Question about NuVision NVU22L 10 Ft Hdmi To Hd Cable For
Im have trouble ouching the screen
It wont type my password and stuff I need help asap it ha ll my stuff on it that I use
How can I delete everything on my Macbook?
The only way to really, really clean it is to re-install the OS and do a 7-times wipe/formatting the hard drive. This is what the government recommends on their hard drives.
Now, if you're worried about doing this quickly, a 7-times wipe takes forever and requires you to have the Operating System on some type of install disk, which you may not have.
The best suggestion I would have for your situation is to go System Preferences> Users > create a new account (click the +, you may have to click the lock and type in an admin password). Create another account, delete your current account from the same screen within the new account.
Just realize that you'll lose most all of your settings and have to re-do it. No one should really be digging far enough in from here to find anything from the deleted account. It's possible to recover that type of thing, but it is beyond any likelihood that anyone will put that much effort into looking like that deep.
Nov 14, 2012 | Apple Computers & Internet
FORGOTTEN PASSWORD, LOST PASSWORD DISK, WHAT NOW?
try this one.....surely it'll work.
Use a Linux Live CD to Get at the Files
If you don't need access to the OS itself, just a few files, you don't need to go through much trouble at all. You can grab any Linux live CD and just drag-and drop files onto a USB hard drive, as you would in any other OS.
Full sizemedium.pngHow It Works: Just download the live .iso file for any Linux distribution (like the ever-popular Ubuntu) and burn it to CD. Stick it in the computer you want to access and boot up from that CD. Pick "Try Ubuntu" when it comes up with the first menu, and it should take you right into a desktop environment. From here, you can access most of the hard drive just by going to the Places menu in the menu bar and choosing the Windows drive. It should see any NTFS drives just fine.
Note that depending on the permissions of some files, you might need root access. If you're having trouble viewing or copying some files, open up a terminal window (by going to Applications > Accessories > Terminal) and type in gksudo nautilus, leaving the password blank when prompted. You should now have access to everything.
How to Beat It: This method can give you access to the file system, but its main weakness is that the malicious user still can't access any encrypted files, even when using gksudo. So, if the owner of the computer (or you) has encrypted their files (or encrypted the entire OS), you won't get very far.
Sneaky Command-Line Fu: Reset the Password with the System Rescue CD
If you need access to the operating system itself, the Linux-based System Rescue CD is a good option for breaking in. You'll need to do a bit of command line work, but as long as you follow the instructions closely you should be fine. Hat tip to our friends at the How-To Geek.
How It Works: Just download the .iso filefor the System Rescue Live CD and burn it to disc. Boot from the disc and hit the default option when the blue screen comes up. After everything loads and you're presented with a command-line interface, type fdisk -l to see the drives and partitions on your computer. Pick the Windows partition (usually the largest NTFS partition) and note the name, e.g. /dev/sda3.
Then, run the following command:
ntfs-3g /dev/sda3 /mnt/windows -o force
Make sure to replace /dev/sda3 with the partition you noted earlier. Next, cd to your Windows/System32/config directory with this command:
cd /mnt/windows/Windows/System32/config
We want to edit the SAM file in this folder, so type the following command to get a list of users:
chntpw -l SAM
Note the username you want to access, and then type the following command, replacingWhitson Gordon with the username in question.
chntpw -u "Whitson Gordon" SAM
At the next screen, choose the first option by typing the number 1 and hitting Enter. This will clear the user password, making it blank. When it asks you to write hive files, hit y and press Enter. It should say OK, and then you can type reboot to reboot the computer. When you boot into Windows, you'll be able to log in to that user's account without a password.
How to Beat It: Once again, the weakness of this method is that it still can't beat encryption. Changing the password will disallow you access to those encrypted files, which, if the user hasencrypted their entire OS, makes this method pretty useless. If they've only encrypted a few files, though, you'll still be able to access all the unencrypted stuff without a problem.
Brute Force: Crack the Password with Ophcrack
Where the other two methods are vulnerable to encryption, this method will give you full access to everything the user can access, including encrypted files, since this method relies on finding out the user's password instead of bypassing it.
How It Works: We've actually gone through this method before, but it doesn't hurt to have a refresher. All you need to do is download and burn the Ophcrack Live CD(use the Vista version if you're cracking a Windows 7 PC) and boot from it on your computer. It'll take a little bit of time to boot, but eventually it will bring you to a desktop environment and start attempting to crack passwords. This may take a while. You'll see the passwords pop up in the top pane of the window, though, when it finds them (or, if it doesn't find them, it'll notify you). You can then reboot and log in to Windows using those passwords.
