings. you can right click on your desk top, go to properties, select settings, and advanced. I suggest that you make small minor adjustments.
Mar 27, 2009 | Acer Aspire™ T180 PC Desktop
HDTV as pc monitor-no digital signal
Try different Resolutions/DPI and Refressh rates the other possibility is settings on the monitor check the manual of the monitor for use with the pc as in resolution etc.
Newer monitors oftem change there own settings to best suit themselves or act differently if forced to use different settings.
The returning to 16bit seems odd though only other suggestion is trying updated video card drivers from the vendors site.
Mar 18, 2009 | Computers & Internet
Out of frequency range set low resolution or refer monitor manual
TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
Feb 06, 2009 | Compaq CV 7500 17" CRT Monitor
Brightness issue
hi, try recycling the power, unplug the power and vga cable and leave it out for some time, then check.. let me know
Dec 05, 2007 | Acer AL1916W 19" LCD Monitor
Polaroid TLAC-02255 22AA€A LCD TV 1920x1080, 60 Hz, HDTV, LED Backlight Logo
70 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
