Question about Garmin nuvi 2599LMTHD 5" GPS with Built-In Bluetooth and Lifetime Map and Traffic Updates
Will not charge and actually seems to discharge when plugged in to auto charger
Used ALL Garmin items. Used auto charger from nuvi 1450 that worked fine w 1450 in same auto. stiil no charge
    Scholar:
  • Garmin Expert
  • 186 Answers
Charge the unit overnight with a high power usb charger, 2A or above. If it turns on after that, check your auto charging cable. It should have a red led that illuminates if it has power. If it does not, then it is either the cable or a fuse blown in your car. If the gps still does not turn on after chargning overnight, you have a batter issue. Amazon sells battery kits.
Posted on May 02, 2017
SOURCE: Garmin Nuvi 200
Guys go to
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=104952
http://pinouts.ru/GPS/garmin_nuvi_power_pinout.shtml
they have the answers
it seems a standard or phone USB cable will not work to charge and use the maps at same time
Good luck
Posted on Nov 15, 2008
SOURCE: Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Posted on Nov 17, 2008
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi Doesn't turn on
Try resetting the unit. The procedure can be found here:
http://www.sharc.net/discus/messages/6/313.html?1268661443
- Jim
Posted on Mar 19, 2010
SOURCE: Garmin Nuvi 250 stuck in mass storage mode
Make sure you have the rite charger. Garmin will only work with a garmin charger. You may have accidently picked up a blackberry charger or something. Hope this helps
Posted on May 21, 2010
SOURCE: I have a Garmin Nuvi
I had the same issue on my 1450 except it just would not power on anymore, even with a full charge. A soft reset will preserve your Home, Favorites, POis, etc. Leave the battery in the unit. Hold down on the lower right of the screen while holding down on the power button. After 20-30 seconds, you should see the Garmin splash screen. Have your PC/laptop ready with USB cable. Get the latest Map update downloaded and installed or just start using the unit again.
Posted on Dec 09, 2010
Tip
Garmin Nuvi 1450 Favorites Backup and Restoration Procedure Models: Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Would you like to back up a copy of your Garmin Nuvi 1450 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
______________________________________
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Webupdate
Garmin Nuvi 1450 Hard Reset
on May 27, 2010 | GPS
The limited directions tell me to charge my Garmin 1450 for at least 4 hours. How is that done without a charger? Will it charge with the computer cable? It seems that your site will not allow me to...
The nuvi will accept a charge when connected to a computer if the computer connection is done through a powered USB port.
Garmin part number 010-10723-00 which is an AC power adapter is also available for charging the unit.
www.gpscity.com/garmin-nuvi-zumo-international-ac-adapter.html
Sep 14, 2011 | Garmin nuvi 1450 GPS Receiver
Just bought a nuvi 1450. missed setting the country as USA. now it is in a foreign language (Uraguay, I think) and I cannot figure out how to reset it
Go into tools setting to language and set to American English and hit restore. Then I would go to the Garmin site and update your 1450. Make sure it is fully charged first, I will attach the like to Garmin.
Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 20, 2011 | Garmin nuvi 1450 GPS Receiver
Tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1450 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
________________________________________
Tip
Download Garmin Nuvi 1450 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1450 GPS?
Would you like a digital copy of the Garmin Nuvi 1450 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1450 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1450 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1450 GPS?
Would you like a digital copy of the Garmin Nuvi 1450 Users Guide for easy searching of terms and quick reference?
The Nuvi 1450 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1450 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
on May 27, 2010 | Garmin nuvi 1450 GPS Receiver
Tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Garmin nuvi 2599LMTHD 5" GPS with Built-In Bluetooth and Lifetime Map and Traffic Updates Logo
57 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
