Question about Shoprider Mobility Products, Inc. Hero 3-Wheel Scooter with Swivel Seat and Curved Tiller Blue 1ea
Has NO reverse but goes great in forward help
    Sergeant:
  • 313 Answers
This sounds like the Wig-Wag could be at fault or the wiring to the controller.
Posted on Jun 16, 2015
The shredder only goes in reverse. I did oil it, but it doesn't work.
did you try to fix the forward problem by oiling it? That would be my first choice. The Forward and reverse switch would be my first thing to check to make sure the switch is working. Next would be the actual motor to see if it's getting power to go forward.
Oiling it won't fix the forward problem unless it was somehow stuck which would be unlikely since it goes in reverse.
Sorry I couldn't give you more help with this.
Good luck.
Mar 11, 2015 | Shredder Office Equipment & Supplies
My golden companion 2 Gc 321 goes forward when i push reverse and goes reverse when i push forward
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
Aug 12, 2014 | Golden Technologies Golden Companion 2 -...
My 9053 lifts off fine goes left right and reverse. but it goes reverse also when i want to go forward . Tail rotor turns at what appears proper rpm. and it changes direction when i push stick from reverse...
I own this heli also. The problem is that the tail rotor does not apply enough push to tilt the heli forward. It is this forward pitch that moves the heli forward. Aside form buying a stronger tail motor, upgrading your battery etc, the only thing you can do id this:
Get a credit card, a pair of scissors and some tape. Cut a couple of strips from the credit card about 2 1/2 - 3 times wider thhan the tail rotor blades and the same length. Now tape the strips to the top of the tail rotor blades. Make sure you don't increase the length.
This will help a little by providing more air push when the tail rotor in engaged. Without some serious modding, this heli will never be great.
I have more fun flying my micro size syma helicopter in the garage then I have flying my volitation. If there is even the slightest breeze, the volitation will float in the direction of the breeze and will not fly against it.
Apr 03, 2011 | xheli 9053 Outdoor Volitation Metal...
EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Apr 09, 2010 | 1993 Acura Vigor
When going forward the tines are going in reverse
I've never seen one of these so excuse my ignorance. Is it possible that the cable to change from forward to reverse is out of adjustment? Can you go to where the cable attaches to the shifting mechanism, detach it and manually try to change from reverse to forward? Hope this helps. Good luck!
Mar 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Goes reverse but, not forward
First of all let me tell you that i really enjoyed reading your question. and that i am in now way an expert on the electric cars but i do have my masters in automotive technology. My niece had the same problem whith her little electric car and we found it to be the forward and reverse switch. i hope this helps please rate mysolution
thank you
Apr 21, 2009 | Hummer H2 Cars & Trucks
2001 Dodge Durango transmission goes out?
it not moving could be a number of things check fluid level if thats good its an internal tranny problem dodges are known for tranny problems
Nov 13, 2008 | 2001 Dodge Durango
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Oct 14, 2008 | Garden
Shoprider Mobility Products, Inc. Hero 3-Wheel Scooter with Swivel Seat and Curved Tiller Blue 1ea Logo
163 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
