Low battery charged battery's step pedal to go noting it moved before charge
    Top Expert:
  • Computers & ... Master
  • 8,211 Answers
Could be the battery needs replacing,or check your charger.
Posted on Apr 07, 2015
3 Suggested Answers
VinayT
  • 1884 Answers
SOURCE: battery not charging
Either of the two reasons. The battery may be dead (most likely, depending on the age of the laptop) or the charger may be faulty. Both is unlikely as both of them could not have conked out simultaneously.
Posted on Oct 03, 2009
cjblackheart
  • 135 Answers
SOURCE: my sensr480 note book battery
Samsung laptops have this program called Battery Life Extender where this would allow you to choose your charging to 100% or 80%. 80% charging as the program says will lessen the ageing of your battery thus extending the overall battery life specially when your using youre laptop connected to AC more often.
I would guess that you might have activated that program if youre only charging at 80%. Have a look at it at youre programs and reply back.
Posted on Aug 07, 2011
I own a 2006 Ford Expedition XLT ADVANCE TRAC RSC 8CYL. The car starts fine , but when I put the gear in DRIVE mode and step on the gas pedal to accelerate, the vehicle doesn't move at all and the...
DO THIS FIRST, I GOT A F150 IT DID THE SAME THING IT TURNED OUT TO BE MY ALTERNATOR, GET THAT CHECKED BEFORE YOU DO ANYTHING ELSE, IT CAUSED MY COMPUTER TO GO HAYWIRE BATTERY RAN DOWN ALSO
Sep 14, 2011 | 2006 Ford Expedition
Tip
How to know a Good battery Equipments Needed Foreign & Local Booster Procedures...
Equipments Needed
Procedures to follow
Step 1: All good batteries are suppose to read 3.7 volts as inscribed on the battery body.
Step 2: When a battery is low with 0.0 volts and it's boosted with a booster, it will increase back to 3.7 volts.
Step 3: If you boost a low volt battery and it increases to maximum but immediately reduce to lowest after removing the booster, it means the battery is bad.
Step 4: If the battery has 1.0 volts or more and it cannot still power up a handset, it also means the battery is bad.
Step 5: You can also use a desktop to charge a battery that is low volted, but if it does not charge, use a boosted as a second option, if it still does not come up, then the battery is totally bad.
Note
You can over charge and discharge a battery by dropping it in a cold water or interchange the polarity of the booster.
An over charged battery might not power a phone.
on Jan 11, 2010 | Cell Phones
Tip
Prolong Your GPS Battery Life
Are you tired of having to keep your GPS plugged into the car for the entire duration of your drive? Does it die out instantaneously after removing it from it's jack? If it does, there nothing you can do to fix it because the battery had over heated and lost its battery life tremendously. I can only say that you would need to purchase a new one.
However, if your GPS doesn't die out right away, here's your chance to start prolonging its life. First, let it completely die out by turning it on, and leaving it on until it the batteries run out of charge. Second, plug the dead GPS into either a house outlet, or a car jack (if you are using the car jack, make sure the car is on!!!). Third, wait for the GPS to reach full capacity, but DO NOT let it overcharge, it kills the battery. So I recommend checking on the charging GPS periodically at even intervals of your choice. When it is done, just unplug it, and it is good to go.
NOTE: Do not charge the GPS in while in use.NOTE: If the battery is low as you are driving, turn it off and plug it in to charge.Explanation: This is why the steps above the notes are to be taken to prolong the life of your GPS' battery. 1 Complete Charge + 1 Complete Drain = 1 Charging Cycle
Thanks for reading my tip!
on Dec 04, 2009 | GPS
How do I charge the battery of my ACER note book PC? What is the correct manner to charge it? Should I always plug the Note Book PC into the main AC when I log on to the computer?
Yes you should when the battery is low.
You can check the amount of charge in your battery by -
Open Control Panel - Power Options - click on Power meter tab - un-tick Show power levels on each battery.
Apr 14, 2011 | Acer Aspire One PC Notebook
When I switch my camera on it will not focus - my
Did he drop it while it was being used?
Also, I assume that you have fresh batteries.
Why doesn't the lens retract when I turn off my camera or extend when I turn on my camera? Question : Why doesn't the lens retract when I turn off my camera or extend when I turn on my camera? Answer : The batteries may be low or exhausted.
NOTE: If the batteries run low on power, your camera may turn off without retracting the lens. In most cases, this is normal and can be corrected by recharging the camera batteries.
In the U.S. and other countries where the Step-by-Step Solutions and Repair tool is available:
  1. Recharge the batteries or install new batteries.
    NOTE: Rechargeable batteries can be charged in the following ways depending on the camera:
    • Remove the batteries and place them in an optional battery charger.
    • Place the camera in a printer dock or a camera dock.
    • With the batteries installed, connect the camera to an AC adapter or to a computer using a USB cable.
  2. For more information, go to KODAK Product Manuals, and select the User's Guide for your camera. To see the battery charging accessories that are available for your camera, go to KODAK Accessories.
