Question about Pool & Spa
Although the batteries fully charged the unit will not start
Although it doesn't start (the shaft will not move it does make a small noise. Has the electric motor failed
  • 1,631 Answers
What exactly are you referring to?
make & model please... please place your answer into the comments of this thread, and somebody in the forum will assist you.
Posted on Apr 16, 2015
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
Apr 24, 2013 | Electric Mobility Mobility Electric Power...
Won't start battery is fully charge. No noise when
Does the engine crank over but not start?
Jan 06, 2013 | Cars & Trucks
Hyundai Sante Fe Imobiliser problem?
can you hear the starter click at all take a hammer and tap on the starter if that works then you know the starter is bad, if you are comfortable enough take out the battery and the starter and take them to your local autozone have them tested just because a battery is fully charged doesn't mean that it doesn't have a dead cell or 2. They can test the starter also
Jun 03, 2012 | Hyundai Santa Fe Cars & Trucks
Audi A6 wont start
the clicking noise is the starter selonoid because there is not enough power in battery, either fully charge the battery or get a jump start. if you have any other problems just let me know and i will try sort it for you. good luck
Feb 17, 2012 | Audi A6 Cars & Trucks
Brand new unit forward and reverse seems very slow moves a little then just hovers.
Make sure you're charging fully, until the light on the charger doesn't get ANY brighter when you unplug the helicopter. Also, battery must be allowed to cool 10 minutes after flying AND another 10 minutes after charging.
Most crucial is that you must never fully discharge battery. Fully draining a Li/Po even once (especially when it's new) can cripple or ruin your battery. As soon as you are unable to maintain altitude, land copter and power it off. Also, there is a button on the remote, labelled "tail motor speed switch" located near the trim control. With it in the "off" or up position the tail motor is much slower allowing for more precise control. When button is pushed to the down or "on" position, tail motor moves faster giving more tilt, and thereby much more forward/reverse 'thrust'. Verify that tail rotor is moving when right joystick is actuated (and that it reverses when right stick is pulled in opposite direction) and that it isn't loose on it's shaft... this can be tested by verifying tail rotor spin in one direction then reversing joystick... tail rotor should instantly start spinning in the other direction with NO hesitation, if it slows and then starts spinning in other direction or anything like that then it's loose. Turn helicopter upside down then VERY CAREFULLY apply a small drop of super glue where the shaft meets the tail rotor, be very cautious to not get any glue near where the shaft comes out of the motor, and do not turn right side up until glue is fully dry.
Hope this helps,
r
Jan 07, 2011 | SYMA Toys industrial Syma S032 Ready to...
2005 Mini Cooper won't start battery is fully charged
I found solution. In my case problem was with connection next to the small electronic module next to the gear wheel. It is module directing red light in proper 'P', 'R', 'N' and 'D' letter.
Jul 12, 2010 | 2005 Mini Cooper
Watch stopped while in hospital and now, although running again, has the second hand moving in two second intervals
Some Seiko kinetic watches and other self charging watches do this when the battery is low. If it relies on you moving to keep it charged that may explain why it stopped in hospital. Try giving it a good shake and see if it starts moving smoothly again
Aug 10, 2009 | Watches
My Garmin forerunner 305 recently got immersed in
I have read in some other posts about the unit only working while being plugged into a USB port. My guess is that the battery is in fact shot and the unit will only run off the USB port while plugged in. Submersing in water is not a good idea. On the back of the unit there are some small holes for the speaker. These speakers corrode from sweat and eventually quit.
Jun 05, 2009 | Garmin Forerunner 305 GPS Receiver
Intermittent Crackling noise in the right headphone
Hello Rachel, I use my QC3 for 2.5 years Mon-Fri for 3 hours a day. I have the same problem when battery is weak and/or it is cold outside. The cracking nose stops for me if battery fully charged. This is known problem andBose put it in the manual.
Vlad
Aug 28, 2008 | Bose QuietComfort 3 Acoustic Noise...
Pool & Spa Logo
63 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
