Question about HP Office Equipment & Supplies
Can I make the font size bigger when I copy a document off my HP Officejet Pro 8610
Rain041304
  • 63 Answers
SOURCE: font size
You can change it on yor POS software.
Posted on Feb 14, 2008
SOURCE: Lines appear when making a copy using document feeder tray
If the lines are vertical (in the direction the ADF feeds, 11in long for 8 1/2 by 11) You can try cleaning the glass the scanner uses when it's using the document feeder. Pull up the top left part of the printer where the documents feed, there's a little rib in the middle of the side to help you do this, then simply pull up the assembly underneath with all the rollers in it, you should see about an inch of glass underneath and a centimeter long strip of white plastic on the assembly (this serves as the white background when feeding slimmer papers) Clean them both. I'd recomend any glass cleaner, just don't spray it in there, spray it onto a cloth.
Posted on Jan 19, 2009
myjosh007
  • 530 Answers
SOURCE: my hp officejet j5750 does not copy
hi im josh in cebu phils.try my solutions
.tt1 {font-size: 10pt;} If your printout is not as you expected, there might be several causes. The most likely cause, believe it or not, is our old friend the poorly connected cable. If all the instructions don't make it from the computer to the printer, your printout will be incomplete, if not totally out of whack. Check all cable connections to ensure a good throughput of data. If that doesn't fix the problem, just change the printer cable. An old or damaged cable could be causing your problems.
tip
tip_icon.gif Printing the printer's self-test page is also a good way to determine whether the problem is in the printer or in the computer—or somewhere in-between.
Another cause of print garbage might be the printer itself. If you have a low or old toner cartridge in a laser printer or a near-empty ink cartridge in an inkjet printer, your printout will be lighter than normal, perhaps even unreadable. If necessary, change the cartridge and run the print job again.
If you're using a laser printer, you might get black streaks on your output. This problem is most often caused by an old toner cartridge, or by a dirty roller or printer cleaning bar. If you replace the toner cartridge and clean the suspect parts (using a cotton swab) and you still experience black streaks, your printer might need service.
If you're using an inkjet printer, it's possible that your print jets are clogged. You'll need to unclog the print jet by inserting a small pin into the jet.
It's also possible that a paper misfeed in your printer caused the printout to become smudged or out of line; if this is the case, straighten the paper feed and start the print job again.
An incorrect printer setup in Windows can also cause unusual printouts. Make sure that Windows is configured for the exact type of printer you're using. Also make sure that you have the correct landscape (horizontal) or portrait (vertical) printing option selected.
If none of this works, you probably have a problem somewhere in your printer. Although a bad printer port on your PC could be the culprit, more than likely some internal problem with your printer is causing the poor printout. (You can confirm this by printing a self-test page; if it looks bad, the problem is in your printer.) Consult your friendly repair center.
Problem: Your Printed Page Looks Half-Finished If you're trying to print a document with a lot of graphics (especially on lower-priced laser printers), you might find that your printer doesn't have enough memory to print the entire document. What you'll get is about half the document—and not always a contiguous half! You can do one of several things to rectify the problem:
  • Add more memory to your printer. If you do a lot of heavy graphics printing, you probably need at least 1MB of RAM installed in your printer. You might be able to add the memory yourself, or you might want to have a qualified laser printer technician do the job for you.
  • Instruct Windows to print this document at a lower resolution. Go to the Printer Properties dialog box for your printer and select the Graphics tab (if your printer has this option). Select a lower resolution (which requires less memory and gives you less finely detailed output) and see if you can now print your document.
  • Simplify your document. If you're using a lot of different fonts and graphics, take some out. It's not an ideal solution, but it might be the only way you'll get this particular document printed on time!
Problem: Your Printer Prints, but the Fonts Aren't Correct If you create a document on a PC with one set of fonts installed, and try to print it on another PC with different fonts installed, you could be in for a real surprise! Windows will try to "match" missing fonts, but quite often the match leaves a lot to be desired—resulting in different line lengths and page breaks than what you had originally. Your options are to install the missing fonts on the PC you're printing from, or change the fonts in the document in question. (A word to the wise: stick to common fonts such as Arial and Times New Roman if you think you'll be sharing a document on multiple PCs.)
