Question about Bose CineMate GS Series II Speaker System
Seems the remote stoppd wrking I chngd batts & unpluggd all & re-plugged. get a blinking green light on small box for seconds when I plug it in but then it stops. can't get solid green? Don't get red?
    Genius:
  • Bose Master
  • 1,054 Answers
Is it a series I or series II? Easy way to tell is the series II will have an optical input on the back of the control box. If it is a series I, then your control box has probably gone bad - very common problem with this unit.
Posted on Apr 07, 2015
    New Friend:
If it's blinking green it means it's on mute. Unmute it and you should have solid green. It doesn't turn red.
Not communicating
make sure red 4 pin plug is plugged in and not loose if ok then open up the antenna box see if red and green lights are blinking shut everything off then turn back on then turn on PDA see if lights are blinking should connect
Oct 20, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I have a mitsubishi model WS-55511. The green light keeps blinking. Have reset by unpluging and then pluging back in and holding the reset but for 5 seconds and press the power button. worked once, but...
TWO possible reasons for the blinking light:
1. The DM unit (caps and or fuses) are bad---no longer made and only (to my knowledge) PTS electronics repairs/rebuilds them.
2. Less likely but Possible: remove front speaker grill and inspection plate behind it----locate the two bundles of wires from front keyboard on set and follow them down and to the right---unplug both plugs and plug set in and wait 70 plus seconds and try to turn set on with Mitsubishi remote.
The blinking light is the DM trying to boot up--if set works with front keyboard unplugged---the tiny reset switch on it is bad.
If set does NOT work that way DM UNIT IS BAD.
SD TECH
May 03, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My Mitsu Ws48511 green light blinks for about 2 minutes then stops. After another minute, it begins to blink again. It continues this until I unplug the tv. Then it often blinks for up to 8 hours before...
First: the blinking green light means the set has a DM unit in it. It should when unplugged and plugged back in blink for 70 seconds and then go out.
One of two things is wrong here:
1) The DM unit (large metal box on the left as you look from the back) has several capacitors and fuses that can fail.
2) Try this: Pull front speaker grill off: held on with plastic pegs.
Remove the inspection plate you will find in back of it.
Note the two groups of wires that come from the front keyboard; follow them down and to the right and unplug the two plugs you find; most have two and they are different sizes and marked so you cannot get them wrong.
The idea here is to disconnect the entire front keyboard and the reset switch from the set.
You can still turn the set on with the remote.
If the set now works--you have two choices----use the set with a remote and the keyboard not connected.
Remove the entire screen assembly and remove and or replace the reset switch.
IF DISCONNECTING THE KEY BOARD DOES NOT CURE IT--the Dm unit is bad---either change the four caps--lots of sites sell kits for this OR send the entire DM unit out for repair/rebuild to someone like PTS ELECTRONICS.
THE BLINKING GREEN LIGHT IS THE DM UNIT TRYING TO BOOT UP--LIKE A COMPUTER.
iF THIS INFORMATION TOLD YOU SOMETHING YOU DID NOT KNOW, rate this solution as very helpful as I do this here for free.
make a comment here if you need additional help---I am here to help.
REGARDS, SD TECH
Aug 15, 2010 | Mitsubishi WS48511 48" Rear Projection...
Sony kdf60655 green light blinking 37 times and pic goes off/on
I am having the same problem and we purchased the tv new in April of 2005 had the four yr warranty also. That's obviously passed and now we don't know what to do? What did you find out?
May 04, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Battery level
As Suzaku explained:
A battery icon will show up on the LCD screen of your camera when it is already low and needs recharging. It can be found at the lower right side of your LCD screen. The ready light of your camera will also blink red and your camera will turn off if the battery is exhausted.
NOTE:
The icon will not appear if the batery is sufficient and there is no TECH way of making the icon show until the batt needs charging.
Jan 04, 2009 | Kodak EASYSHARE M763 Digital Camera
Have mitsu model # ws-65813 wont turn on
You have a common problem in the DM (Digital Module), more specifically the DM power supply. There are four electrolytic caps in that supply 16v/1000uf that are bad and likely buldged from heat stress. Replacing these caps and the E2P module, a small stand-up board further back on the main DM board should restore normal operation...
You might be lucky enough to have a tech come out and simply replace those caps in-home. It's not a really big job for a qualified tech.
Hope this helps!
Bill
Dec 01, 2007 | Mitsubishi WS-65813 65" Rear Projection...
Bose CineMate GS Series II Speaker System Logo
467 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
