I look for main board, where to find it?
Display flashing and flickering.
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
It will be difficult to get its original main board. You might have to repair it. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 07, 2015
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Lg 47lv355u tv
Ok t-con board is connected to main board which is giving signal and logic supply.. If the main board failed or giving a over voltage to the t-con it possibly your T-con gone out (new) again.
To isolate the problem try to replace the main board.
Dec 05, 2012 | Televison & Video
Indesit WIXE127 washing machine with a flickering display screen
This is a fault with the contoller board and it is possible that the power supply is not stabilising due to an erratic stabilisation. This can be due to faulty capacitors- in case the main filter had leaked and damaged.
If so you can replace them but with case to remove from the PCB.
Also it can be due to poor connector or dry solder on the main board. Best is to check this out without delay as it can damage the board at a later stage..
Jun 26, 2012 | Washing Machines
Monitor flickers, similar to a fluorescent light bulb that is going out. Also, there is one line on the left side of the screen, going up and down, that changes color, but it comes and goes. I thought...
The problem is in the monitor screen, there is a large circuit board connected behind the main display screen. The video signal is feed to the main board and generates the proper color balance, the second problem is the lamp behind the display is flickering and breaking down. To repair this will not be cost effective, cheaper to replace the monitor. But I would suggest hooking a spare monitor to the computer to make sure there are no additional issues.
Jan 21, 2011 | Dell SE198WFP LCD Monitor
My Hp Designjet T1120 fails to initialize. When mains is switched ON the Front Display Panel in the plooter illuminate without any display and the Power switch in the display panel flickers with green...
Reset the formatter & check,,
Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..
Led pattern: Power supply LED as 1
Formatter leds 3nos from left to right as 2,3 & 4..
* indicates "on"
# indicates "off"
& indicates "flashing"
* # # # ....Main PCA
* * # # ....Formatter
* $ # # ....Hard disc
* * * $ .....Main PCA or Formatter
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part.. 11_19_2011_3_40_14_pm.jpg
Oct 11, 2010 | HP DESIGNJET T1120 44 Printer
Mac Book Display Flickers
Check the Wire Harness from the screen, This can be checked by removing the bottom of the system. 9-12 screws, and then remove the main board. I had this issue on a 13" MB.
If you need further Instructions,
Contact me here.
-Stephen.cscorp@gmail.com
Apr 12, 2010 | Apple MacBook Pro Laptop Computer with...
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Laptop screen display
backlight, inverter or loose screen connector into system board
Nov 24, 2008 | Acer Aspire 9300 Notebook
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
VIEWSONIC VPW505 Screen flickering
Got it. I was the 'guest' who posted that I had the same problem. Not the CTRL board as I earlier thought. It boils down to the Y-SUS board (right hand side as you face the back of the display) In the upper-upper left hand quadrant you'll find a small capacitor labelled "C70".
This is the naughty one.
You can verify this by removing the back of the display, powering up and then with a small extended flame lighter, GENTLY warming C70. All it takes is about 2 to 3 seconds and the display will steady up just like always.
C70 is a surface mount capacitor, most likely 33uf at 25 volts. Haven't confirmed this yet. Will post again when I've affected the repair on my VPW505.................
BTW: This is not something you want to attempt unless you have experience with electronics. No.....really!
Sep 01, 2007 | ViewSonic VPW505 50 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
