Question about KitchenAid Dishwashers
Kitchenaide dishwasher drains sometimes - KitchenAid Dishwashers
    Habit-Forming:
    New Friend:
  • 20 Answers
You also might have a blockage in your air gap. Your air gap sits on your sink. You generally have the dishwasher drain line going into the air gap and then the other side of the air gap is a hose that attaches to the garbage disposal. If plastic items like stickers from vegetables and fruit go through your pump they can accumulate in the end of the air gap and cause no drain situations.If you do not have an air gap and your drain line is going directly into your garbage disposal then you need to make sure that the drain line sits higher than the dishwasher tub and has a loop in it. This will avoid any water backing back into the dishwasher when you are using your sink. You will need to take the cap off the air gap and look inside.
kitchenaide dishwasher drains sometimes - kitchenaide-dishwasher-drains-sometimes-q3ht0obhzr4haiynuyvb4e0h-4-0.jpg
Posted on Apr 12, 2015
    Champion:
  • KitchenAid Expert
  • 220 Answers
Usually when you have intermittent drainage the check valve in the drain hose is staying open allowing water back into the sump the fact that it is draining tells me the pump is rotating on a few occasions i have found a broken vane on the pump impeller you will usually hear a rattling sound I am assuming the drain line is routed correctly and it did drain correctly at one point.
Posted on Apr 07, 2015
Kitchen aid dishwasher m # kdfe304dss wont drain , can hear clicking sound from underneith.what do you recommend? 14 months old.
KitchenAid Dishwasher Not Draining - Model KUDP02CRBL0
www.repairclinic.com/RepairHelp/...Dishwasher/...-/KitchenAid-Dishwas...
See All Dishwasher Parts for model KUDP02CRBL0. Cause 1 Drain ... If the drain pump motor is not working, the dishwasher won't drain. To determine if the ...
How to repair a dishwasher, not draining - troubleshoot ...? 6:18https://www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYMost of the time if it is not draining, the garbage disposal is clogged or there ... If you have a newer model dishwasher that looks different from the one .... But with the help of your video, I was able to show her where her ... How to Fix a Dishwasher thatWill Not Drain : How to repair your home - Duration: 1:50.Missing: kdfe304dssDishwasher Repair-Will Not Drain-Part 2 - YouTube? 4:14https://www.youtube.com/watch?v=dYHTdzQrsBAApr 20, 2013 - Uploaded by Frosty LifeInstructions 1 Press the "Cancel/Drain" button on yourKitchenAid dishwasher after the Clean light comes on to manually drain the standing ...Missing: m ‎kdfe304dssReviews on kitchenaid dishwasher kdfe304dss
Jan 17, 2016 | KitchenAid Dishwashers
Upper drawer dishwasher won't drain
First =check for a plugged drain line
Second = check for plugged screens in the unit.
It could also be your pump. The vanes are only plastic and they sometimes just give out.
Jan 07, 2014 | KitchenAid Kitchen-Aid KUDD03DTSS...
Sometimes doesnt drain completely,hooked to disposal correctly
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Apr 17, 2011 | KitchenAid Dishwashers
Kitchenaid normal cycle light and cancel light both blinking. Dishwasher wont start
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
Kitchenaid dishwasher kuds24sewh2. It won't drain
  • A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
  • Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
  • Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
  • Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
May 04, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
Only motor goes on, no water
Hi,,
try these
  1. Check that the water supply is turned on. The valve may be located under the sink.
  2. Check the door latch
  3. Test the door switch
  4. Inspect the float assembly
  5. Inspect the fill tube for kinks
  6. Test the float switch
  7. Check the inlet valve filter screens
  8. Test the water inlet valve
  9. Test the drain valve lever arm
  10. Check the drain valve
  • please rate my suggestion....
Apr 11, 2009 | KitchenAid Dishwashers
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Dishwashers Logo
165 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