  3. If the problem persists, go to the Step-by-Step Solutions and Repair tool.
    • Select Digital camera, camera dock, or digital video camera.
    • Select Lens.
In countries where the Step-by-Step Solutions and Repair tool is not available:
  1. Remove the batteries, then wipe the battery contacts with a soft, clean cloth.
  2. Install the batteries, then turn on your camera.
  3. If this does not resolve your problem, remove the batteries.
  4. Go to Choosing the Right Battery for Your KODAK Digital Camera, then follow the instructions to verify that you are using the correct batteries.
  5. Install new or fully charged batteries into your camera.
    • With the batteries installed, connect the camera to an AC adapter or a computer using a USB cable.
    • For more information, go to KODAK Product Manuals, then scroll down to select the User's Guide for your camera. To see the battery charging accessories that are available for your camera, go to KODAK Accessories.
  6. Turn on your camera.
  7. If the problem persists, go to Eastman Kodak Company Worldwide Contacts for assistance.
Jul 23, 2010 | Kodak EasyShare C875 Digital Camera
Tip
How To Prolong Your GPS' Battery Life
LIttle Tikes Hummer not working
Sometimes if the battery is not charged up and it sits for a few months then it is difficult to charge the battery. I learned this the hard way by keeping it out all winter without charging up. I called the repair tech's at this website http://www.shopjandl.com/kids---baby-ride-on-toys-little-tikes.html
they told me to charge the battery up for 18 hrs at a time, especially if it sat more than 3 weeks.
If the battery is good it may be the foot pedal in this link http://www.shopjandl.com/mepu0001.html
May 09, 2009 | National Little Tikes Hummer Yellow
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Battery charging
All lead-acid batteries contain highly corrosive sulfuric acid, generate explosive gases and have warning labels which should be observed closely. For best results, charge the battery as soon as you know it is discharged. To charge your battery, follow these steps and important safety tips: Before Charging: 1) Read the charger manufacturer's instructions. 2) Put on protective eyewear, rubber gloves, work clothes and remove all jewelry. 3) Place the battery in a well ventilated area. 4) Don't charge a frozen battery. Allow the battery to warm to about 60?F before charging. 5) If applicable, remove the vent caps and check the battery's water level and, if low, add distilled water to cover the tops of the plates. Do not overfill. 6) To determine if the battery needs to be charged, test it with a hydrometer to determine its specific gravity and/or with a voltmeter to determine its state of charge. 7) If applicable, reinstall vent caps before charging. 8) While the charger is unplugged, connect the leads to the proper battery terminals. Note: For side-post and studded batteries, we recommend that you use adapters to insure adequate contact. For additional information regarding adapters, contact Interstate Batteries. 9) Set the charger to the proper settings for your battery, e.g. 6 volts vs. 12 volts, low-maintenance vs. sealed, standard automotive vs. deep cycle. 10) Plug in and turn on the charger. 11) Don't wiggle the connections to check contact while the charger is turned on or plugged in. 12) Choose the lowest amperage setting initially. Once the charger is on and the battery is charging, you may want to choose a higher amp setting to reduce charge time. During Charging: 1) Keep the vent caps on. 2) Don't allow smoking, open flames or sparks near the battery. 3) Don't allow the battery to become hot to the touch. After Charging: 1) Immediately after the battery is fully charged, turn off and unplug the charger. Continuing to charge a fully charged battery will severely damage the internal plates and shorten battery life. 2) Disconnect the leads from the battery.
Nov 20, 2008 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
My iphone won't sync with itunes. it did at first but now keeps coming up with an error I have an original iphone, never been jailbroken or any such thing, and can not currently get it to sync with itunes...
Recharge
Make sure iPhone is charged. Connect to a USB port and look for the lightning bolt battery icon in the upper right. If you don't see this icon, then iPhone is not charging. The battery will charge to 80% in an hour.
Note: If you put your computer into sleep mode while iPhone is connected via USB, iPhone may not charge.
This screen means to keep iPhone connected so it continues charging. Please note:
If iPhone is not sufficiently charged it will not show up in iTunes
Use a high-power USB port such as the one on your computer, or use your iPhone AC adapter.
Don't use the USB port on your keyboard because it is a low-power port and iPhone will not charge.
Make sure you are using USB to charge. Accessories that use FireWire to charge are not supported with iPhone.
If you see the red part of the battery image flash three times and then the screen goes black, it means that iPhone is not receiving power to charge.
If the above steps dont resolve follow the following steps :
Retry with a different USB port.
Note:
Restart
Try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
Does iPhone appear frozen or stuck? Try pressing and holding the Home button for at least 6 seconds to close a frozen application. Then try restarting iPhone again.
Note: If that doesn't work, try restarting your computer.
Reinstall
Reinstall iTunes 7.7 or later.
Get the latest version of iTunes (7.3 or later) from http://www.apple.com/itunes/download/
Thanks.
Oct 21, 2008 | Lands Phones
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