Oct 21, 2012 | Computers & Internet
I want to bar the incoming call but whenever i am putting the password it is showing "password blocked" in tata docomo what is the solution. plz tel me
Namaste Guruji,
Guruji, try this site www.mobile9.com
Here you can get third party software for various needs for various mobile models and variants. These software include call bouncers, call recorders and also black list calls of only selected numbers that you don't want calls from. All you have to do is go on the site and type in your phone's make and model number. And behold the options that you get. You will love it.
Or if you don't want to try the above then contact your service provider (Tata Docomo in your case) or best still, go to the gallery from where you bought your phone. Guys over there are like cellular wizards. They just magically get various stuff to start working on your phone. (not to mention, sometimes even the stuff/services that you don't need is activated) ha ha! So tell them your specific needs & get it done.
Hope this helps.
Nov 06, 2010 | Computers & Internet
Im looking for a girl friend
HA.HA. Cant help you with this problem . Get in to trouble all by your self.
Aug 07, 2010 | Brother IntelliFax-2820 Laser Fax
I cannot connect to the internet using the router the computer does not detect the router please help me with my problem thanks.
we ll start with the physical connections.
1.take ethernet cable n connect one end of the cable to the modem and the other end to the isolated port on the router(internet port) and then connect the computer and your router with other cable(any lan port).refer the chart on the router to distinguish the internet and lan port.
2.check the light status on the modem and router.
router lite status-power,alphabet i lite,wireless lite(lollipop lite) and the number light lit up(depends on the port eg port no:1 connected number 1 light lit up).
3.check the ip address and default gateway address.
steps:In windows(xp,2000 etc),click on start->click on run->in the search tab type cmd->dos prompt window opens,type ipconfig and u ll get ip address and default gateway address(192.168.1.1 or 192.168.0.1).note it
In vista,start->in the search tab type cmd->dos prompt window type ipconfig->u ll get the address as specified earlier.
4.open the browser,type the default gateway address in the address bar and press enter.The login window ll ask for username and password. username-admin
password-password.
5.You ll enter the netgear smart wizard page.Run the setup wizard at the left side (blue screen).select yes and detect the type of connection.
6.If it is a cable modem-dynamic ip detected and click next.check whether the dns address is given automatically from isp and click apply.Then click on basic settings under setup menu and in that window in the router mac address select "use computer mac address "option and click on apply.Now click on router status under maintenance menu and check the ip address in internet port(it should not bo 0.0.0.0) and in lan port(eg 192.168.1.2 or 192.168.0.2).
7.If its a dsl modem-the type of connection ll be detected as pppoe.click next.configure your router with the username and password provided by the isp and click on apply.The router ll save the settings and then check the internet port and lan port
address as given in the previous step.
8.Now we have to configure the router for wireless settings(both modems same configuration).
*click wireless settings under set up menu.
*In that page enter
name(ssid):netgear1
region:us
channel:11
mode:g and b.
In security options select wep and key1 give your telephone number so that you wont forget the password.we have secured the n/w.
9.scan and connect to the network.
For windows vista-start->connect to->select the network name(netgear2)and click connect->it ll ask for password,enter it(telephone no).you ll successfully connected.Now disconnect the cable and try going online wirelessly.
For xp-start->control panel->network connections->right click on wireless network connection->select the network and configure.
10.you ll be able to go online wirelessly if there is any problem delete the preferred networks.
I have given you all the steps with examples to help you configure the router.hope you ll fix the issue and further assisstance im ready to help u but pls give details about your operating system,type of modem and no of computers so that it ll easy for me to troubleshoot.
Sep 28, 2009 | NetGear WGR614 Wireless Router
Typing in blackberry messenger cant do more than 1 word
i have a blackberry curve. my friend tried to tye my password in and got it wrong 10 times. my screen sais 'jvm error 513' and it wont do anything when i click reset. i need help D:
Sep 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My windows Xp on mac wont run
Try getting the latest version of bootcamp again, and making sure you create the driver cd it asks you to create during the install.
This part is critical as it installs the software needed for your keyboard and mouse to be recognised by windows xp.
Hope this help.
Nathan.
Apr 13, 2009 | Apple MacBook Pro Laptop Computer with...
I need help.sorry
are you referring to the one for emailing? Go to your service providor(ISP) website, and look for email settings in the help/support screen. Each one is unique, so I can't really tell you which it is.
Feb 18, 2008 | Office Equipment & Supplies
NuVision NVU22L 10 Ft Hdmi To Hd Cable For Logo
259 people viewed this question
Top NuVision NVU22L Televison & Video Experts
Electro Med Services...
Are you a NuVision NVU22L Televison and Video Expert? Answer questions, earn points and help others
