Question about Brother MFC 8220 All-In-One Laser Printer
Paper sticks in top feeder tray.
The top feeder tray is designed for only one sheet. I feed the one sheet in and it gets stuck in the printer toner drum.
    Problem Solver:
  • 17 Answers
I'm guessing by top feeder tray, you are referring to the manual feed tray.
If the paper is getting stuck midway into the printer, and you have taken the time to clear all paper jams, torn piece of paper, paper clips or staples that might act as an obstacle to the paper path, then usually the problem is a defective or non-operational optical sensor.
I had this happen to me on a Brother MFC-8840DN recently. I took some compressed air and pointed the air at what I felt was the area of the optical sensor. This helped blow the paper dust or loose toner powder from out of the optical sensor and the printer began working again just fine.
If you're not sure where the optical sensor is, after you have removed the toner cartridge and drum assembly, just spray compressed air over the entire area. You might wish to wear a dust mask or do this outside to prevent inhaling any paper dust or toner.
The small optical sensor usually has a small plastic arm attached to it with a flapper that moves in between a small "U" (The emitter and receiver are mounted in the sides of the U). This arm can get broken or jammed.
If cleaning the optical sensor doesn't work, then probably you will need to replace it. You can call Brother Customer Service at 877-436-2665 and see if they can give you the part number and sell you the part. If you can access the sensor, generally replacing it is pretty easy.
Let me know how it goes and please vote a Thumbs Up if you find this answer helpful.
Posted on Apr 07, 2015
  • Anonymous Apr 08, 2015
    Using a air compressor (thanks to my husband) I sprayed the inside of the printer and it is back to working like new. Thank you.
  • jobs2 Apr 09, 2015
    I'm glad to hear that it worked. Sometimes it's just a simple thing. Have a wonderful day!
Bl;ack streaks on paper
Pull down the manual feed tray door.
Load a few sheets of paper in tray 1.
Print something.
As the paper feeds into the printer observe it.
When the paper gets halfway in, open the top cover.
Lift out the toner and look down at the paper.
Does it have a black streak? If yes...change the toner.
If no...change the fuser.
Feb 22, 2011 | HP LaserJet 4 plus Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Canon MP730 Paper feed is not working correctly.....keeps jamming and feeds the paper incorrectly
    There are two feeders on this MP730. There is the sheet feeder on top and there is the paper feeder on the back. You can have problems with both.
    The sheet feeder on top.
    If the problem is things go through somewhat sideways, and if this is the problem, stuff some postit notes between the back grey thing and the feeder tray to eliminate this problem. Add or subtract to the wad to make it right.
    If the problem is it does not grip the sheet, what I used to do is to help it through by one sheet at a time, painful. I got frustrated with this so for scanning, I have a Snap Scan 1500, which is faster and better.
    The paper feeder.
    A small piece of paper left in the paper infeed path can cause a major problem. You cannot have anything in the paper path that will skew the paper, so you must get any little bit of restriction out of there.
    As the printer gets older, you will have to produce your own guides to prevent this skewing, as the guides on the printer do not do this well. I use clamps and wooden guides to keep things in line.
    May 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
    Paper stucked inside
    Open the top cover.
    Pull out the toner / developer units and look for paper under neath.
    In the rear, pull open the access door.
    remove the paper tray and look for misfed paper.
    Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
    Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
    Paper jams can occur in the following areas
    1 Top cover and toner cartridge area
    2 Optional envelope feeder
    3 Input tray areas
    4 Optional duplexer
    5 Output areas (top and rear)
    6 Fuser area
    Solving repeated paper jams
    * Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
    * If using a duplexer, check all areas (including under the duplexer).
    * Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
    * Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
    * Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
    * Try printing to a different output bin.
    * The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
    * If you are printing from tray 1, try reducing the size of the stack.
    * If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
    * If you are printing small sizes, feed paper short edge first.
    * Turn over the stack of paper in the tray. Also try rotating the paper 180°.
    * Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
    irregular paper.
    * Avoid using paper that has already been used in a printer or copier.
    * Do not print on both sides of envelopes or transparencies.
    * Print only on full sheets of labels and do not print on both sides of label sheets.
    * Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
    * Clean the printer (see the online user guide procedures).
    Hope this helps.
    Please rate my response.
    Thanks
    Have a good day.
    Dec 09, 2009 | HP LaserJet 4100 Printer
    Miss feeds when print multilpe pages
    The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
    Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
    Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
    Hope this helps....
    Explanation of the paper jam message
    A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
    NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
    Clearing the jam
    To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
    Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
    NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
    For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
    NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
    Remove any jammed sheets of paper you find and try printing again.
    Dec 12, 2008 | Lexmark T640 Laser Printer
    I have a Lexmark X3550 printer There is a paper way down inside that cannot be reached Tried the automatic remove and it does nothing. What should I do?This machine is only a few months old.
    Bending the bottom exit tray will allow it to be removed. Simply remove tray and wipe rollers right in front of the bar that the ink slides back and forth on. Most printers get a lttle dust on the rollers then they wont feed. Hope this Helps.Sincerely Brian @ Game-On Computers.
    Apr 26, 2008 | Office Equipment & Supplies
    Automatic Paper feed
    Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
    Sep 06, 2007 | Samsung ML 1210 Laser Printer
    Document feeder
    Try clean with alchorol those rols what feed those sheets. I'm sorry my English . But try clean. or some think stuck the paper on tray Aleixo
    Sep 05, 2007 | Canon imageCLASS D780 All-In-One Laser...
    Brother MFC 8220 All-In-One Laser Printer Logo
    54 people viewed this question
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Samyfam
    Samyfam
