Question about FocalPrice MX Google Android 4.2 Dual-Core 1.5GHz HD TV Box with RJ45 LAN Port, Built-in WIFI N Module
Got sound, but no picture & cannot get into setting, help
  • 711 Answers
You can try using the RCA connections as it sounds as if hdmi is switched off.this will be the yellow plug into a scart socket adapter.
if you are still having connection issues try a different hdmi cable and or reset the box using a paperclip near to USB sockets.
Posted on Apr 13, 2015
Why does my tv have sound but no picture?
you should be getting both sound and picture..check the video cables in the back and make sure they are plugged in correctly...if this doesnt help, try messing with the settings on the remote...and after that it may be a component problem(picture tube blown, etc.
Sep 08, 2014 | Televison & Video
LCD Samsung tv no picture no sound
Try to unplug set and a box if used from power for several minutes and then power back to see if a reboot will help or not.
Dec 10, 2012 | Televison & Video
Picture but not sound on my Fujitsu Plasmavision. TV used to be hooked into a control 4 system that handled sound but now no system is attached. Help! Tried adjusting the sound settings for a while last...
Picture but not sound on my Fujitsu Plasmavision. TV used to be hooked into a control 4 system that handled sound but now no system is attached. Help! Tried adjusting the sound settings for a while last night to no avail.
Apr 14, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Good picture, no sound
hello, if you have a good picture then your set is serviceble make sure you check all your options and audio set up settings before you go futher, with this symptom your set displaying fine and sound not coming trough it could be a fualty sound board module this board is identified by aquiring a service manual and then using the schematic drawings location the board that controls sound, i would then find this board online at auction or parts site and have it exchanged. hope this helps
Jun 04, 2010 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
"snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
Aug 24, 2009 | RCA F27442 27" TV
Sound but no picture and then tv turns off..
Your symptom is that you have no picture but you have sound. And then the sound cuts out.
Sony Televisions have a circuit that blanks the video when there is a problem generating a picture. There may be something damaged in the video circuit, or in the video drivers on the CRT boards. Worst case scenario, you may have bad CRT’s in the set.
No matter which is the case, I would recommend that the set be looked at by a qualified technician.
This person could run some checks and lead you to a repair.
I could not recommend that you repair the set yourself.
There is a high risk of electrical shock when dealing with picture tubes and projection sets, as they have tubes that will hold a charge like a capacitor. This charge is around 30,000 volts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this Solution with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 20, 2009 | Sony KP-46WT520 46" Rear Projection...
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
No picture
Yes there is a ballast that fires the lamp. If the lamp doesnt light the set wont turn on. What model set do you have?
Jan 22, 2008 | Televison & Video
No picture no sound
Last night i set childlock in my nikai ( NTV34010) tv set and tuned off by remote control.Then after some time later i tried to turn on tv but there is no sound and no picture.
will u please help me to solve it out.
Dec 02, 2007 | Panasonic CT-36D32 36" TV
FocalPrice MX Google Android 4.2 Dual-Core 1.5GHz HD TV Box with RJ45 LAN Port, Built-in WIFI N Module Logo
212 people viewed this question
Top FocalPrice Televison & Video Experts
john o grady
ray gallant
Are you a FocalPrice Televison and Video Expert? Answer questions, earn points and help others
