Question about Building Materials
Unit has two bulb one in front one in back. back bulb blows every 4 to 6 weeks. had unit long time no problems until 6 to 8 months ago.
    Top Expert:
  • 12,962 Answers
The strong vibrations of the motor quickly weaken the filament in normal light bulbs. They have special bulbs to withstand the rigors of the vibrations.
Posted on Apr 09, 2015
  • 2,184 Answers
Are using high vibration light bulbs? should solve the issue.
Posted on Apr 07, 2015
Bulbs keep blowing
You may be touching the bulb (ampule) and leaving a fingerprint on it which creats a hot spot and blows the bulbs up prematurely.
Mar 25, 2013 | Mitsubishi WD-65731 65" HDTV
Saturn sc1 3 bulbs burnt out at one time after I just replaced both headlight bulb
Hi Legalass, Condensation will be caused by water or moisture entering the head light unit. If the lens is cracked or broken or the cover are not correctly fitted that will answer that part of the question. I think for the second part of the question you should take the vehicle and have the voltage regulator output checked. It is possible that the alternator is being allowed to over charge and when it does, it may be blowing the bulbs! Regards John
Apr 01, 2012 | 2000 Saturn L-Series
I bought two HB-4190 Hampton Bay Lights a couple of years ago. All has worked well until the past couple of months. THe light bulbs now burn out withing weeks. The bulb in one of the units keeps...
if lights are haligen lights, you may be adding to the problem, never touch them after you have removed the lamps, do not use your hands to install them, oils from hands cause them to burn out quicker, use a cloth to install them do not touch lights
Aug 16, 2011 | Home
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
I have a Toshibal 50HM66 DLP TV. I purchased it about 4 yrs ago. It worked well for 4 months and the bulb popped, since then I've had to replace the bulb 3 times at a about $150 per bulb. The last bulb...
I have had the same problem and after several trips to the shop I realised it was caused by humidity. The shop was air conditioned so the problem never happens there. A dehumidifier or air conditioner "solved" the problem.
Dec 27, 2009 | Toshiba 50HM66 52" Television
Unit was used about 5 weeks ago running fine went to use the other day and no go the batterry is still full strength pump doesnt run nothing works i put a new pump in about 4 months ago
Blown fuse on circuit board. Take one side off, find the board. Fuse is water tight sealed. Remove the seal and replace fuse. This seems to be a rather common problem, but coleman doesn't give any help on it. There are only aprox 7 screws that hold the case together. One little one in under the decal on the front just blow the knob. THERE IS NO NEED TO TAKE THE KNOB OFF.
Oct 14, 2009 | Coleman Hot Water On Demand
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Paper is jammed in the transport unit
This unit does not require the proof of purchase until 3/2009, so if you take it to a service center and tell them that you bought it about 8 months ago, but can not find the receipt, they are suppose to take your word for it and repair it under the warranty. However if you sent in the warranty card with the serial number they may have it on file, however the service center can not access that info unless they go through tech support in Va. Most do not.
I hope this helps you out, and lets you keep your hair in your head. :-)
Nov 09, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Print
Check out these steps:
1. Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Check with a copy from the front panel of the All-in-One.
However, the issue might be with the low on ink.
Please perform the following steps:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Try to make a copy and get back to us with the results.
Regards,
Sagar
Aug 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Sony Wega kdf-55wf655 rear projection set keeps turning on and off
If picture quality is poor, be sure you aligned the bulb in the correct manner and be sure the cover for the bulb is not loose. Also, you might want to re check you picture setting as it might have gotten reset when you pulled the plug (I hope you pulled the plug when replacing the bulb).
Heres another solution (maybe temporary) to the problem of no picture and no sound for 30 seconds. I had my tv's power saving setting on "standard" before. After I switched it to "reduced", the problem was fixed. It has been almost two weeks without the problem. I think its a good fix until the new bulb comes in the mail.
Jan 18, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Building Materials Logo
57 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
