Question about Emerson Audio Players & Recorders
Emerson Model RP625-1 Played good on D/C current then faded out to not playing at all now does not power up
Casio LK-100 keyboard is turning off often when chords are played, esp in lower octaves - seems like a short. Where might the short be - way to fix without taking the whole keyboard apart?
Sounds like a lack of power from the external "wall wart" power supply. Is it the correct one that can supply enough current for a chord to be played? (a chord will play more notes at the same time & pull more power from the supply in order to make the sound(s)) If it's the correct power supply or one of the correct current rating check the cable & the connector both at the end of the cable & where it plugs into the keyboard. Perhaps the lead has been tugged accidentally? / Damaged in some way? Turn the volume down a little & see if that helps - that will confirm the power theory :-) Good Luck!
Jan 17, 2017 | Casio Music
Picture color is fading
If it is fading on all screens (menus included) then it is the picture tubes. If it only fades when source is played, it is the tuner electronics.
Oct 30, 2013 | Sony KP-53V75 53" Rear Projection...
Ov4-1600 When i play at loud volume, the amp shuts off or fades in and out . All lights shut off as well when sound fades, wiring is good and no shorts... Help me out....
If you are 100% sure that you have checked all the wiring, this is usually due to not enough current reaching the amp. Make sure you are using the right size power wire (4awg) and that the power and ground connections are solid. This could also be due to a bad ground to the chassis.
Mar 10, 2011 | Power Acoustik GOTHIC OV4-1600 Car Audio...
I have cd mix 2, i lost the power cord, and i used a different 12v cord. The mixer played for a while then the power went off. I checked the fuse at the power supply it has continuity.
may be you unintentionally provided more voltage or current to the appliance and it has got damaged because i feel that if it played at first and then stopped then it might have got damaged due to overvoltage or excess of current .I would highly recommend you to take it to a technician for repairs as repairing burnt out is really complicated they might need to check the complete integrated circuit
Dec 06, 2010 | Vacuums
Color fading? is it the convergence?
I thought that I had the convergence dialed in . I played my xbox through it and it was looking good . I unplugged everything and put it up on stand and it wouldnt come on . Power button turns red then blinks 9 times but wont power up.
Oct 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Dec 18, 2007 | JVC AV-56WP30 56" Rear Projection...
Emerson TV won't stay on
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Nov 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Emerson ewc1302 13 in. tv/vcr combo problem
We had that same problem. Try a VHS head cleaner. Worked for us.
Oct 24, 2007 | Emerson EWC1303 13 in. TV/VCR Combo
Fading light problem
need more info but sound as a power regulator problem..good luck
Jul 26, 2006 | Apex Digital AD-1110W DVD Player
130 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
