Question about Garden
Replace starter spring as has come unwound
Trying to recoil and replace
  • 1,631 Answers
Posted on Apr 07, 2015
    Top Expert:
  • Garden Master
  • 12,962 Answers
If you google this it will lead you to a utube site that will walk you thru rewinding the spring.. Not hard, just a PIA.
Fs44 whipper snipper recoil spring unwound, cord jammed and when tried to release recoil spring released
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
http://rapidlibrary.com/source.php?file=ulztcbvqczi89on&url=http%3A%2F%2Fwebweevil.co.uk%2FPublic%2FInfo%2FStihl%2520FS36%252C%2520FS40%252C%2520FS44%2520parts%2520list.pdf&sec=a0a080fc8669d51a
The link is for the breakdown manual and parts list
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    The spring is all the way unwound and pull rope wouldn't rewind
    It sounds like the recoil assembly must be replaced.
    Email me for instructions if you want to replace it.
    aquaman987@aol.com
    Jun 09, 2011 | Garden
    How do you replace spring on a poulan chainsaw
    A Poulan "P4018WT Gas Saw Type 1" IPL follows (may not be your saw):
    http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
    If yours is not a "Type 1" it can be found here:
    Poulan.com
    http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
    The dash number of your serial number is the type.
    If the spring is unwound:
    Recoil Spring Rewind
    I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. The video explains how to tension the spring.
    R² Starter Rope by SmallEng.com
    http://www.youtube.com/watch?v=eRyy3MlsjVo
    If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
    Lou
    Thank You for using FixYa.
    Apr 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
    Starter recoil spring reload, How?
    If the spring is unwound.
    I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
    If the starter cord needs a pretension, this works quite well.
    If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
    Lou
    Mar 26, 2010 | Homelite Garden
    Recoil starter spring has unwound Briggs & Stratton 4 HP mower motor
    you can buy the whole recoil + pull cord ready to install ,or have a small engine shop rewind it if you cant. some times the tab that held it breaks and you have to replace it.
    Mar 06, 2010 | Briggs & Stratton Power Products 5,550...
    Cant remember how to put the spring back on the pull cord recoil
    This reply is based on the following assumptions:
    A Poulan PP2375LE (wildthing) Type 2
    The starter recoil spring is unwound.
    All components aer servicable
    Poulan 2375LE Type 2 IPL
    http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
    Starter components and reassembly order are illustrated on the "Handle, Chassis & Bar Assembly" detail.
    If the spring needs rewound this is how I do it, there are other methods.
    I invert and secure the housing and rewind the spring large coil to small (need eye protection, and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool.
    This illustrates proper pretension and rope installation:
    Smalleng.com (about 3.5 minutes long and worth watching the entire video)
    If yours is not a Type 2 you can find the correct IPL here:
    Poulan.com
    I hope this was helpful
    Lou
    Jan 29, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
    WeedEater Edger PE550 Starter Rope will not recoil
    Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
    Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
    Garden Logo
    49 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
