Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
It turns on and off by it self. change the power board with new one and its does the same thing. it stay on for about hour then truns off then few mins later it trun back on please help.
    Sergeant:
  • 395 Answers
First try a firmware update from the manufacturer's web sight (look under support heading). you can do this yourself. if that doesn't fix the problem replace the main board.
Posted on Apr 07, 2015
    Sergeant:
    Champion:
  • Sharp Expert
  • 243 Answers
Press Power + Vol Down button from LCD TV "k" will appear on screen after that press Ch Down & Vol Down at a time from LCD TV. Go to 10/9 page by remote and run EEP Cleared.
Posted on Apr 21, 2015
    Genius:
  • Sharp Master
  • 1,689 Answers
If the set was working okay when new, and this fault happened over time, then this must be from something that has failed on one of the circuit boards. This may not necessarily be from the power supply itself.
Most likely one of the boards has a component that is failing and causing the protection in the power supply area to do a reset of sorts. The only way to find this is to try each of the boards until the fault is determined. In rare occasions there can be more than one board faulty to cause this. The service rep would try each of the boards until the fault is found, and then leave the working board(s) in the set on test for at least 24 hours. After that they would give the estimate to the customer.
Servicing these new generations of TV sets out of warranty can be fairly expensive. If the set has a number of years of use and is out of warranty it is usually a better option to replace the set than to service it. After one of the boards fail there is odds that other boards could soon fail. The MTBF for most of these sets is in the range of 40,000 to 50,000 hours depending on the model and specs. This is equivalent to about four to six years...
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: sharp aquos 46 picture disappears intermittently
it might mean there is an intermittent connection or cold solder joint somewhere inside the set.
But I wouldn't just settle on that.
Here are some other things to check:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Here is what I suggest:
ONE: Give it a hard reset. Possibly the software codes in the power management are corrupted. Just unplug the tv line cord for 4 hours. That will reset everything internally to factory defaults.
TWO: Give it the old whacking test. Just bang on the cabinet in many places with your hand or fist. That will restart any cold solder joints or loose connections.
THREE: If the above procedure does not help, then you will have to call in an expert tv tech; OR just live with it and put in a line cord switch so that when it is OFF, it is really OFF.
Posted on Jan 17, 2009
deltonsmith9
  • 96 Answers
SOURCE: truns on off by its self
what do mean you jus sitting there and it comes on how often does the tv do this
Posted on May 31, 2012
Samsung Savyy wont trun on. it blinks red
please use other samsung battery same as your phone if not the issue is on the phone it self.
Dec 20, 2013 | Cell Phones
Laptop - Chooses when to turn on.
have you tryed formating it somthig could be conflicting somwere down the line if you can get it to trun on press and hold F11 you will lose stuff off the computer as it restors it bk to factory settings
Dec 05, 2012 | Computers & Internet
Tablet will not stay on, only turns on by reset and will not let unlock screen.
SOFTWARE PROBLEM YOU HAVE TO GET THE MEMORY CARD OOUT OF THE BOARD FORMATT IT FULLY REPLACE SOFTWARE PUT BACK IN TAB DONE
Oct 12, 2012 | Coby Kyros 716829701508 Tablet PC
Can't get my system to boot up
The power mapping grid on the motherboard may be defective
Sep 15, 2012 | ASUS P8Z77 WS Z77 LGA 1155 ATX Intel...
Lexmark X5470 powers on and off constantly
I encountered the exact same problem with my Lexmark X5470. After a power failure on Aug 20, the printer would reboot itself every few seconds. I unplugged the power cord and/or adapter for a few minutes and after replugging, it worked fine. However, the problem returns after I power off the printer and then turn it back on, in which case I unplug again for a few minutes. Hope this helps.
Aug 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
Tv wont stay on channel
This TV actually has bad buttons I've seen many of them, usually those switches never go bad but on this tv they do. The easiest thing to do is remove them, and use the remote, who uses those buttons anyway. You can slide out the circuit board and you will see the small switches in front if you can solder just remove remove them if not you can cut them out just be careful none of the pins remaining in the board are touching one another.
Jun 19, 2007 | RCA 27F530T 27" TV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
104 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