Problem: Your Color Printer Doesn't Print All Available Colors This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge.
Problem: Paper Jams in Your Printer It's possible that your printer's internal paper feed mechanisms are getting dirty. You can try taking the printer apart yourself to clean out any pieces of scrap paper or other debris, or you might want to take it into the shop to let a pro deal with it.
You might also be getting some paper sticking to other sheets of paper in your paper tray. (This happens more often with cheaper paper—spend a little more and get the good stuff!) Try thumbing through the stack of paper before inserting it into the tray; this should loosen up the paper and make it feed easier into your printer.
Finally, you might need to change the grade of paper you use with your laser or inkjet printer. Lightweight papers tend to jam up the works, so switch to something heavier if you experience a lot of problems.
THE ABSOLUTE MINIMUM
  • Most printer problems are caused by a bad cable connection, a misconfiguration in Windows, or a bad or outdated print driver.
  • All printers need periodic maintenance; make sure you regularly change toner or ink cartridges, clean the paper path and feed, and—if you have an inkjet printer—use the cleaning option to clean the ink jets and cartridge.
  • If you're having trouble printing graphically intense documents on a laser printer, you might need to add memory to the printer or simplify the documents.
  • Lightweight paper can cause unexpected paper jams; use a better grade of paper to keep things running smoothly.
  • good luck friend
Posted on Mar 05, 2009
Roop1980
  • 228 Answers
SOURCE: The font size is very small on the my printed doc. and I want to increase the font size
Fonts and font sizes are managed within the program you are using, the actual font files, and your operating system (typically Windows). This is especially true with some languages on the internet - you will need Language Packs from the program manufacturer to successfully display the characters of some languages.
If the printer works with other fonts and other programs just fine, but is having a problem with one specific font or program, then you will need to contact the manufacturer of the font (Or Microsoft, if it is a font that came with Windows), or the program manufacturer, for more assistance. The printer only prints what is sent to it, if other programs work fine, then the printer, its driver, and the related hardware are fine. Any printer does also not include fonts in the installation of the printer driver, so reinstalling the printer driver will not replace or solve font problems. If the printer is not working from multiple programs, let us know so we can troubleshoot this issue. Otherwise, you will need to contact your program manufacturer for information on how to manage fonts or the manufacturer of your specific font.
Posted on Apr 14, 2009
  • 10865 Answers
SOURCE: i need help removing a paper jam in the document
Hi. here is the link to HP and what they recommend. I hope it solves your problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00839319&lc=en&cc=us&dlc=en&product=2512009
Posted on Aug 05, 2009
My printer is only printing one copy at a time
Your question is not clear. You mean it print only one page of a document with several pages?
Guess you should unistall drivers, look for a more recent version of drivers in HP website and reinstall your printer
Oct 12, 2015 | HP Officejet Pro 8610 Inkjet Multifunction...
How do i refill my hp cartriges in my hp 8610 printer step by step.
All refill sets, come with a good description. But before you buy ink, make sure your cartridges can be filled and the chip can be reset. So you won't end with filled and unusable cartridges and dirty hands.
Look here to see how things go:
Ink Refill Kit For HP Officejet Pro 8610 8620 8630 8625 8615
Mar 29, 2015 | HP Officejet Pro 8610 Wireless All-in-One...
Will not print word document
Most likely there is a problem with the default "Calibri" Font in the body template of Normal.dot.
temporarily change the default font to say "Times new Roman", then download another version of the Calibri font from internet or copy from another PC.
Dec 18, 2013 | HP Officejet Pro 8600
How do i change font size on HP 6110 xi printer
The manual doesn't list scaleable font size as a feature. You will probably have to set your font size in the document you are making.
Mar 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to change font size on officejet 6110 printer
you determine the font size via your computer. You can change font sizes on any document typed or received as long as the received document is not 'read only'
55 people viewed this question
Seeker5211
Seeker5211
